01-09-2013, 15:27 | #31 (permalink) | |
No Life Poster Join Date: Oct 2008 Location: PAKISTAN
Member: 882981 Status: Offline Sonork: 161363 Thanks Meter: 306 | Quote: Wipe Rom = Wipe Data and Wipe Cache = Factory Reset = Data Lose MANY TIME BUT SAME PROBLAM | |
01-10-2013, 03:47 | #32 (permalink) | |
Product Manager Join Date: Dec 2009 Location: CEO.of.ROMDevelopers Age: 32
Member: 1174508 Status: Offline Sonork: 100.1593820 Thanks Meter: 11,979 | Quote:
Wipe done? If yes then still your problem .So you need update tab. If wipe not done get any error ,Read full tharead . | |
01-10-2013, 10:23 | #33 (permalink) | |
Dear, i was done same procedure and tab ran but face still problem when you send me procedure same as category was fallow did not clear. last you tell me update tab kindly send me way off updating procedure may be possible clear my tab condition............ (this problem create last time i was do angry bird game install in tab so when i start game tab is hang and customer angry with me) | |
01-17-2013, 08:42 | #35 (permalink) |
Cheater -Don't Deal with him- Join Date: Nov 2007 Location: In the web Age: 37
Member: 622382 Status: Offline Thanks Meter: 201 | brotehre i have one tablet a13 but i cannot solved hang logo. ur driver not work for me . all ways show adb interface not found. |
01-17-2013, 15:04 | #36 (permalink) | ||
Check Here About ROM Quote:
Why Asked Its Not Work Check User Reply Already Done Another One . For More Info Check Full Thread If You Need Other Any Help Connect Me On Sonork . Driver Install Done But Software Not Asked For Press Any Key ? If Yes Use Other Pc And Try To Change Usb Cable And Check Usb Post . After Install Driver Software Not Asked Press Any Key Solved | ||
01-25-2013, 07:29 | #37 (permalink) | |
Freak Poster Join Date: Oct 2004 Age: 47
Member: 88402 Status: Offline Thanks Meter: 489 | wipe success Quote:
This work 1000000% i tried morethan 50 handsets. i face some commen errors i will list to all i hope that will halp to others. 1.this software work more easy in win7 then xp. 2. most probably who are installed samsung kies may face a problem in wipe. (for this problem select driver file manually and select "android_test" driver file inside the software. Don't reboot pc after drivers install). 3. mostly morethan 2 usb slots avalible in pc or laptops so i fail one then try to another. 4. and the lost failure make perfect again im 100% sure the software very very good working and thanks to the creator. almost BEST OF LUCK. | |
The Following User Says Thank You to cgsm For This Useful Post: |
01-25-2013, 11:35 | #38 (permalink) | |
Freak Poster Join Date: Aug 2007 Location: in iOs
Member: 563648 Status: Offline Sonork: 100.1594523 Thanks Meter: 87 | Quote:
Good Share Tested On Wintouch A13 | |
01-28-2013, 07:02 | #39 (permalink) |
Junior Member Join Date: Mar 2011 Location: philippines Age: 35
Member: 1537477 Status: Offline Thanks Meter: 2 | thnx man for this useful software.....i solved my china android tablet zinc desire..ive been 3weeks looking for solution and now ive found this useful info....i solve my customer china android tablet.....more thnx one man... |
01-30-2013, 03:40 | #40 (permalink) | |
Freak Poster Join Date: May 2010 Location: angeles city,pampanga Age: 45
Member: 1304373 Status: Offline Thanks Meter: 31 | Quote:
02-03-2013, 16:30 | #43 (permalink) |
Freak Poster Join Date: Oct 2006 Location: India
Member: 376471 Status: Offline Sonork: 100.1608095 Thanks Meter: 107 | Dear Member......... wipe_rom easy a10 - a13_1 - Download - 4shared try this link or do it manually........... adb shell recovery --wipe_data android - Wipe data/Factory reset through ADB - Stack Overflow |
02-04-2013, 13:36 | #44 (permalink) | |
Major Poster Join Date: Oct 2006
Member: 372620 Status: Offline Thanks Meter: 38 | Download link not working pls give another link Download link not working pls give another link Quote:
The Following User Says Thank You to rry For This Useful Post: |
