Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Android based Phones / Tablets > Android Tablets
Old 01-20-2019, 22:02   #331 (permalink)
Member: 2687904
Sonork: family
plz i want this fermware tw_a0766bs_v33_201706156
The Following User Says Thank You to alielali For This Useful Post:
Old 01-26-2019, 03:32   #332 (permalink)
Member: 2810036
I need help i have firmware eSTAR GEMINI IPS Quad Core 8
motherboard.
model 8128
board id MB80906_A33_V1_1 2015.03.06
Android version: 5.1.1
Operating system Android 5.1 Lollipop
im look firmware need
The Following User Says Thank You to Zeus33 For This Useful Post:
Old 02-02-2019, 11:55   #333 (permalink)
Member: 2827654
Thanks Meter: 3
Originally Posted by mgonline View Post
OTHER DETAILS
On the back side of the display there is this number
HT-9001-02P-140L-2017-XX-XX
I tried to flash some firmware name CB-M 94V-0 trough Phoenix but the process does not even start.
Up to now the firmware version that at least allowed me to turn on the device was A33-800X480-astar_y3-eng-4.4.2-KVT49L-20141224-test-keys but touch screen doesn't work and display can only be seen against the light.
Thank you for your Help. Best regards
MY TABLET IS YD MID900
TW_A0935BS2_V22_20170808
MaPan MAIXIN ???
HELP ME mribraqdbra
The Following User Says Thank You to mgonline For This Useful Post:
Old 02-03-2019, 12:41   #334 (permalink)
Member: 2827654
Thanks Meter: 3
All MaPan link for download firmware are down...
Anyone can provide me MX923B firmware JellyBean
Old 02-04-2019, 09:11   #335 (permalink)
paulbs's Avatar
Member: 74719
Sonork: paulelectro
Thanks Meter: 181
work ...need search
http:// w w w .maixin-china.net/software/mx713-dc.html
The Following User Says Thank You to paulbs For This Useful Post:
Old 02-04-2019, 11:14   #336 (permalink)
Member: 2846109
Thanks Meter: 2
need firmware for this tablet;
dtech- 7 pad -w 702
A33-Quadcore
TZX-733VA22
thank's.
The Following User Says Thank You to ziktamurt For This Useful Post:
Old 02-04-2019, 13:07   #337 (permalink)
GazI's Avatar
Member: 20566
Thanks Meter: 29
this file work for ACME TB714
A33 Allwinner
71Q6-A33(A23) v1.0
2015-03-20
870256_SW_S3T7IN_20160222-http://smartphonesreset.********.com/.rar - FileFactory
The Following User Says Thank You to GazI For This Useful Post:
Old 02-04-2019, 17:56   #338 (permalink)
Member: 2693319
thans for your method
Old 02-09-2019, 04:18   #339 (permalink)
Member: 2892615
Sonork: www.sonork.com
Exclamation drn x600
TW-A0720R-V30 yazılım rom arıyorum lutfen yardım saygılar
Old 02-10-2019, 01:01   #340 (permalink)
Member: 2892615
drn x600
A33 TW-A0720R-V30 yazılım rom arıyorum lutfen yardım
Old 02-11-2019, 22:11   #341 (permalink)
Member: 2170096
Thanks Meter: 13
Someone Can help with firmware for Insys xf7-a701
A33
Wifi Chip : RTL8703BS
Touch Chip : GSL1680
Screen Resolution: 1024 X 600
Rom: 8GB
Thanks in Advance !
The Following User Says Thank You to powa For This Useful Post:
Old 02-12-2019, 16:07   #342 (permalink)
Member: 2827654
Thanks Meter: 3
OK Guys after one year of discontinued work on my chinese Tablet i found the system for operate correctly.
After several searches i found a firmware that contained a lot of drivers for different tablet configuration. Through Dragon Face i changed the file system values after opening the tablet and checking the chipset of the display, touch and WiFi.
Installed everything through phoenix suite the system has restarted correctly with the right graphic resolution and the touch perfectly working.
Too bad the Tablet with a version of Android Kit Kat is slow and many apps do not work properly because the amount of available ram memory is not enough and is always saturated.
Old 02-18-2019, 03:38   #343 (permalink)
Member: 2892615
powerway drn x600
A33 TW-A0720R-V30 bir suru yazılım buldum am hic biri duzgum calışmadı
bana bir yol gosterin
Old 03-05-2019, 01:12   #344 (permalink)
Member: 329950
Thanks Meter: 2
HI all,
newbie here...
I've been searching for 1 month now for firmware (.img / ROM) for a Chinese tablet that only said QUART at the back panel.
I tried more than 100 firmwares I could find via Google, but each one of them had a flaw, some didn't start at all, others couldn't be used because the touch doesn't work, but in all of them - the WiFi just would not start.
However, after opening the tablet, I got the following:
Allwinner
A33
86V-A33-V1.0
2014/07/05
GT 1440 PTW
GT8UB256M
16BP-BH 30
1450408401
SK hynix H27UCG8T2ETR BC 411A
M18LRB26AJ4
AXP223 ECO32AC 6CH1
Silead
GSL 1680
LIF106R754N
ESP8089
492014
P1WX70
CB07021AA-LCMA2
Any help would be highly appreciated.
The Following User Says Thank You to lazy_eye For This Useful Post:
Old 03-11-2019, 11:14   #345 (permalink)
Member: 2741086
Thanks Meter: 19
Originally Posted by lazy_eye View Post
HI all,
newbie here...
Allwinner
A33
86V-A33-V1.0
2014/07/05
GT 1440 PTW
GT8UB256M
16BP-BH 30
1450408401
M18LRB26AJ4
AXP223 ECO32AC 6CH1
Silead
GSL 1680
LIF106R754N
ESP8089
492014
P1WX70
CB07021AA-LCMA2
You got a bad luck!
did you tried this?
https://www.firmware1.com/2015/12/a3...-firmware.html
Page generated in 0.21648 seconds with 9 queries
