Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > GPGeMMC
Old 02-04-2014, 09:03   #1 (permalink)
sahilfency's Avatar
Member: 1212231
Sonork: 100.1611130
Thanks Meter: 164
eMMC ORC: 00000000, bad code ! >> Id check lost /// Solution Here \\\
GPGeMMC Box provided Special Adaptor for ISP and JTAG. Make sure for ISP read and write use ISP Adaptor/Jig and for ISP writing Use ISP correct Files. Don't use ISP files into JTAG and don't use JTAG files into ISP. ISP files are like this Boot1, Boot2, USER, etc. and Jtag files don't have Boot1. Boot2, User etc. so 1st of all make sure of this. 2ndly Triple Check your Soldering use Good Jumper Wires for Soldering and Good Solder and Good Iron. after all Trip Check if still you are getting Bad code error can be cause of two reasons 1st phone can be Hardware and 2nd use this method to make sure it's hardware issue or not.
Check this picture
Some phones need Extra Current of 3.3 Volts and these type of phones not connect with box. when you try to connect it with GPGeMMC you got error
>> Id check lost
what you have to do is make sure your soldering are 101% correct after confirm just put 3.3v to ISP jig. Keep in mind no need to sold any extra 3.3v to phone. just you have to sold extra 3.3v to ISP adaptor. these kind of error comes on N7000, I9300, N7100 etc so i had tested many of these phones which was giving error so i research and found this solution and it's working fine. If you have I9300 type phones which no need 3.3 volts that type of phones need VCC which is 2.8 Volts. for those type of phones just put 2.8 Volts to ISP adaptor and phone will connect but again before Putting External volts you make sure your soldering is 101% correct. So for those type of phones which have Vcc pinouts and mobile giving error of bad code then you need to put 2.8 volts to VCC on ISP adaptor not to phone. and which phones have 3.3v pinouts and mobile giving error of bad code then you need to put 3.3 Volts to 3.3V on ISP adaptor not to phone. But again make sure your soldering are 100% correct. and IF even that phone showing BAD code error it's means your eMMC ic is TOTALLY DAMAGED !!!
here is some pictures i want to share with you
i got N7000 trying to repair it. but it's not connecting. i sold wires and verify it. even thing was fine but phone was not connecting here is screen shot ( i didn't sold External power on this screen shot )
then i sold External volts check here ( i use Battery to give 3.3 Volts )
after sold external power here is the results
and mobile Successfully Repaired !!!!
The Following 6 Users Say Thank You to sahilfency For This Useful Post:
Old 02-05-2014, 06:10   #2 (permalink)
Member: 1595163
Thanks Meter: 51
Good work Bro! thank u for your experiment.
Old 02-05-2014, 06:40   #3 (permalink)
SHIJILFONOTLY's Avatar
Member: 351924
Thanks Meter: 12,469
this power supply also worked
this power supply generated by 3.3volt and 1.8volt
my hand made
if you need more information i can make mannul how to make the power supply device
The Following 5 Users Say Thank You to SHIJILFONOTLY For This Useful Post:
Old 02-05-2014, 08:02   #4 (permalink)
Member: 1247583
Thanks Meter: 17
my hand made
can you give this procedure?
Old 02-05-2014, 08:27   #5 (permalink)
Member: 351924
why not
give me today
i give you full details tommarow
The Following User Says Thank You to SHIJILFONOTLY For This Useful Post:
Old 02-05-2014, 08:34   #6 (permalink)
Member: 1247583
Thanks Meter: 17
why not
give me today
just post here the materials and procedure how to do it
Old 02-05-2014, 08:38   #7 (permalink)
WBGSM's Avatar
Member: 1759636
Sonork: 100.1591515
Thanks Meter: 785
I just ask for clear my mind Bro sahilfency You mention the set modle Note N7000 and in Picture PCB Circute is diffrent did u repaire and done Note1 N7000 or other modle because i am facing also this problem in same modle N7000
Plz Clear to me that is circut is Note1 N7000 or it will work all that modle wich you told
thanks
WBGSM
Old 02-05-2014, 08:42   #8 (permalink)
CONCORDIA GSM's Avatar
Member: 209722
Thanks Meter: 818
hi
good job
we need to sold gnd from extra battery to adaptor vcc one ???
Old 02-05-2014, 09:28   #9 (permalink)
sahilfency's Avatar
Member: 1212231
Sonork: 100.1611130
Thanks Meter: 164
thanks
WBGSM
some pictures share above
& of course u can use it in n7000...
in n7000, there are 2 options of 3.3 and both jumper connection are necessory
Old 02-05-2014, 10:00   #10 (permalink)
Member: 1350832
Sonork: 100.1627308
Thanks Meter: 25
thanks
WBGSM
have the same problem bro
Old 02-05-2014, 10:17   #11 (permalink)
Member: 209722
Thanks Meter: 818
3.3 volts from battery like ur screen shot are sold to adaptors 3.3 then whats about gnd from same source where we need to sold it or no needed gnd anymore ??
Old 02-05-2014, 10:31   #12 (permalink)
sahilfency's Avatar
Member: 1212231
Sonork: 100.1611130
Thanks Meter: 164
bro without gnd how to work ?
put it on pcb or adeptor
The Following User Says Thank You to sahilfency For This Useful Post:
Old 02-05-2014, 10:37   #13 (permalink)
Member: 351924
Old 02-05-2014, 11:03   #14 (permalink)
Member: 1260512
Sonork: 100.1605447
Thanks Meter: 461
Hello sir
u make battery to external power 3.3v and 2.8
all the time Battery is 3.7v so how i can convert to 2.8 or 3.3v?
connect direct to ISP jig?
pls help me,thanks
Old 02-05-2014, 11:27   #15 (permalink)
sahilfency's Avatar
Member: 1212231
Sonork: 100.1611130
Thanks Meter: 164
u have more option .........................
this is easy way .Communication Maintenance Power Supply(bk 1501t+ Baku New Products) - Buy 10v Power Supply,110v Power Supply,2a Power Supply Product on Alibaba.com
Page generated in 0.25558 seconds with 8 queries
