Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > GPGeMMC
Old 07-12-2014, 20:41   #16 (permalink)
Member: 2121008
i have same error help plzzzzzzzzzzzzzzzz
Old 07-13-2014, 04:03   #17 (permalink)
Dipendra Pathak's Avatar
Member: 747989
Sonork: 100.1593052
Thanks Meter: 8,621
Post your GPG EMMC serial Kay and connect with me.
Dipendra Pathak
Old 09-16-2014, 21:11   #18 (permalink)
Member: 89550
Thanks Meter: 8
gpg emmc box not open
same problem
my serial :00000101542
please help me
Old 09-18-2014, 07:42   #19 (permalink)
Member: 747989
Sonork: 100.1593052
Thanks Meter: 8,621
Post the error in screen short of GPG EMMC Connecting windows (Picture format) brother.
Dipendra Pathak
Old 11-02-2014, 17:16   #20 (permalink)
Crazy Poster
Member: 983242
Sonork: 100.1660072:om
Thanks Meter: 3
please help me too i got same problem.
my box S/N 00000101503
Old 11-03-2014, 05:15   #21 (permalink)
Crazy Poster
Member: 983242
Thanks Meter: 3
(gpg emmc please connect box and run it again
help me sir. how to fix this error
driver also ok i used window 7
11/2/2014 1:40:23 AM >>Connecting...
11/2/2014 1:40:41 AM >>No box found, System isn't on-line
11/2/2014 1:40:41 AM >>------------------------------------------------------
11/2/2014 1:42:24 AM >>The device has been disconnected.
11/2/2014 1:42:24 AM >>------------------------------------------------------
11/2/2014 1:42:26 AM >>Connecting...
11/2/2014 1:42:33 AM >>Connecting...
11/2/2014 1:42:44 AM >>No box found, System isn't on-line
11/2/2014 1:42:44 AM >>------------------------------------------------------
11/2/2014 1:42:51 AM >>No box found, System isn't on-line
11/2/2014 1:42:51 AM >>------------------------------------------------------
11/2/2014 1:53:55 AM >>The device has been disconnected.
11/2/2014 1:53:55 AM >>------------------------------------------------------
11/2/2014 10:37:03 AM >>Connecting...
11/2/2014 10:37:09 AM >>No box found, System isn't on-line
11/2/2014 10:37:09 AM >>------------------------------------------------------
11/2/2014 8:54:30 AM >>Connecting...
11/2/2014 8:54:49 AM >>No box found, System isn't on-line
11/2/2014 8:54:49 AM >>------------------------------------------------------
11/2/2014 8:55:11 AM >>Connecting...
11/2/2014 8:55:30 AM >>No box found, System isn't on-line
11/2/2014 8:55:30 AM >>------------------------------------------------------
11/3/2014 12:35:54 AM >>Connecting...
11/3/2014 12:36:01 AM >>No box found, System isn't on-line
11/3/2014 12:36:01 AM >>------------------------------------------------------
11/3/2014 12:36:55 AM >>Connecting...
11/3/2014 12:37:14 AM >>No box found, System isn't on-line
11/3/2014 12:37:14 AM >>------------------------------------------------------
11/3/2014 12:37:35 AM >>Connecting...
11/3/2014 12:37:53 AM >>No box found, System isn't on-line
11/3/2014 12:37:53 AM >>------------------------------------------------------
Old 11-05-2014, 20:09   #22 (permalink)
Member: 1134978
Thanks Meter: 3
same error "please connect box and run it again"
hi.
i have the same error
my box arrived, it work perfectly for two month, now not work
my box serial is 00000101028
can you help me ??
Old 03-22-2015, 11:47   #23 (permalink)
Member: 772637
Thanks Meter: 10
this my serial i have same problem 00000101112
can u help me fix the problem ?thanks
Old 03-24-2015, 11:50   #24 (permalink)
Member: 201359
Sonork: 100.1607870
Thanks Meter: 128
this my serial i have same problem :SN:00000100304
some times stuck at GET LICENE
Old 06-09-2015, 17:26   #25 (permalink)
Member: 2203827
Dear Dipendra Pathak please wait for an answer
Old 07-02-2015, 11:42   #26 (permalink)
Member: 747989
Sonork: 100.1593052
Thanks Meter: 8,621
Hi all brothers,
* if you are running this box first time, then, you have to let us know so that you get the license from our server.
* If you are old user who is using 32 bit windows, then, might be problem of driver or might be problem of registry. In case of registry problem.
1. Go to RUN
2. Type "regedit"
3. go to "Hey_current_users"
4. then "Software"
5. "GPG"
6. Right click "GPGeMMC"
7. and delete it.
8. Now connect "GPG EMMC Box" with good internet connection.
9. Problem solved.
* BUT, if you are windows 64 bit users, we are not supported yet. Please install 32 bit windows and run the software.
* Try other computer if you have problems and still not solve.
* Check your internet (Ask your Internet Provider)
* Disable Antivirus when you are running the GPG EMMC Software.
* Add Exception to GPG EMMC software in your antivirus software.
* Change A to B Cable if needed
* If you are facing problem, please feel free to connect your reseller.
Note: Please post detail information about your box, when you get such problem? Are you using this box first time? What error gives by the software? The main thing is that where is the screen short of GPG EMMC Connecting windows ?
Thank you for you understanding. Hope all clear.
Dipendra Pathak
The Following User Says Thank You to Dipendra Pathak For This Useful Post:
Old 07-02-2015, 11:55   #27 (permalink)
Member: 2203827
all of the above described has been done but there is no result , I bought a box at gsmserver prishol boxing I installed software program started 3 times longer writes pototom reconnect and start boxing again win7 32bit
Old 07-02-2015, 12:26   #28 (permalink)
Member: 2203827
tried on 3 PCs boxing did not register set and it worked 2 days now writes again to reconnect and start doing all the above result is not what to do next
Old 07-02-2015, 12:34   #29 (permalink)
Member: 2203827
Originally Posted by Dipendra Pathak View Post
Hi all brothers,
1. Go to RUN
2. Type "regedit"
4. then "Software"
5. "GPG"
7. and delete it.
9. Problem solved.
Dipendra Pathak
here is my serial number 000102172 what to do next
Old 07-06-2015, 04:59   #30 (permalink)
Member: 857426
Thanks Meter: 4
i have same problem plz help
Page generated in 0.20781 seconds with 8 queries
