04-01-2015, 12:06 | #1 (permalink) |
No Life Poster Join Date: Dec 2011
Member: 1704666 Status: Offline Sonork: 100.1652565 Thanks Meter: 157 | plz need help p3100 write cip lose after erase User not write showing this error mobile is total dead not powe on eMMC ORC: C0FF8080 AF eMMC CID: 1501004D414732474107925D0A4D8F eMMC CSD: D02701320F5903FFF6DBFFFF8A4060 ID check: 00010015 Product name: MAG2GA User partition size: 3AB400000 ( 15028M / 14.675G), 15758000128 Bytes Boot partition size: 0x200000 ( 2.0M ) RPMB partition size: 0x20000 ( 0.1M ) ID check...OK! Write chip...User Write chip: 131.38 sec. >>Write chip lost! |
04-01-2015, 12:23 | #2 (permalink) |
Member: 1704666 Status: Offline Sonork: 100.1652565 Thanks Meter: 157 | b4 falshing working but not format internal data and sum time reboot after erase User not write showing this error mobile is total dead not powe on eMMC ORC: C0FF8080 AF eMMC CID: 1501004D414732474107925D0A4D8F eMMC CSD: D02701320F5903FFF6DBFFFF8A4060 ID check: 00010015 Product name: MAG2GA User partition size: 3AB400000 ( 15028M / 14.675G), 15758000128 Bytes Boot partition size: 0x200000 ( 2.0M ) RPMB partition size: 0x20000 ( 0.1M ) ID check...OK! Write chip...User Write chip: 131.38 sec. >>Write chip lost! |
04-02-2015, 03:25 | #3 (permalink) |
Product Manager Join Date: Apr 2008 Location: Whitehole throught Blackhole!
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,623 | Did you use GPG power Adapter with GPG EMMC BOX? You can find GPG Power Adapter picture on this link: http://shop.gpgindustries.com/produc...ml?pb=108&pc=1 uploading images If you have power adapter attached, then, you can see COM and USB port in the software screen short as shown above. NOTE: I am using the picture to show the example only.You need Power adapter for ISP etc. BR Dipendra Pathak Last edited by Dipendra Pathak; 04-02-2015 at 03:44. |
04-02-2015, 07:49 | #4 (permalink) | |
Member: 1704666 Status: Offline Sonork: 100.1652565 Thanks Meter: 157 | Quote:
http://shop.gpgindustries.com/produc...ml?pb=108&pc=1 | |
04-03-2015, 03:01 | #5 (permalink) |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,623 | You have other option to repair it. Did you try repair via JTAG connect?. Could you please try with Jtag Operation and post the screen short with information. BR Dipendra Pathak |
