09-30-2014, 05:46 | #9 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Kamalia, Pakistan. Age: 38
Member: 151871 Status: Offline Thanks Meter: 71,421 | Hi, 1st of all check. is your Solder is fine ? 2ndly Check 1st Full erase your phone and then try to write ? make sure you use small wires Br Faisal_Computer |
09-30-2014, 06:47 | #11 (permalink) | |
No Life Poster Join Date: May 2009 Location: mumbai wadala
Member: 1037372 Status: Offline Thanks Meter: 557 | Quote:
read ok http://s25.postimg.org/pnn5gze27/untitled_read.png all model same problem erase bad block pleas help faisal bro | |
09-30-2014, 09:01 | #12 (permalink) |
Product Manager Join Date: Apr 2008 Location: Whitehole throught Blackhole!
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,621 | brother, some JTAG models you need to continue holding power button while doing operation. Please follow the method too and let us know. BR Dipendra Pathak |
The Following User Says Thank You to Dipendra Pathak For This Useful Post: |
09-30-2014, 10:07 | #14 (permalink) |
Member: 1037372 Status: Offline Thanks Meter: 557 | Erase operation(Make sure to press Power on key)... 29/09/2014 8:05:20 PM >>CPU ID: 0F6F9207. 29/09/2014 8:05:24 PM >>Flash ID: 00EC0040 (256M). 29/09/2014 8:05:24 PM >>Release Power on key now and operation continues... 29/09/2014 8:05:37 PM >>Erase succeed! 29/09/2014 8:05:37 PM >>Bad-block address: 0xD5F61E00(3423ΥΧ) [95] 29/09/2014 8:05:37 PM >>Bad-block address: 0x59D68700(1437ΥΧ) [D1] 29/09/2014 8:05:37 PM >>Bad-block address: 0x59832E00(1432ΥΧ) [B5] 29/09/2014 8:05:37 PM >>Bad-block address: 0x95648800(2390ΥΧ) [79] 29/09/2014 8:05:37 PM >>Bad-block address: 0xBF02BA00(3056ΥΧ) [13] 29/09/2014 8:05:37 PM >>Bad-block address: 0x5634AE00(1379ΥΧ) [87] 29/09/2014 8:05:37 PM >>Bad-block address: 0xC166AC00(3094ΥΧ) [BA] 29/09/2014 8:05:37 PM >>Bad-block address: 0x971E4F00(2417ΥΧ) [A0] 29/09/2014 8:05:37 PM >>Bad-block address: 0x0995DE00( 153ΥΧ) [4E] 29/09/2014 8:05:37 PM >>Bad-block address: 0x42697B00(1062ΥΧ) |
09-30-2014, 12:26 | #15 (permalink) | |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,621 | Seems device (mobile) needs more power. Brother, Use the power supply to the device and do according to the picture and instructions: image ru Quote:
Also let us know.........how long wire you are using to connect to the device. More less, more success report . Good Luck! BR Dipendra Pathak | |
