02-03-2014, 19:10 | #1 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Saudi Arabia Age: 45
Member: 417778 Status: Offline Sonork: 100.1603326 Thanks Meter: 116 | How to remove Samsung ID SM-N900 [Solved] How to Remove Samsing SM-N900 Samsung iD and which one is the special Cable http://forum.gsmhosting.com/vbb/f899...6/#post9982591 Regards, |
02-03-2014, 20:03 | #2 (permalink) |
Member: 417778 Status: Offline Sonork: 100.1603326 Thanks Meter: 116 | hello , i am following this method About Android ( Samsung ) ID Remove Android ( Samsung ) ID Id remove is for Removing Pattern lock, Pin lock etc... You have to use Special GPGeMMC IMEI Repair Special Cable for that which comes with GPGeMMC box. Connect GPGeMMC Special cable to pc and install drivers, Go to device manager and see what port it's make. now go to Tool, Select Correct model and correct port of that cable, connect cable to phone, Phone must be in powered on condition. insert cable and click on "Remove Samsung ID lock" wait software for finish. keep in mind At the same time it will format the phone. To use at your own Risk. Supported models : GALAXY Note 3 SM-N900、I9500、N7100、I9300... More coming soon Regards, |
02-04-2014, 10:40 | #7 (permalink) | |
Member: 417778 Status: Offline Sonork: 100.1603326 Thanks Meter: 116 | Quote:
but i am trying the process the support team mentioned in the post http://forum.gsmhosting.com/vbb/f899...6/#post9982591 but i will try after root and let you know the result , Tanks Regards | |
02-04-2014, 11:28 | #8 (permalink) |
Banned Join Date: Apr 2008
Member: 762819 Status: Offline Thanks Meter: 232 | Dear try this solution, hope it works. Actually it is for n9005, but u can try it on ur phone. Goto accessibility option which is available on the first screen where you select language Goto Text to speech option and then from the settings goto Install voice data and try to download any language It will ask you to enter samsung account details,Enter your own samsung account details Once the download is complete,go back to screen where it was showing abnormal factory reset adn then enter your samsung account It will go through |
02-04-2014, 14:25 | #9 (permalink) | |
Same Error Waiting to enter unlock IMEI Repair mode... Fail to enter test mode! >>Fail to clear account Lock! Regards | |
02-05-2014, 16:17 | #10 (permalink) |
Member: 417778 Status: Offline Sonork: 100.1603326 Thanks Meter: 116 | hello , if does not have solution for this mobile please dont write in you post that the device can do this ........... if GPGeMMC can bypass the Samsung id then i am doing the process written int this post i am doing word by word according this post posted by Faisal_Computers here is the link http://forum.gsmhosting.com/vbb/f899...6/#post9982591 and also told me WBGSM to root this mobile and i did root now the mobile ie rooted but the same action ....Same error before root and after root. and Still no answer by Support Team and i am still waiting about solution or advice. so i request to support team reply as soon as possible so that i can repair my mobile . Regards, |
02-06-2014, 15:57 | #11 (permalink) | |
