Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > GPGeMMC
Old 02-21-2014, 11:37   #1 (permalink)
SHIJILFONOTLY's Avatar
Member: 351924
Thanks Meter: 12,469
GPG eMMC Box Flashing,Imei Repair,Unlock Error,Solutions&Mannuls Here
EFS Repair
EFS REPAIR MUST USE NORMAL USB CABLE,MAKE SURE PHONE MUST A DOWNLOAD MODE
DONT POST HERE THANKS ETC.......
IF YOU LIKE MY POST USE "THANKS"BUTTON
The Following 28 Users Say Thank You to SHIJILFONOTLY For This Useful Post:
Old 02-21-2014, 11:42   #2 (permalink)
Member: 351924
IMEI Repair
IMEI REPAIR MUST USE USB SERIAL PORT CABLE.NORMAL USB CABLE CANT WORK IT.
WHEN USE NORMAL USB CABLE YOU SURELY GOT THIS ERROR
The Following 9 Users Say Thank You to SHIJILFONOTLY For This Useful Post:
Old 02-21-2014, 11:55   #3 (permalink)
Member: 351924
FLASHING OR FIRMWARE UPDATES
1)SELECT MODEL NUMBER
2)PUT THE PHONE DOWNLOAD MODE
3)CONNECT USB CABLE
4)ARE YOU USING "tar.md5"(SINGLE FILE)
5)SELECT THIS FILE ON PDA AREA THEN FLASH IT
Dont Killed Your Phone
From Jellybean 4.3, it is not possible to downgrade the Android OS version Otherwise Your Phone Will Be DEAD Or Hang Samsung logo.
The Following 8 Users Say Thank You to SHIJILFONOTLY For This Useful Post:
Old 02-21-2014, 12:00   #4 (permalink)
Member: 351924
WHILE USE THE GPG USB SERIAL PORT CABLE SO MANY USERS FACED THE TESTED MODE ERROR
I HAVE THIS CABLE I CHECK THE CABLE WHERE IS THE PROBLEMS
I WILL TRY TO CLEAR AND GIVE THE REPAIR DETAILS IN THIS CABLE
The Following 2 Users Say Thank You to SHIJILFONOTLY For This Useful Post:
Old 02-22-2014, 01:51   #5 (permalink)
Member: 722421
Thanks Meter: 6
Dear
I have this problem
I have I9300
ime null
repair efs cabel usb ok
ime 0044
Now
but
What is the solution
Wait reply
The Following User Says Thank You to tera2030 For This Useful Post:
Old 02-22-2014, 06:15   #6 (permalink)
Member: 351924
oki do you have any other usb serial port box(so many samsung tool usb serial based)
also you use uart cable then try to rebuild
Old 02-23-2014, 01:18   #7 (permalink)
Member: 1769339
Sonork: 100.1627057
Thanks Meter: 13
Originally Posted by tera2030 View Post
Dear
I have this problem
I have I9300
ime null
ime 0044
Now
but
Wait reply
same problem here , its asking for a driver and i dont know where the driver locate in the setup , please help us
The Following User Says Thank You to high-tech For This Useful Post:
Old 02-23-2014, 08:58   #8 (permalink)
Crazy Poster
Member: 1745778
Thanks Meter: 8
Urt cbale driver here.
FT232R USB UART driver - Download - 4shared - kob aobaob
The Following User Says Thank You to etech pang For This Useful Post:
Old 02-25-2014, 12:33   #9 (permalink)
Crazy Poster
Member: 1745778
Thanks Meter: 8
I have same problem i9100 imei canot reipre feiled to entere testmode
Old 02-25-2014, 16:07   #10 (permalink)
Cheater -Don't Deal with him-
Member: 1791133
Thanks Meter: 89
settings > about phone
if baseband is unkown then you can't repair IMEI you need to flash correct firmware first then when baseband is restored you can fix imei.
Old 02-26-2014, 06:15   #11 (permalink)
Member: 351924
brothers problems with comport cable
you can use other com device then repair it
entere testmode
Old 02-26-2014, 15:34   #12 (permalink)
Member: 1791133
Thanks Meter: 89
even if port is correct you can't fix IMEI if baseband is unkown.
Old 02-26-2014, 19:51   #13 (permalink)
Crazy Poster
Member: 1745778
Thanks Meter: 8
Sir i do it. With direct connect to pc (laptop) box ok and i just test normal usb cable and rooting same devise full ok
But conect urt cable coming this error. It dont ditect direct then download driver seprate named FT232R USB URT DRIVER
If This driver is not correct please give me original driver
Old 02-26-2014, 21:31   #14 (permalink)
LuisinhoCell's Avatar
Member: 264903
Sonork: 1584531
Thanks Meter: 3,350
http://forum.gsmhosting.com/vbb/f899.../#post10126361
Old 02-27-2014, 06:23   #15 (permalink)
Member: 351924
if unknown base band is software defect easy repair this
just reset efs
but some time unknown base band is hardware
this phone cant enter test mode
but remmber our "GPG USB SERIAL PORT CABLE" have some problems at this time software also show the test mode failed,so you can use other com device repair the phone
thats all
The Following User Says Thank You to SHIJILFONOTLY For This Useful Post:
Page generated in 0.28250 seconds with 8 queries
