08-19-2015, 05:09 | #1 (permalink) |
Junior Member Join Date: Aug 2015 Location: Mashhad
Member: 2442925 Status: Offline Thanks Meter: 1 | ATM7013} HIMAXX HM071 (xrd-q8-vc 2012/10/15) Helps... Please suggest a software for flashing china tablet with ATM7013 CPU & also I need firmware for tablet HIMAXX HM071 (GENERIC gs701b) ATM7013 CPU Q8. These photos are from front and back of the motherboard. Restarting and factory reset didn't solve the problems & I must flash it. Most of the links I found was dead. like ele-china & AZhuo I used Livesuit & Phoenixsuit but none of them recognized the tablet. I flashed once using Actions Product Tool but this software need .FW & two .IMG files, I need a software for .IMG files only. Please HELP Thank you uupload [DOT] ir / files / mgf9_front [DOT] jpg uupload [DOT] ir / files /4aaw_back [DOT] jpg Please correct the links because as a new member I couldn't post links. |
08-19-2015, 05:58 | #2 (permalink) |
Product Manager Join Date: Dec 2009 Location: CEO.of.ROMDevelopers Age: 32
Member: 1174508 Status: Offline Sonork: 100.1593820 Thanks Meter: 11,978 | Continue thread only Here, Don't post in too many thread Anyway, Try this 3 rom and report :
In case these link not work in your tablet , Then post tablet and model number !! We have some rules in forum, Before using forum u should read http://forum.gsmhosting.com/vbb/f62/...rules-1591101/ Always read sticky before posting In any section !!! Android tablet http://forum.gsmhosting.com/vbb/f906...rules-1918658/ Thank You Last edited by aZimBahar; 08-19-2015 at 06:11. |
The Following 2 Users Say Thank You to aZimBahar For This Useful Post: |
08-27-2015, 23:00 | #3 (permalink) |
Member: 2442925 Status: Offline Thanks Meter: 1 | Thanks for your reply I tested all these 3 firmwares and touchscreen doesn't work in first 2 of them and the last one is good but right half of the touchscreen is on the left side |
08-28-2015, 22:57 | #5 (permalink) |
Member: 2442925 Status: Offline Thanks Meter: 1 | these are from the front and back of the board www . upsara . com / images / xtl3_front .jpg www . upsara . com/ images / 5oli_back .jpg (remove spaces from links) this software is for .fw files or .fw and .img file both together but I need a software for only .img files to flash this tablet |
08-29-2015, 04:13 | #6 (permalink) |
Member: 1174508 Status: Offline Sonork: 100.1593820 Thanks Meter: 11,978 | Come on man Its action (ATM) tablet All flash file are same format .FW .IMG flash file format for AllWinner , Rock ETC Chip Action tablet has 2 kind of file . A) Single .FW file. B) Multiply .Fw file (System recovery, mesi, FW ETC ) I Hope Clear Try With This rom and Report here : TF-20121031-Q8-0329camera - Download - 4shared - ????? ?????? Last edited by aZimBahar; 08-29-2015 at 07:11. |
The Following User Says Thank You to aZimBahar For This Useful Post: |
09-29-2015, 01:31 | #10 (permalink) |
Member: 2442925 Status: Offline Thanks Meter: 1 | I finally found a firmware although it has some problems but at least touch works. search forums for gs701b atm7013 q8 7" |
The Following User Says Thank You to Metal.Jack For This Useful Post: |
