Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > GPGeMMC
Old 02-27-2014, 23:18   #16 (permalink)
adnan_taeki's Avatar
Member: 417778
Sonork: 100.1603326
Thanks Meter: 114
Originally Posted by SHIJILFONOTLY View Post
WHILE USE THE GPG USB SERIAL PORT CABLE SO MANY USERS FACED THE TESTED MODE ERROR
I HAVE THIS CABLE I CHECK THE CABLE WHERE IS THE PROBLEMS
I WILL TRY TO CLEAR AND GIVE THE REPAIR DETAILS IN THIS CABLE
Do you found the problem .... ?? if you found it plz share how to repair this problem ..
Regarts.
Old 03-01-2014, 19:29   #17 (permalink)
Member: 2125597
Thanks Meter: 2
This UART cable not work
Sent from my Nexus 5 using Tapatalk
Old 03-03-2014, 05:26   #18 (permalink)
SHIJILFONOTLY's Avatar
Member: 351924
Thanks Meter: 12,430
yes some cable have problems
you can use other com based box then use it
Old 07-19-2014, 07:57   #19 (permalink)
Member: 758137
cant see the pictures...
Old 08-29-2014, 16:30   #20 (permalink)
balaji_mobile's Avatar
Member: 1883460
Sonork: 100.1663304
Thanks Meter: 24
Angry karbonn a15 isp flashing problem..
eMMC CID: 0000000000000000,bad code!
>>ID check lost!
please help me how to do,flash karbonn A15
logs:
  Read Info...
   Device Ready...
   Device Ready...OK!
  ID check...
  Level (V):	VCC    V18    VCCQ    D0    CMD    CLK
  1.8 Pullup:	0.00    0.00     0.00    0.33    0.35    0.02
  1.8 Low   :	0.00    0.00     0.00    0.00    0.00    0.00
  1.8 High  :	0.00    0.00     0.00    1.39    1.41    1.40
  2.5 Pullup:	0.00    0.00     0.00    0.63    0.69    0.05
  2.5 Low   :	0.00    0.00     0.00    0.00    0.00    0.00
  2.5 High  :	0.00    0.00     0.00    1.65    1.67    1.69
  3.3 Pullup:	0.00    0.00     0.00    0.83    0.80    0.11
  3.3 Low   :	0.00    0.00     0.00    0.00    0.00    0.00
  3.3 High  :	0.00    0.00     0.00    2.03    2.06    2.11
  Power On  :	3.09    1.76     2.48    0.37    0.37    0.01
  Set   Low :	3.08    1.76     2.48    0.01    0.01    0.00
  Set   High:	3.07    1.76     2.48    1.65    1.67    1.69
  Work Voltage:	3.07    1.76     2.48    0.03    1.43    0.11
  eMMC ORC: 00000000     F6
  ID check lost!
  Read Info...
   Device Ready...
   Device Ready...OK!
  ID check...
  1.8 Pullup:	0.00    0.00     0.00    0.35    0.36    0.01
  1.8 High  :	0.00    0.00     0.00    1.36    1.38    1.37
  2.5 Pullup:	0.00    0.00     0.00    0.64    0.69    0.05
  2.5 High  :	0.00    0.00     0.00    1.65    1.66    1.69
  3.3 Pullup:	0.00    0.00     0.00    0.82    0.79    0.10
  3.3 Low   :	0.00    0.00     0.00    0.01    0.00    0.00
  3.3 High  :	0.00    0.00     0.00    1.97    2.00    2.04
  Power On  :	3.09    1.76     2.48    0.49    0.49    0.00
  Set   Low :	3.09    1.76     2.48    0.01    0.00    0.01
  Set   High:	3.07    1.76     2.48    1.65    1.66    1.69
  Work Voltage:	3.08    1.76     2.48    0.03    1.40    0.09
  eMMC ORC: 00000000     A6
>>ID check lost!
help me!
Old 08-30-2014, 12:53   #21 (permalink)
Member: 1883460
Sonork: 100.1663304
Thanks Meter: 24
>>ID check lost!
logs:
  Read Info...
   Device Ready...
   Device Ready...OK!
  ID check...
  ID check lost!
  Read Info...
   Device Ready...
   Device Ready...OK!
  ID check...
>>ID check lost!
help me!
my problem solved check here:
GPGEMMC Box Successfully Unlocked / Repaired / Flashed Phones !!!
The Following User Says Thank You to balaji_mobile For This Useful Post:
Old 01-08-2015, 10:09   #22 (permalink)
Member: 2289871
i have n7100 imei repair failed,, what is problem sir ?
Waiting to enter unlock IMEI Repair mode*
Enter unlock IMEI Repair mode successful.
Phone Name:GT-N7000
Phone version:N7000DXLSE
Old IMEI:corrupted!!
WIFI ID number:50CCF8B1FCEB
Serial number:8?*b
Fail to set original serial number!
Fail to run Unlock IMEI Repair!
thank's
Old 01-12-2015, 12:15   #23 (permalink)
Member: 2326240
Please how can the connection be made, is it plugging the ftdi cable to the box or to the computer directly.
Old 08-30-2015, 17:26   #24 (permalink)
Member: 2228536
Sonork: wijaya
gpg emmc jtag p3100 eror need solution..
Connecting...
SN:0000010.....
Get License data...
Verify Liecnse data...
Version:V3.2
Device Ready...OK!
Writing in progress(make sure to press Power On key)...
CPU ID: 4C0932BD.
Don't support this CPU, or connection error please check connection
>>Time: 1 s
Old 09-01-2015, 03:10   #25 (permalink)
Dipendra Pathak's Avatar
Member: 747989
Sonork: 100.1593052
Thanks Meter: 7,358
Phone Name:GT-N7000
Serial number:8?*b
thank's
Seems your original IMEI corrupted.
You have to go Android Tab then, Repair Tab
Now choose IMEI, Com port that mobile is using current time and hit "Unlock IMEI Repair" and wait a while. Done.
Yes you can connect fidi cable directly to computer. It makes COM Port.
Note: You need to install fidi cable driver so that it works.
Connecting...
SN:0000010.....
Get License data...
Version:V3.2
Device Ready...OK!
CPU ID: 4C0932BD.
>>Time: 1 s
Hi, this is connection error. Check the soldered wires etc.
Dipendra Pathak
Page generated in 0.36473 seconds with 7 queries
