10-26-2014, 10:15 | #1 (permalink) |
No Life Poster Join Date: Jun 2011 Location: sonu
Member: 1595511 Status: Offline Sonork: nnn Thanks Meter: 121 | samsung i8552 dead boot repair not ok plz hellp Detecting, please press power on/off button... Device Ready...OK! Detection initiated... Detecting TCK,TDO,TDI,and TMS... Detecting TRST and SYSRST... TDO = 5 TCK = 9 TMS = 10 TDI = 11 SYSRST = 16 CPUID = E1008E00 Please click [Set PinOuts] button before read or write. >>Time: 7.42 s >> Device Ready...OK! Read operation(Make sure to press Power on key)... CPU ID: E1008E00. Phone doesn't respond for a long time,please reconnect! >>Time: 10 s Erase operation(Make sure to press Power on key)... CPU ID: FFFFFFFF. Don't support this CPU, or connection error please check connection >>Time: 1 s Writing in progress(make sure to press Power On key)... CPU ID: E1008E00. Phone doesn't respond for a long time,please reconnect! >>Time: 10 s GPGeMMC tame support |
10-26-2014, 10:20 | #2 (permalink) |
Member: 1595511 Status: Offline Sonork: nnn Thanks Meter: 121 | Device Ready... Device Ready...OK! ID check... Level (V): VCC V18 VCCQ D0 CMD CLK 1.8 Pullup: 0.00 0.00 0.00 0.36 0.39 0.00 1.8 Low : 0.00 0.00 0.00 0.00 0.00 0.00 1.8 High : 0.00 0.00 0.00 1.78 1.46 1.78 ... 2.5 Pullup: 0.00 0.00 0.00 0.85 0.86 0.00 2.5 Low : 0.00 0.00 0.00 0.00 0.00 0.00 2.5 High : 0.00 0.00 0.00 2.52 1.86 2.53 ... 3.3 Pullup: 0.00 0.00 0.00 1.40 1.14 0.00 3.3 Low : 0.00 0.00 0.00 0.00 0.00 0.00 3.3 High : 0.00 0.00 0.00 3.24 2.13 3.25 ... Power On : 2.73 1.77 2.48 0.85 0.93 0.00 Set Low : 2.73 1.77 2.48 0.01 0.00 0.00 Set High: 2.73 1.77 2.48 2.52 2.31 2.53 ... Work Voltage: 2.73 1.77 2.48 0.85 0.93 0.00 --------------------------------------------------- eMMC ORC: 00000000 FD eMMC CID: 0000000000000000,bad code! Please check CLK D0 . >>Erase chip lost! |
10-26-2014, 15:27 | #4 (permalink) |
Product Manager Join Date: Apr 2008 Location: Whitehole throught Blackhole!
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,623 | write more about the device. What was the device condition when you get it? This device is supported with Jtag If I am not wrong. Did you use GPG EMMC power adapter? Did you also use USB cable for more power to the device? Did you use battery + USB power? Did you try using Jtag Com Port? Did you also try holding power button continues while doing operation? Better post screen shorts of GPG EMMC connecting windows for better answer. BR Dipendra Pathak |
10-27-2014, 05:34 | #5 (permalink) |
Member: 1595511 Status: Offline Sonork: nnn Thanks Meter: 121 | samsung i8552 i get this cell hang after dead condition. I used your suggestion then also i get Writing in progress(make sure to press Power On key)... CPU ID: E1008E00. Phone doesn't respond for a long time,please reconnect! >>Time: 10 s this msg... |
10-28-2014, 14:49 | #6 (permalink) |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,623 | Brother, could you post screen shorts (Picture while doing operation) of GPG EMMC connecting. If you think, you are following the method thtat i have mentioned, then, you need to check for hardware of the device. BR Dipendra Pathak Last edited by Dipendra Pathak; 10-29-2014 at 05:29. |
10-29-2014, 16:20 | #8 (permalink) |
Member: 1595511 Status: Offline Sonork: nnn Thanks Meter: 121 | Detecting, please press power on/off button... Device Ready...OK! Detection initiated... Detecting TCK,TDO,TDI,and TMS... Detecting TRST and SYSRST... TRST = 1 SYSRST = 2 TDO = 5 TCK = 9 TMS = 10 TDI = 11 CPUID = E1008E00 Please click [Set PinOuts] button before read or write. Time: 12.78 s Device Ready...OK! Writing in progress(make sure to press Power On key)... CPU ID: E1008E00. Flash1 ID: 00350000, Flash Size: 000A960000 (169M) Release Power on key now and operation continues... Phone doesn't respond for a long time,please reconnect! >>Time: 20 s |
The Following User Says Thank You to gsmnitinmobile For This Useful Post: |
11-01-2014, 06:43 | #13 (permalink) |
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,623 | @gsmnitinmobile Hi bro, don't use pinfind button because you have already pinout. Use dafault pinouts button and sold wires according to their pinouts like: if you use Riff pinouts, then Click on "Riff Default Pinout" button and keep continue the operation same as, If you use other device's pinout then click on the device pinout like Medusa etc.... device pinout and Continue the operation. Hope it will help you to do your operations in coming days too. BR Dipendra Pathak |
