02-21-2014, 11:37 | #1 (permalink) |
Product Supporter Join Date: Sep 2006 Location: Kerala-India Age: 46
Member: 351924 Status: Offline Thanks Meter: 12,469 | GPG eMMC Box Flashing,Imei Repair,Unlock Error,Solutions&Mannuls Here EFS Repair EFS REPAIR MUST USE NORMAL USB CABLE,MAKE SURE PHONE MUST A DOWNLOAD MODE DONT POST HERE THANKS ETC....... IF YOU LIKE MY POST USE "THANKS"BUTTON Last edited by SHIJILFONOTLY; 02-21-2014 at 11:44. |
The Following 28 Users Say Thank You to SHIJILFONOTLY For This Useful Post: |
02-21-2014, 11:42 | #2 (permalink) |
Member: 351924 Status: Offline Thanks Meter: 12,469 | IMEI Repair IMEI REPAIR MUST USE USB SERIAL PORT CABLE.NORMAL USB CABLE CANT WORK IT. WHEN USE NORMAL USB CABLE YOU SURELY GOT THIS ERROR |
The Following 9 Users Say Thank You to SHIJILFONOTLY For This Useful Post: |
02-21-2014, 11:55 | #3 (permalink) |
Member: 351924 Status: Offline Thanks Meter: 12,469 | FLASHING OR FIRMWARE UPDATES 1)SELECT MODEL NUMBER 2)PUT THE PHONE DOWNLOAD MODE 3)CONNECT USB CABLE 4)ARE YOU USING "tar.md5"(SINGLE FILE) 5)SELECT THIS FILE ON PDA AREA THEN FLASH IT Dont Killed Your Phone From Jellybean 4.3, it is not possible to downgrade the Android OS version Otherwise Your Phone Will Be DEAD Or Hang Samsung logo. |
The Following 8 Users Say Thank You to SHIJILFONOTLY For This Useful Post: |
02-21-2014, 12:00 | #4 (permalink) |
Member: 351924 Status: Offline Thanks Meter: 12,469 | WHILE USE THE GPG USB SERIAL PORT CABLE SO MANY USERS FACED THE TESTED MODE ERROR I HAVE THIS CABLE I CHECK THE CABLE WHERE IS THE PROBLEMS I WILL TRY TO CLEAR AND GIVE THE REPAIR DETAILS IN THIS CABLE |
The Following 2 Users Say Thank You to SHIJILFONOTLY For This Useful Post: |
02-22-2014, 01:51 | #5 (permalink) | |
Freak Poster Join Date: Mar 2008
Member: 722421 Status: Offline Thanks Meter: 6 | Quote:
Dear I have this problem I have I9300 ime null repair efs cabel usb ok ime 0044 Now but What is the solution Wait reply | |
The Following User Says Thank You to tera2030 For This Useful Post: |
02-23-2014, 08:58 | #8 (permalink) |
Crazy Poster Join Date: Apr 2012
Member: 1745778 Status: Offline Thanks Meter: 8 | Urt cbale driver here. FT232R USB UART driver - Download - 4shared - kob aobaob |
The Following User Says Thank You to etech pang For This Useful Post: |
02-25-2014, 16:07 | #10 (permalink) |
Cheater -Don't Deal with him- Join Date: Jul 2012 Age: 41
Member: 1791133 Status: Offline Thanks Meter: 89 | settings > about phone if baseband is unkown then you can't repair IMEI you need to flash correct firmware first then when baseband is restored you can fix imei. |
02-26-2014, 06:15 | #11 (permalink) | |||
Member: 351924 Status: Offline Thanks Meter: 12,469 | Quote:
you can use other com device then repair it Quote:
02-26-2014, 19:51 | #13 (permalink) |
Member: 1745778 Status: Offline Thanks Meter: 8 | Sir i do it. With direct connect to pc (laptop) box ok and i just test normal usb cable and rooting same devise full ok But conect urt cable coming this error. It dont ditect direct then download driver seprate named FT232R USB URT DRIVER FT232R USB UART driver - Download - 4shared - kob aobaob If This driver is not correct please give me original driver |
02-27-2014, 06:23 | #15 (permalink) | |
just reset efs but some time unknown base band is hardware this phone cant enter test mode but remmber our "GPG USB SERIAL PORT CABLE" have some problems at this time software also show the test mode failed,so you can use other com device repair the phone thats all | |
The Following User Says Thank You to SHIJILFONOTLY For This Useful Post: |
