12-02-2014, 07:31 | #1 (permalink) |
Product Supporter Join Date: Jul 2008 Location: iran-shiraz
Member: 814775 Status: Offline Sonork: 100.1587334 Thanks Meter: 973 | Actions PAD Product Tools Actions Semi ATM7029 Quad-core ARM CPU devices 1.01.02 http://yadi.sk/d/wn0y5BdtFmQy9 2012-12-25? (Use newer versions for Ainol firmwares) 1.02.02 http://yadi.sk/d/Xf5NVryz998nC 2013-01-08? (Hero 4 nuclear upgrade tool) 1.02.03 http://yadi.sk/d/GFpAmhs39QZ67 2013-01-28? 1.02.04 http://yadi.sk/d/Q77kNQRx5py4n 2013-02-27? 1.04.01 http://yadi.sk/d/mzPzjx8x98vWv 2013-07-05? 1.05.02 http://yadi.sk/d/KrQo018cDYkqw 2013-11-25 (automatic updates) 1.06.01 http://yadi.sk/d/RFV5MC7SHuhht (test version. Install an older version, or just its drivers to use.) 1.06.02 http://yadi.sk/d/BB67kma9JaUYY 2014-02-25 1.07.02 http://yadi.sk/d/5VDeBWigMwt9X 2014-04-22 |
The Following 5 Users Say Thank You to dr_moosavi For This Useful Post: |
12-02-2014, 07:32 | #2 (permalink) |
Member: 814775 Status: Offline Sonork: 100.1587334 Thanks Meter: 973 | For non-developers? (Better use a Developer Edition) End User Upgrade V1.01 http://yadi.sk/d/VxJwKz95FmQ2t (if it says "Nothing found" just reload the download page) |
The Following 3 Users Say Thank You to dr_moosavi For This Useful Post: |
12-02-2014, 07:35 | #3 (permalink) |
Member: 814775 Status: Offline Sonork: 100.1587334 Thanks Meter: 973 | Actions PAD Firmware Modify Tools Actions PAD Firmware Modify Tools Some Actions' programs I found from Baidu shares during the holidays. There is many vendors who (unlike Ainol) share these tools there. When Ainol released the source code, "小二黑, Xiao Erhei" said that they have some plans to release some more stuff (like this?) but I've heard nothing about it since then. With "Pad Firmware Modify Tool" one can do the same things (and more) that some of my packages do. For example it enables re-partitioning like the partition patchers and the "Liberator" tool (although they are lighter/more flexible). And it also makes boot logo editing package obsolete now... (when editing Actions' boot logos that is) For boot.img editing one still might have to use something like my uImage un/repacker. Anyway, it's a nice tool for stock ROM modders, etc... Download V1.01 http://yadi.sk/d/d6CAgFrMFmKEK V1.02 http://yadi.sk/d/YB8YbVh8GaZCu V1.03 http://yadi.sk/d/xh90XgBhFmKhA V1.04 http://yadi.sk/d/kwsfJuypFmKv3 V1.05 http://yadi.sk/d/U1rlJxJIFmKx5 V1.06 http://yadi.sk/d/b82atoUeFmKyk V2.00 http://yadi.sk/d/JniKWv4QHuhiK (test version) V1.07 http://yadi.sk/d/yymo17HxJaUZH (automatic updates) V1.08 http://yadi.sk/d/EzayZ6fRMwmq2 V1.10 http://yadi.sk/d/McQKDNCZYjbQ8 2014-08-08 V1.12 http://yadi.sk/d/QY757mmrbg2ku 2014-09-15 V1.13 2014-10-08 |
12-02-2014, 07:36 | #4 (permalink) |
Member: 814775 Status: Offline Sonork: 100.1587334 Thanks Meter: 973 | Other tools from Actions Pad Image Maker Tool Make vendor partition images with your own bloatware easily. V1.01 http://yadi.sk/d/4ofK51BaFmYdT V1.02 http://yadi.sk/d/UbKHU6mmMwzBs More tools will be here... |
12-02-2014, 07:37 | #5 (permalink) |
Member: 814775 Status: Offline Sonork: 100.1587334 Thanks Meter: 973 | Actions ATM7029 Hardware Check Tool Actions ATM7029 Hardware Check Tool Test that it isn't some hardware problem. Needs adfu (product tool) drivers installed. Download ATM7029 v1.0: http://yadi.sk/d/zTUeOyJ0Ge3ET Download ATM702X v1.2: http://yadi.sk/d/E7klzRB0KA7W8 Download ATM702X v1.3: http://yadi.sk/d/Ov6gVVawMx2BL Questions? --> Guide in English, Google translated |
The Following 2 Users Say Thank You to dr_moosavi For This Useful Post: |
12-02-2014, 07:41 | #6 (permalink) |
Member: 814775 Status: Offline Sonork: 100.1587334 Thanks Meter: 973 | PCBA Test Tool (misc.img version) A tool to help mass testing. Little or no use otherwise. (Just wanted to see how it works...) Modified for Crystal 2. To use it, flash it to the misc partition. (just it, no erase nor formatting) Unplug charger/usb before starting. To remove, just flash the original misc.img back. To use it in another tablet, copy boot.img, dk44k_2ch_20s.wav, pcba.conf, modules.sh and the lib folder to its misc and make the necessary changes. Tests: memory, flash, wifi, gsensor, camera(s), bluetooth, clock, vibrator, sdcard, OTG, USB, HDMI, headphones, buttons, touch, sound and mic. An image with bad translations included. (bluetooth and HDMI not in it) Download: http://yadi.sk/d/ANWlpQlZGmiTt |
12-02-2014, 07:42 | #7 (permalink) |
Member: 814775 Status: Offline Sonork: 100.1587334 Thanks Meter: 973 | Pad Card Writer Tool V1.01 Make bootable SD cards. Don't ask me how Download: http://yadi.sk/d/qafCqqsYGqBys Chinese instructions: http://yadi.sk/i/9OVS4SGAVmHw2 SD card package for Hero2: http://yadi.sk/d/FGvUiJ4CVoTgV For some reason erasing flash didn't work for me. It might be that the boot device must be changed to SD card?? In some package it was done in afi.cfg like this (haven't tested) // Boot Device // // 0x00 - NAND // 0x20 - SD0 // 0x21 - SD1 // 0x22 - SD2 // INF_AFI_DEF_BYTE = 0x08,0x20; // sd0 |
12-02-2014, 07:42 | #8 (permalink) |
Member: 814775 Status: Offline Sonork: 100.1587334 Thanks Meter: 973 | More Actions' Test apps They are in Chinese so I don't know much about them. These can be run as normal apps in any model, starting is just a bit different. Some of them might be already installed by default. ActionsPcbaTest.apk - same as the previous misc.img version ActionsProductLineTest.apk - similar, but less automatic, maybe more control ActionsAgingTest.apk - see the next message Download, running instructions included http://yadi.sk/d/IK7Sd2y0HQt4T (For screenshots see the next message...) |
12-02-2014, 07:44 | #9 (permalink) |
Member: 814775 Status: Offline Sonork: 100.1587334 Thanks Meter: 973 | Translated the ActionsPcbaTest and the ActionsAgingTest using Google and APKTool. Download address is the same: http://yadi.sk/d/IK7Sd2y0HQt4T Can be launched normally now. (Aging test still needs started with am.) Aging test looks like a stability test. It runs some tasks repeatedly or a period of time. To run time tests put a video file into Movies folder and install Fishing Joy 2 game |
The Following User Says Thank You to dr_moosavi For This Useful Post: |
12-02-2014, 07:44 | #10 (permalink) |
Member: 814775 Status: Offline Sonork: 100.1587334 Thanks Meter: 973 | Also ActionsProductLineTest now works in "English". It makes a database (plt_data.*) to the root of the sd card from where it took the Chinese texts. So if you have tried the Chinese one, delete plt_data.* files from your ex/internal sd card. Download address is still the same: http://yadi.sk/d/IK7Sd2y0HQt4T Just the "English" test apps: http://yadi.sk/d/q8DJ1Kt9HdRaF |
12-02-2014, 07:45 | #11 (permalink) |
Member: 814775 Status: Offline Sonork: 100.1587334 Thanks Meter: 973 | Actions' test apps in English (their own versions) Now I found them in English, so translating them was useless... Not edited, so must be run using am. ActionsPcbaTest.apk - http://yadi.sk/d/jpAlMkckK82Gb ActionsProductTest.apk - http://yadi.sk/d/jBzTYDUhK82H4 ActionsAgingTest.apk - http://yadi.sk/d/E0xTSZ7JK82aK (123MB!) ActExplore.apk - http://yadi.sk/d/5iXNIW1mK82K2 The last one a small File Explorer from Actions. (FishingJoy2 game for the Aging Test: http://yadi.sk/d/dhBpzkwrKNoU6) |
12-02-2014, 07:45 | #12 (permalink) |
12-02-2014, 07:50 | #13 (permalink) |
Member: 814775 Status: Offline Sonork: 100.1587334 Thanks Meter: 973 | Upgrade/Flash the Ainol Novo 7 Venus firmware FIRMWARE UPGRADE TOOL (Tablet Product Tool(Developer Edition) .... Ainol Last edited by ...:::::NP™:::::...; 08-27-2020 at 00:22. Reason: YouTube Link has been correction |
05-19-2016, 10:49 | #15 (permalink) |
Junior Member Join Date: May 2016
Member: 2574840 Status: Offline Thanks Meter: 0 | All the stuff in this thread has been copied from Slatedroid . com Here is the original thread there (remove the spaces) h t t p : // www . slatedroid . com/topic/94521-actions-tablet-tools/ |
