Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > GPGeMMC
Old 03-24-2014, 23:59   #46 (permalink)
Member: 185667
Thanks Meter: 2
Read Info...
Device Ready...
Device Ready...OK!
ID check...
Level (V) : VCC V18 VCCQ D0 CMD CLK
Pullup : 1.20 0.00 2.63 0.00 0.00 0.00
Power ON : 2.62 1.77 3.30 0.84 1.64 0.00
eMMC ORC: 00FF8080
eMMC CID: 0000000000000000,bad code!
>>ID check lost!
samsung i9300
how to repair
Old 03-27-2014, 00:11   #47 (permalink)
c_ahmad79's Avatar
Member: 221603
Sonork: 100.1581270
Thanks Meter: 6,392
Originally Posted by magojhon View Post
Read Info...
Device Ready...
Device Ready...OK!
ID check...
eMMC ORC: 00FF8080
>>ID check lost!
samsung i9300
how to repair
change the vcc voltage to 2.80
if all connections are ok and still same earror then have to replace emmc
Regards
Old 04-05-2014, 13:31   #48 (permalink)
misal's Avatar
Member: 185854
Sonork: 100.1592083
Thanks Meter: 286
Read Info...
Device Ready...
Device Ready...OK!
ID check...
Pullup : 0.09 0.00 2.75 0.00 0.00 0.00
Power ON : 2.80 1.77 3.30 1.55 2.07 0.01
eMMC ORC: EF800000
>>ID check lost!
Today i m buy new Gpgemmc box for repair dead phone. i was try i9300 4 pess , But i can,t connect any one. all time show this problem. i have 5 pess i9300 hang samsung logo and no product name
plz help me gpgemmc product team . how to connect it,sssssssssssssssss plz
Old 04-05-2014, 19:29   #49 (permalink)
c_ahmad79's Avatar
Member: 221603
Sonork: 100.1581270
Thanks Meter: 6,392
Originally Posted by misal View Post
Read Info...
Device Ready...
Device Ready...OK!
ID check...
eMMC ORC: EF800000
>>ID check lost!
all user making mistake emmc box cant repair all the phones with isp flashing note2 , s3 etc ... sucess rate of repair hang logo and dead phones is 20-40% other which fail to connect have to replace emmc
Regards
Old 04-05-2014, 22:19   #50 (permalink)
trashed's Avatar
Member: 8303
Thanks Meter: 127
@c_ahmad79
why everytime you answer you sound like either the user is the problem or the emmc/phone is the problem?
why don't you accept that the box itself have a problem that's why the product creator is doing the fix.
didn't you read their thread? their thread about the "adaptor" that will fix the connection problem?
look at your post above, none out of 4 i9300 is connecting properly, do you think it's because the emmc is dead? i bet those 4 i9300 can be connected properly to other box...
next time, before you do an advice, make sure you mention that the box have problems too, not just blaming the user or the emmc...
The Following 2 Users Say Thank You to trashed For This Useful Post:
Old 04-07-2014, 16:03   #51 (permalink)
Member: 2078045
Thanks Meter: 145
i9300
eMMC ORC: 00000000,bad code!
ID check lost!
Please choose chip.
Read Info...
Device Ready...
Device Ready...OK!
ID check...
Pullup : 0.00 0.00 0.02 1.40 0.00 0.00
Power ON : 2.62 1.81 2.54 0.85 2.53 0.00
>>ID check lost!
use external suply voltaje no work ?
friend can explain me more clear where I connect the battery
diagram plizz
Old 04-29-2014, 03:27   #52 (permalink)
Member: 174603
Sonork: 100.1614168
Thanks Meter: 3
Originally Posted by Ghandysoft View Post
thanks bro i will try and post result im so grateful for your reply
This is also worked i tested
Thanks !
Old 05-07-2014, 13:21   #53 (permalink)
Member: 2099630
any ideas on this ?
Connecting...
SN:00000100495
Get License data...
Verify Liecnse data...
Version:V3.1
Device Ready...OK!
PIN3 = SYSRST
PIN5 = TDO
PIN7 = RTCK
PIN9 = TCK
PIN11 = TMS
PIN13 = TDI
PIN15 = TRST
Please choose phone.
Reading...
Device Ready...
Device Ready...OK!
ID check...
Pullup : 0.41 0.00 0.44 0.77 0.00 0.00
Power ON : 2.62 1.76 2.51 0.86 2.50 0.00
eMMC ORC: C0FF8080
eMMC CID: 150100303030303030562011072658
eMMC CSD: 902701320F5903FFF6DBFFEF8A4040
ID check: 00010015
Product name: 000000
User partition size: 400000000 ( 16384M / 16.000G), 17179869184 Bytes
Boot partition size: 0x80000 ( 0.5M )
RPMB partition size: 0x20000 ( 0.1M )
ID check...OK!
Read chip...User
>>Read chip lost!
any other method maybe ? am i doing something wrong ?
isp will help ?
chip is bad?
any other ideas?
Old 05-07-2014, 14:22   #54 (permalink)
Member: 2078045
Thanks Meter: 145
resolder cable conexion
Old 05-07-2014, 15:37   #55 (permalink)
Member: 2099630
i use an adapter for the chip ,you think it got something to do with the wiring.
i need to check the setting or something ,like ic_speec and vcc ?
Old 07-22-2014, 18:31   #56 (permalink)
Member: 732994
Thanks Meter: 80
What is the problem with this ?
With other tool i can write and check
Device Ready...
Device Ready...OK!
ID check...
Level (V): VCC V18 VCCQ D0 CMD CLK
1.8 Pullup: 0.62 0.00 3.20 0.10 0.10 0.00
1.8 Low : 0.61 0.00 3.20 0.00 0.00 0.00
1.8 High : 0.59 0.48 3.20 0.88 0.90 0.90
2.5 Pullup: 0.48 0.00 3.20 0.10 0.10 0.00
2.5 Low : 0.47 0.00 3.20 0.00 0.01 0.00
2.5 High : 0.45 0.49 3.20 0.89 0.91 0.91
3.3 Pullup: 0.36 0.00 3.20 0.11 0.11 0.00
3.3 Low : 0.36 0.00 3.20 0.00 0.00 0.00
3.3 High : 0.35 0.50 3.20 0.90 0.92 0.92
Power On : 0.74 1.53 3.20 0.75 0.75 0.00
Set Low : 0.75 1.53 3.20 0.01 0.01 0.00
Set High: 0.77 1.69 3.20 2.23 2.25 2.27
Work Voltage: 0.76 1.55 3.20 1.36 2.09 0.00
eMMC ORC: F807FC04 A7
>>Write chip lost!
Old 08-15-2014, 10:22   #57 (permalink)
Member: 2142391
Sonork: 1656181
Thanks Meter: 13
Connecting...
SN:00000100810
Get License data...
Version:V3.1
Device Ready...OK!
Erasing...
Device Ready...
Device Ready...OK!
ID check...
1.8 Pullup: 2.18 0.00 0.05 0.23 0.24 0.05
1.8 Low : 2.14 0.00 0.05 0.00 0.00 0.04
1.8 High : 2.08 0.00 0.05 1.03 1.06 0.27
2.5 Pullup: 1.59 0.01 0.87 0.58 0.56 0.89
2.5 Low : 1.56 0.00 0.05 0.01 0.00 0.56
2.5 High : 1.52 0.00 0.05 1.35 1.38 0.74
3.3 Pullup: 1.11 0.00 0.87 0.75 0.72 1.08
3.3 Low : 1.08 0.00 0.05 0.01 0.00 0.66
3.3 High : 1.06 0.00 0.87 1.64 1.67 0.92
Power On : 2.83 1.78 2.53 0.85 0.86 2.53
Set Low : 2.83 1.78 2.53 0.01 0.00 2.52
Set High: 2.83 1.78 2.53 1.98 2.01 2.53
Work Voltage: 2.83 1.78 2.53 0.85 0.86 2.52
eMMC ORC: 00000000 FF
Please check CLK .
Erase chip lost!
Erasing...
Device Ready...
Device Ready...OK!
ID check...
1.8 Pullup: 2.18 0.00 0.05 0.23 0.23 0.05
1.8 Low : 2.13 0.00 0.05 0.00 0.00 0.04
1.8 High : 2.08 0.01 0.05 1.03 1.06 0.27
2.5 Pullup: 1.59 0.00 0.87 0.58 0.56 0.89
2.5 Low : 1.55 0.00 0.05 0.01 0.00 0.57
2.5 High : 1.52 0.00 0.05 1.35 1.38 0.75
3.3 Low : 1.08 0.00 0.05 0.01 0.00 0.67
3.3 High : 1.06 0.00 0.87 1.64 1.67 0.91
Power On : 2.83 1.78 2.52 0.85 0.85 2.53
Set Low : 2.83 1.78 2.52 0.01 0.00 2.52
Set High: 2.83 1.78 2.52 1.98 2.00 2.53
Work Voltage: 2.83 1.78 2.52 0.85 0.85 2.52
Please check CLK .
Erase chip lost!
Erasing...
Device Ready...
Device Ready...OK!
ID check...
1.8 Pullup: 2.18 0.00 0.04 0.23 0.23 0.05
1.8 Low : 2.13 0.00 0.04 0.00 0.00 0.04
1.8 High : 2.09 0.00 0.04 1.03 1.06 0.27
2.5 Pullup: 1.60 0.00 0.87 0.61 0.58 0.93
2.5 Low : 1.57 0.00 0.04 0.01 0.00 0.63
2.5 High : 1.54 0.00 0.04 1.35 1.37 0.77
3.3 Pullup: 1.12 0.00 0.87 0.75 0.72 1.07
3.3 Low : 1.10 0.00 0.04 0.01 0.00 0.68
3.3 High : 1.07 0.00 0.87 1.64 1.67 0.92
Please check CLK .
>>Erase chip lost!
Old 05-26-2015, 16:53   #58 (permalink)
Member: 108131
Thanks Meter: 21
Originally Posted by swechacnu View Post
Hi,
I given image below for how to sold wire with external power supply from gpg emmc jig and i9300 emmc connection.
BR,
Srinivas Reddy.
tried this solution, seem to work but getting this message.
eMMC ORC: C0FF8080 FF
eMMC CID: 15010056545530304DF1FC2435D26F
eMMC CSD: FF409C04C83D640FFFDB6FFFFE3901
ID check: 00010015
Product name: VTU00M
User partition size: 75F17E3E00 ( 483095M / 471.772G), 506562756096 Bytes
Boot partition size: 0x1EC0000 ( 30.7M )
RPMB partition size: 0x1960000 ( 25.3M )
ID check...OK!
>>Chip information acquisition in error, please modify the VCCQ value and then try again.
cant modify any of the values since they are all fixed.
what can i do please???
Old 05-26-2015, 16:55   #59 (permalink)
Member: 108131
Thanks Meter: 21
Originally Posted by Mashacellular View Post
Bro just change 3.3 from(gpg isp ) to mobile vcc 100% TESTED I9300 4 Device All 4 Successs
(no need vcc from gps isp)
Hi, tried your suggestion but it didn't work for me. i have read it worked for others. i guess i may have to get the new adaptor from my supplier.
thanks for your help nonetheless.
Old 08-28-2015, 08:38   #60 (permalink)
Member: 2228536
Sonork: wijaya
need help p3100 isp flashing
Read Info...
Device Ready...
Device Ready...OK!
ID check...
3.3 Pullup: 0.00 2.01 0.00 1.79 1.45 2.19
Power On : 2.88 1.76 2.48 1.34 0.00 1.61
Set Low : 2.88 1.76 2.48 0.03 0.04 1.17
Set High: 2.88 2.95 2.48 3.15 3.16 1.40
Work Voltage: 2.84 1.58 0.00 2.14 2.87 2.02
eMMC ORC: FFF2003F AF
eMMC CID: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
eMMC CSD: FFE1F3FFFFFFFFFFFFF413FFFFFFFF
ID check: FFFF00FF
Product name: ______
User partition size: 17DED2DFA00 ( 1564370M / 1527.705G), 1640361753088 Bytes
Boot partition size: 0x1980000 ( 25.5M )
RPMB partition size: 0xA40000 ( 10.2M )
ID check...OK!
what can i do....
Page generated in 0.40355 seconds with 7 queries
