08-01-2014, 23:22 | #1 (permalink) |
Junior Member Join Date: Sep 2005 Age: 36
Member: 185667 Status: Offline Thanks Meter: 2 | eMMC ORC: 00000000 A0 Read Info... Device Ready... Device Ready...OK! ID check... Level (V): VCC V18 VCCQ D0 CMD CLK 1.8 Pullup: 0.01 0.00 0.00 0.53 0.71 0.01 1.8 Low : 0.01 0.02 0.00 0.05 0.02 0.00 1.8 High : 0.00 0.00 0.00 1.47 1.49 1.49 ... 2.5 Pullup: 0.00 0.00 0.00 0.71 0.76 0.00 2.5 Low : 0.00 0.00 0.00 0.00 0.03 0.00 2.5 High : 0.01 0.01 0.00 1.94 1.97 1.96 ... 3.3 Pullup: 0.00 0.00 0.00 0.70 0.78 0.01 3.3 Low : 0.00 0.00 0.00 0.00 0.02 0.00 3.3 High : 0.01 0.02 0.00 2.25 2.27 2.27 ... --------------------------------------------------- eMMC ORC: 00000000 A0 eMMC CID: 0000000000000000,bad code! >>ID check lost! |
08-02-2014, 04:27 | #2 (permalink) |
Product Manager Join Date: Apr 2008 Location: Whitehole throught Blackhole!
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,623 | How did you join the GPG EMMC Adapter (Position)? Did you see the light (luz) on the adapter? if not, you have to install the driver for this. After installing driver you can see the special port for this (Check Device Manager of your computer). check the picture below: 20mb image hosting I am sure, you have forgotten to connect USB cable Power Adapter to the GPG EMMC Adapter. Can you see the light glowing on the GPG Power Adapter? If yes, not go to the "DEVICE MANAGER" of you computer and you will see the "USB to Serial Port" as shown in the below picture. The Driver of Power Adapter http://www.4shared.com/zip/f9egwBDB/...RT_driver.html upload foto Now, choose your COM Port as shown in the picture below: photo hosting I hope remaining process you know well. IMPORTANT FOR NOTE 2 and I9300 Device If the device is NOTE 2 or i9300 then read more: http://forum.gsmhosting.com/vbb/10419568-post4.html BR Dipendra Pathak Last edited by Dipendra Pathak; 08-02-2014 at 09:35. |
The Following User Says Thank You to Dipendra Pathak For This Useful Post: |
08-03-2014, 03:05 | #4 (permalink) |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,623 | Post your problem with screen short (Picture as i have posted above). I understand your language but I can't write here because we are not allowed to write in other language except English. Hope you understand. BR Dipendra Pathak |
08-07-2014, 21:09 | #5 (permalink) |
Member: 185667 Status: Offline Thanks Meter: 2 | este es mi error, esta conectado los puntos 100% testeado image hosting over 5mb post images http://i57.tinypic.com/2nh45ys.jpg http://oi57.tinypic.com/2hy8ihh.jpg . Last edited by Dipendra Pathak; 08-08-2014 at 06:24. Reason: Fixing picture on the link |
08-08-2014, 06:31 | #6 (permalink) |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,623 | Already same kind of problem over here: http://forum.gsmhosting.com/vbb/10012636-post5.html and do not forget to check the i9300 and Note 2 issue as user has posted: http://forum.gsmhosting.com/vbb/10419568-post4.html BR Dipendra Pathak Last edited by Dipendra Pathak; 08-08-2014 at 06:41. |
08-08-2014, 15:19 | #7 (permalink) |
Member: 185667 Status: Offline Thanks Meter: 2 | connections estasn 100% tested have placed several teams igniting just asking product name I buy the new cable that never came free to continue with the same error need a hand full to show us flaws additional error on when you have a line connected the sample to check if the connection to not tell me it's Connection failure need help |
The Following User Says Thank You to magojhon For This Useful Post: |
08-12-2014, 05:39 | #10 (permalink) | |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,623 | Quote:
Hi brother, sorry for delay. I was on short holiday. Brother if you have cable problem, simply request your reseller to replace it. BR Dipendra Pathak | |
08-25-2014, 16:33 | #12 (permalink) |
Member: 185667 Status: Offline Thanks Meter: 2 | I have more than 4 phones that make the same error that is not emmc problem and another thing as I will say that the cable is bad that lackluster response. for such a bad case you can not expect less. |
