Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Android based Phones / Tablets > Android Tablets
Old 11-16-2013, 10:21   #1 (permalink)
Faheem Anjum's Avatar
Member: 399832
Sonork: Faheem Anjum
Thanks Meter: 24,310
Android Tools v1.1 [ Faheem Anjum ]
Check device
- you can now check device by clicking "search device" in device check icon
if device is detected it means device is set to ENABLE USB DEBUGGING
- if device is detected you can use WIPE DATA
if device is not detected proceed to flashing using LiveSuit and ETC.
Scr!tp Tools
- ENABLE USB DEBUGGING must be set on device or android tablet
- added "search device" to know if tablet is detected before scr!pt editing.
FIX TOUCH SCREEN TOOLS
- A13 All winner chips is supported but you can do experimental in other device chips
but use at your own risk and always do back up rom or firmware prepared just incase what
happen to your device after injecting fixers tools.
CAMERA FIXER TOOLS
COMBO FIXER TOOLS
- this tools can only fix on specific model available in my shell button.
- you can do experiment by injecting scr!pt to other device but use at your own risk.
Android X-tools by Xeven2nd Version 2
FEATURES ADDED:
Check device
Scr!tp Tools
CAMERA FIXER TOOLS
COMBO FIXER TOOLS
PLEASE HELP TO THE VICTIMS OF TYPOON HAIYAN
Download Here
The Following 108 Users Say Thank You to Faheem Anjum For This Useful Post:
Old 11-16-2013, 11:16   #2 (permalink)
Member: 1908579
Thanks Meter: 21
Can any one create a software that can detect android without usb debug? is it possible?
The Following User Says Thank You to maiga73 For This Useful Post:
Old 11-16-2013, 11:21   #3 (permalink)
r-jcomm's Avatar
Member: 601913
Sonork: 100.1597350
Thanks Meter: 658
hi
plaese add onething in ur software " temporary enable usb debug" option line in mirracke cocktail
thanks in advance
br
S.M.JUNAID
The Following 5 Users Say Thank You to r-jcomm For This Useful Post:
Old 11-16-2013, 11:27   #4 (permalink)
Member: 399832
is it posible long time ago thru flashing
just kidding
The Following User Says Thank You to Faheem Anjum For This Useful Post:
Old 11-16-2013, 11:37   #5 (permalink)
usmano abdullah's Avatar
Member: 1206600
Sonork: 100.1670311
Thanks Meter: 11
nice work .pls how to enable usb debung
Old 11-16-2013, 11:40   #6 (permalink)
r-jcomm's Avatar
Member: 601913
Sonork: 100.1597350
Thanks Meter: 658
Originally Posted by r-jcomm View Post
hi
thanks in advance
br
S.M.JUNAID
sorry i write wrong spellings up there in my post "(plaese add onething in ur software " temporary enable usb debug" option like in mirracle cocktail")
now its ok
The Following 2 Users Say Thank You to r-jcomm For This Useful Post:
Old 11-16-2013, 11:42   #7 (permalink)
Member: 1418524
Thanks Meter: 186
Payment Sent (Unique Transaction ID # 7GW80108SH8497534)
M.FAHEEM THIS MY SMALL DONATIONS
Mashallah
The Following 10 Users Say Thank You to gsaara For This Useful Post:
Old 11-16-2013, 16:36   #8 (permalink)
ea12345's Avatar
Member: 130345
Thanks Meter: 10
Faheem bhai remove virus first than share exe.
The Following 2 Users Say Thank You to ea12345 For This Useful Post:
Old 11-17-2013, 10:34   #9 (permalink)
gsm_shamim's Avatar
Member: 1845954
Sonork: 100.1622497
Thanks Meter: 397
Need solution
Hello Faheem sir Pls give solution. When i try to open Faheem Anjum Tools v1.1 then show this
I have download ur another tool name Droid Tool by Faheem Anjum but it is pass adjust.
Pls give solution
Old 11-17-2013, 11:20   #10 (permalink)
Member: 1908579
Thanks Meter: 21
just kidding
sir but flashing cause problem to some phones especially cloned phone i appreciate your tool but am sure you peoples can create one to use without usb debug
Old 11-19-2013, 08:40   #11 (permalink)
moonmoon8
Guest
Posts: n/a
Member:
Nice Options!
Just need one more "Temp USB Debug Enable" or Reset via AT-Command
Good Luck
Old 11-19-2013, 10:51   #12 (permalink)
Member: 202786
Thanks Meter: 2
If u play games with users then bye bye ........Share a clean link without passsword
Old 11-19-2013, 16:33   #13 (permalink)
Member: 2022385
Sonork: 166633
Thanks Meter: 74
This link has no password bro check it again.
Old 11-20-2013, 07:15   #14 (permalink)
narayan pathak's Avatar
Member: 1864020
Sonork: 100.1624750
Thanks Meter: 44
Faheem Tools v1.1
The Following 2 Users Say Thank You to narayan pathak For This Useful Post:
Old 11-20-2013, 15:16   #15 (permalink)
Member: 154879
Thanks Meter: 2
Transaction Details
Payment Sent (Unique Transaction ID # 0MM434656T189645K)
The Following 2 Users Say Thank You to jam_gsm For This Useful Post:
Page generated in 0.25240 seconds with 10 queries
