Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > GPGeMMC
Old 07-30-2014, 15:09   #1 (permalink)
Member: 2231541
Question GPGEMMC having issues and would like help
I have a GPG EMMC and i am unable to get it working is it faulty?
I have done a very fresh install with windows 7 and latest version of 1.26
Drivers all installed but I am unable to read anything from the phone (i9300) via the USB cable.
Connecting......
SN:0000000100***
Getting License data...
Verify License data...
Version:V3.1
Device Ready... OK!
>>>Scanning devicei
Failed to enter test mode!
>>Fail to scan device!
Coms port is COM2
Please advise.
Old 07-31-2014, 04:24   #2 (permalink)
Dipendra Pathak's Avatar
Member: 747989
Sonork: 100.1593052
Thanks Meter: 8,623
Jtag and EMMC uses other types of Connection ie. soldering with GPG EMMC Power adapter to Mobile Board (More than 3 soldering on the board of the device) not USB so Think twice before write brother.
And post screen shorts if you want to get fast answer.
Dipendra Pathak
Old 07-31-2014, 11:19   #3 (permalink)
Member: 2231541
Im using a usb cable as I wish to correct the imei as its a new motherboard.
So does this box need to be jtagged to write the imei?!
Old 07-31-2014, 14:06   #4 (permalink)
Member: 747989
Sonork: 100.1593052
Thanks Meter: 8,623
Did you tell that you want to repair imei in first post. How do I know your internal feeling? Just wasting your time and mine too not telling details. I Need Screen Short if you need real time answer.
How to Repair IMEI with GPG EMEC Box?
1. Open GPG EMEC software
2. Click on “Android Tab”
3. Now, choose “Repair Tool”
4. Choose the Phone Model that you want to repair from Drop-Down List
5. Put the phone in Normal Mode and connect with GPG Fidi Cable (Long Cable that comes with GPG EMEC Box)
6. Now Fidi cable makes COM Port for this Device
7. Connect the Device with this PORT
8. Fill the Valid IMEI number in the “IMEI” box
9. Click on “IMEI and Repair”
10. When you get information “IMEI Repair Should be used only to repair device and should be used for experimental used only. IMEI change is illegal and we would not be held responsible if any abuse. Do you want to continue?” Click on “YES”
11. Wait until the operation is completed.
12. Done.
Dipendra Pathak
Old 07-31-2014, 15:33   #5 (permalink)
Member: 2231541
the screen shot is going to show what i typed. the cable is not talking with the phone
Old 08-01-2014, 02:51   #6 (permalink)
Member: 747989
Sonork: 100.1593052
Thanks Meter: 8,623
Use the Cable you GOT with the GPG EMMC box. This Cable is about 1 meter long. On the cable you will see a plastic red box attached and the cable color is white that is called GPG FIDI CABLE. This cable makes a special port to repair IMEI of your devices. You must need to choose that PORT to repair IMEI.
You must need to install the driver for this Cable. You will find the driver link as given below:
Driver for Uart Cable
FT232R USB UART driver - Download - 4shared - kob aobaob.
Good Luck
Dipendra Pathak
Old 08-01-2014, 10:41   #7 (permalink)
Member: 2231541
same problem. what now?
Old 08-02-2014, 10:55   #8 (permalink)
Member: 2231541
Thumbs down Need help and you close thread! where is support?
You closed my thread. WHY?
1. You ask for screen shots which I'm not allowed to post or any one for that matter because have to have 10 posts!
2. You keep saying post screen shots but someone with 10 posts can't.
3. I just want my device working what I brought it's got your name on it and would like some help!
So I have a GPGEMMC unit with I brought and can't get working as it seems you don't provided drivers for the cable then send people off to a website which infects machine with malware and pop up adverts.
So far not impressed with GPG support!
So once again I request support.
Please assist and don't keep asking for screen shots when the rules don't allow me to post them.
Old 08-02-2014, 14:25   #9 (permalink)
Faisal_Computer's Avatar
Member: 151871
Thanks Meter: 71,421
Hello,
you have to tell us that you are not allowed to post link cause of you don't have 10 post.... ( we didn't checked you post count sorry for that )
2ndly you can post image link without putting Http:// so like this forum don't know you post link or some comment
so post image so we can understand where is the problem and solve your issue asap
Faisal_Computer
Old 08-02-2014, 18:17   #10 (permalink)
Member: 2231541
It wont let me as it knows I am posting a link
tinypic (dot) com*r*16or4z*8
Replace the stars with slashes
Old 08-02-2014, 21:05   #11 (permalink)
Member: 2231541
What time GMT are you around as this is dragging on and really need this working asap
Old 08-03-2014, 05:44   #12 (permalink)
Member: 151871
Hello,
We mostly work +5 GMT. Morning 10 AM to 8 PM.....
you have problem with FDTI Cable right ?
can you please tell me what operation you are trying to do with it ?
did you select it's correct comport in GPGeMMC box software ?
what Windows 7 you use ? 32 bit right ?
Please write in details
Faisal_Computer
Old 08-03-2014, 16:05   #13 (permalink)
Member: 2231541
Thank for help so far Faisal.
Fresh install of windows 7 32bit
Latest version of gpg software.
Downloaded drivers which someone posred in other thread. For the USB cable .
I gave link to screen shot of desktop showing device manager and gpg.
I would like to repair imei on samsung 9300 and I now have a 9505 which I would like to unlock
I select scan ports. Select port 4 as this is the USB cable.
Fill in boxes and press start or whatever button is labeled.
It jumps to 10% and then comes back with error. Again can see this in screen shot link posted above.
Old 08-04-2014, 05:09   #14 (permalink)
Member: 747989
Sonork: 100.1593052
Thanks Meter: 8,623
IMEI Repari with FIDI Cable already. I am sure you are killing your time without posting or sending screen shorts. May be you think you are making fool us
Post your screen short over this link:
Postimage.org - free image hosting / image upload
or send to my Yahoo Messenger.
[email protected]
After that I will check it from Team Viewer. Hope you understand.
Dipendra Pathak
Old 08-04-2014, 05:20   #15 (permalink)
Member: 2231541
You are clearly not reading my posts. I have provided screen shots. But as I'm not allowed because of 10 post rule I have broken it down.
Please take time to read what people put.
Again here are screen shots.
I did have another but you deleted that post and closed the thread now you have hijacked my thread and m joined it to this. When a helpful person called Faisal was providing assistance.
I guess one my post and ill be able to post pictures
Page generated in 0.24883 seconds with 8 queries
