02-26-2015, 17:17 | #1 (permalink) |
No Life Poster Join Date: Dec 2011
Member: 1704666 Status: Offline Sonork: 100.1652565 Thanks Meter: 157 | i9100 how to solved this problem Flash2 ID: 00150001, Flash Size: 0000080000 (512K) Release Power on key now and operation continues... Phone doesn't respond for a long time,please reconnect! Time: 19 s Writing in progress(make sure to press Power On key)... CPU ID: 7704A04B. Flash1 ID: 00150001, Flash Size: 03AB400000 (15028M/14.68G) Flash2 ID: 00150001, Flash Size: 0000080000 (512K) Release Power on key now and operation continues... Phone doesn't respond for a long time,please reconnect! Time: 20 s Read operation(Make sure to press Power on key)... CPU ID: 7704A04B. Flash1 ID: 00150001, Flash Size: 03AB400000 (15028M/14.68G) Flash2 ID: 00150001, Flash Size: 0000080000 (512K) Release Power on key now and operation continues... Phone doesn't respond for a long time,please reconnect! Time: 25 s Writing in progress(make sure to press Power On key)... CPU ID: 7704A04B. Flash1 ID: 00150001, Flash Size: 03AB400000 (15028M/14.68G) Flash2 ID: 00150001, Flash Size: 0000080000 (512K) Release Power on key now and operation continues... Phone doesn't respond for a long time,please reconnect! >>Time: 21 s plz help |
02-27-2015, 06:39 | #2 (permalink) |
Product Manager Join Date: Apr 2008 Location: Whitehole throught Blackhole!
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,621 | What is the status of device when you get it in hand? if this is not hardware problem then use COM Port 69 as seen screen short of GPG EMMC Box (That you have posted above). Check the success report and also check the manual from permalink 106 to 112 over this link: http://forum.gsmhosting.com/vbb/f899...53/index8.html BR Dipendra Pathak |
02-27-2015, 08:06 | #3 (permalink) | |
Member: 1704666 Status: Offline Sonork: 100.1652565 Thanks Meter: 157 | Quote:
Flash1 ID: 00150001, Flash Size: 03AB400000 (15028M/14.68G) Flash2 ID: 00150001, Flash Size: 0000080000 (512K) Release Power on key now and operation continues... Phone doesn't respond for a long time,please reconnect! | |
02-27-2015, 14:18 | #4 (permalink) |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,621 | This mobile has already done with GPG EMMC Box. Please check: http://forum.gsmhosting.com/vbb/10002048-post14.html May be your device has EMMC IC Problem. Please check it and if the problem resist then change it. BR Dipendra Pathak |
02-27-2015, 14:30 | #5 (permalink) | |
but emmc full dump read success boot 1 boot 2 csd write scucces user file not write | |
02-28-2015, 05:56 | #6 (permalink) | |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,621 | Quote:
Did you full erase the device and write one bye one. First time only boot1, second time boot2 like that. And did you try write back the working dump? you did not write about it. Not giving full information, just killing time too, you know that. User file not that much important than boot1 or boot2. Sometimes after writing boot1 and boot2, device works properly. If the old back not work for you, then, find good dump and write to the device. I do not understand what do you mean reasonable and valid answer? JTAG/EMMC operation not like flashing, so it is hard and we have to consider more things while answer. I have just shown you that my friend has made success using same boot file. Is that mistake? Good Luck for your further operation! BR Dipendra Pathak | |
