Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > GPGeMMC
Old 07-07-2015, 06:39   #31 (permalink)
Member: 79966
For who are facing error "please connect box and run it again" after check all the driver are installed correctly, antivirus is disabled, please check your system control panel -> Regional and Language Option -> Advanced "Language for Non-Unicode Programs" is selected to ENGLISH
this solve my problem.
Old 07-28-2015, 17:29   #32 (permalink)
Member: 976188
Thanks Meter: 6
I have the problem, This my image my computer, any solution?
My serial box is 000-102-464
Old 07-29-2015, 16:33   #33 (permalink)
Member: 2436276
Help me please. The same problem!!!!!!!!!!
000-102-352
Old 07-30-2015, 22:00   #34 (permalink)
Member: 976188
Thanks Meter: 6
Anu Solution?
[IMG][/QUOTE][/IMG]
Old 07-31-2015, 08:21   #35 (permalink)
Member: 1036725
Thanks Meter: 31
GPGeMMC_v1.35
The Following User Says Thank You to shurrass For This Useful Post:
Old 07-31-2015, 08:32   #36 (permalink)
Dipendra Pathak's Avatar
Member: 747989
Sonork: 100.1593052
Thanks Meter: 7,358
Please check with new version 1.35
GPGeMMC ver 1.35 Solved Error Connecting to Server & New EMMC Ic Supported !!
Dipendra Pathak
The Following User Says Thank You to Dipendra Pathak For This Useful Post:
Old 08-01-2015, 02:44   #37 (permalink)
Member: 976188
Thanks Meter: 6
Dipendra Pathak
Tank you very much. I solved with the update.
The Following User Says Thank You to alangersain For This Useful Post:
Old 10-21-2015, 07:42   #38 (permalink)
Member: 638919
Thanks Meter: 17
please help me,i also facing this problem
Old 12-14-2015, 09:19   #39 (permalink)
Member: 2185941
Thanks Meter: 5
Помоги мне, пожалуйста. Та же проблема !!!
plese connect box and run it again
000-102-172
Old 03-05-2016, 06:23   #40 (permalink)
Member: 857426
Thanks Meter: 4
same problem sir plz connect box and run it agin box serial no. is 000-102-275
Old 03-05-2016, 08:51   #41 (permalink)
Member: 2385015
Thanks Meter: 876
Hello,
Kindly post here screen short of error.
Br,
GPGTeam
Old 11-03-2016, 13:13   #42 (permalink)
Member: 2638659
Sonork: www.sonork.com
same error "please connect box and run it again"
this my serial i have same problem :SN:00000100226
can u help me fix the problem ?thanks
some times stuck at GET LICENE
3.11.2016 14:16:28 >>Connecting...
3.11.2016 14:16:30 >>SN:00000100226
3.11.2016 14:16:31 >>Get License data...
3.11.2016 14:16:31 >>Connect server...
3.11.2016 14:16:33 >>BOX_100226: Invalid device information. error: 840
Old 11-05-2016, 06:04   #43 (permalink)
Member: 747989
Sonork: 100.1593052
Thanks Meter: 7,358
000-102-172
1.First, Download Latest version from the support:
GPGeMMC_v1.35
2. second, disable your antivirus and windows securities and put GPG EMMC software to exception.
3. Third, edit your registry setting:
gpg emmc please connect box and run it again
4. Fourth, try other computers
5. Fifth, change your internet service provider or try with other internet service providers.
6. Sixth, Do not use 64 bit winder and higher than windows 8
7. Seventh, If you are first time using box, then, provide us your box serial number so that we will help your box activate through our server and you will get license of the box
Good Luck!!!
Dipendra Pathak
(Inside GPG Box and chips)
Old 03-02-2017, 22:33   #44 (permalink)
Member: 201359
Sonork: 100.1607870
Thanks Meter: 124
Always same pb cant get licence
Old 03-10-2017, 23:02   #45 (permalink)
Member: 201359
Sonork: 100.1607870
Thanks Meter: 124
Ho want this box just for 70$
Page generated in 0.36199 seconds with 7 queries
