07-30-2014, 15:09 | #1 (permalink) |
Junior Member Join Date: Jul 2014
Member: 2231541 Status: Offline Thanks Meter: 0 | GPGEMMC having issues and would like help I have done a very fresh install with windows 7 and latest version of 1.26 Drivers all installed but I am unable to read anything from the phone (i9300) via the USB cable. Connecting...... SN:0000000100*** Getting License data... Verify License data... Version:V3.1 Device Ready... OK! >>>Scanning devicei Failed to enter test mode! >>Fail to scan device! Coms port is COM2 Please advise. |
07-31-2014, 04:24 | #2 (permalink) |
Product Manager Join Date: Apr 2008 Location: Whitehole throught Blackhole!
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,623 | Jtag and EMMC uses other types of Connection ie. soldering with GPG EMMC Power adapter to Mobile Board (More than 3 soldering on the board of the device) not USB so Think twice before write brother. And post screen shorts if you want to get fast answer. BR Dipendra Pathak Last edited by Dipendra Pathak; 07-31-2014 at 04:45. |
07-31-2014, 14:06 | #4 (permalink) | |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,623 | Quote:
Did you tell that you want to repair imei in first post. How do I know your internal feeling? Just wasting your time and mine too not telling details. I Need Screen Short if you need real time answer. How to Repair IMEI with GPG EMEC Box? 1. Open GPG EMEC software 2. Click on “Android Tab” 3. Now, choose “Repair Tool” 4. Choose the Phone Model that you want to repair from Drop-Down List 5. Put the phone in Normal Mode and connect with GPG Fidi Cable (Long Cable that comes with GPG EMEC Box) 6. Now Fidi cable makes COM Port for this Device 7. Connect the Device with this PORT 8. Fill the Valid IMEI number in the “IMEI” box 9. Click on “IMEI and Repair” 10. When you get information “IMEI Repair Should be used only to repair device and should be used for experimental used only. IMEI change is illegal and we would not be held responsible if any abuse. Do you want to continue?” Click on “YES” 11. Wait until the operation is completed. 12. Done. BR Dipendra Pathak | |
08-01-2014, 02:51 | #6 (permalink) | |
You must need to install the driver for this Cable. You will find the driver link as given below: Driver for Uart Cable FT232R USB UART driver - Download - 4shared - kob aobaob. Good Luck BR Dipendra Pathak | |
08-02-2014, 10:55 | #8 (permalink) |
Member: 2231541 Status: Offline Thanks Meter: 0 | Need help and you close thread! where is support? You closed my thread. WHY? 1. You ask for screen shots which I'm not allowed to post or any one for that matter because have to have 10 posts! 2. You keep saying post screen shots but someone with 10 posts can't. 3. I just want my device working what I brought it's got your name on it and would like some help! So I have a GPGEMMC unit with I brought and can't get working as it seems you don't provided drivers for the cable then send people off to a website which infects machine with malware and pop up adverts. So far not impressed with GPG support! So once again I request support. Please assist and don't keep asking for screen shots when the rules don't allow me to post them. |
08-02-2014, 14:25 | #9 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Kamalia, Pakistan. Age: 38
Member: 151871 Status: Offline Thanks Meter: 71,421 | Hello, you have to tell us that you are not allowed to post link cause of you don't have 10 post.... ( we didn't checked you post count sorry for that ) 2ndly you can post image link without putting Http:// so like this forum don't know you post link or some comment so post image so we can understand where is the problem and solve your issue asap Br Faisal_Computer |
08-03-2014, 05:44 | #12 (permalink) |
Member: 151871 Status: Offline Thanks Meter: 71,421 | Hello, We mostly work +5 GMT. Morning 10 AM to 8 PM..... you have problem with FDTI Cable right ? can you please tell me what operation you are trying to do with it ? did you select it's correct comport in GPGeMMC box software ? what Windows 7 you use ? 32 bit right ? Please write in details Br Faisal_Computer |
08-03-2014, 16:05 | #13 (permalink) |
Member: 2231541 Status: Offline Thanks Meter: 0 | Thank for help so far Faisal. Fresh install of windows 7 32bit Latest version of gpg software. Downloaded drivers which someone posred in other thread. For the USB cable . I gave link to screen shot of desktop showing device manager and gpg. I would like to repair imei on samsung 9300 and I now have a 9505 which I would like to unlock I select scan ports. Select port 4 as this is the USB cable. Fill in boxes and press start or whatever button is labeled. It jumps to 10% and then comes back with error. Again can see this in screen shot link posted above. |
08-04-2014, 05:09 | #14 (permalink) | |
Post your screen short over this link: Postimage.org - free image hosting / image upload or send to my Yahoo Messenger. [email protected] After that I will check it from Team Viewer. Hope you understand. BR Dipendra Pathak | |
08-04-2014, 05:20 | #15 (permalink) |
Member: 2231541 Status: Offline Thanks Meter: 0 | You are clearly not reading my posts. I have provided screen shots. But as I'm not allowed because of 10 post rule I have broken it down. Please take time to read what people put. Again here are screen shots. tinypic (dot) com*r*16or4z*8 I did have another but you deleted that post and closed the thread now you have hijacked my thread and m joined it to this. When a helpful person called Faisal was providing assistance. I guess one my post and ill be able to post pictures |
