Asus memopad me172v hard reset what is not posted before in this forume when i need find from another place ------ ASUS MEMOPAD ME172V WIFI hard reset 1. Download the "cleardata.zip" 2. Unzip to MicroSD card 3. insert SD to device 4. press power bottun to boot 5. choose clear user data by volume key and press power key to do the clear data ------------ cleardata - Download - 4shared |
My device is not going in boot mode while pressing Vol- & PWR tried many times.. BR |
He said PRESS POWER BUTTON TO BOOT. Not POWER + Volume - |
cannot boot with power botton,pls help me bro. |
Then can u more elaborate wth ur power button to boot ?? Bro i asked how to hard reset when it does not go to boot mode ? BR |
I already download the clear data in my micro SD card and inserted it to my memo pad but when I power on the pad it continuously goes to the main screen and not to the boot loader.. pls help.. need to hard reset my pad.. thanks guys |
@ mobile_hotman,chardie hard reset solution, formate sd card and copy bspinst+scriptcmd to sd card,insert SD to device,just power on,selct clear data,thats all, injoy. |
ASUS ME172V, Hardreset ASUS ME 172V -Hard reset solution, formate sd card and copy bspinst+scriptcmd to sd card,insert SD to device,just power on,selct clear data,thats all, injoy. DOWNLOAD FROM ASUSTeK Computer Inc. -Support- Drivers and Download ASUS MeMO Pad |
i have done 10+ tabs with this file and same procedure one is just before 5 minuts use original mmc and with charger conected best of luck thanks |
It doesn't work for me too. I did format the mmc with fat32 and copied the files, and did the rest but it turn on to the normal mode. I'm using a 1gb mmc, is it possible that this is the problem? Should i use 4gb? Please help. |
need to extract cleardeta.zip to your mmc |
here is some points that i face yesterday ------------------- copy or heap third quality mmc card will not boot into recovery mode must use any original mmc card battery must b up to 50% charged - thanks |
ASUS ME 172V -Hard reset thanx 100% working use original mmc card |
Notice ... MMC below 2GB will be working like charm .. upto 4GB or 8GB .. u need to buy or borrow u're friends,coz it wun be works .. tested many2 time by me with MMC 2GB. |
