10-30-2014, 09:09 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: (United States Of Islam) Age: 37
Member: 399832 Status: Offline Sonork: Faheem Anjum Thanks Meter: 24,310 | Axis A23 7″ Tablet Manual firmware only on one place https://www.dropbox.com/s/w613rzehye...r%20manual.pdf Quantum Axis A23 Windows Drivers: https://www.dropbox.com/s/kf1nra23l8...river.zip?dl=0 Quantum Axis A23 Firmware installation: The version of firmware you should use is determined by the serial number that was on the back of the tablet when you received it. **** YOU MUST use the correct firmware for your tablet ***** **** DO NOT us the incorrect firmware version or certain features will not work on the tablet***** Manual Firmware Installation: 1) download the instructions pdf 2) down load the burn card tool zip file. 3) download the CORRECT firmware version for your tablet 4) unzip the burn card tool file using Winzip or Winrar 5) unzip the Firmware file using Winzip or Winrar 6) follow the rest of the instructions in the document on line one. Please download the instructions below: https://www.dropbox.com/s/sslhbovyzg...nstruction.pdf You will need to use the burn card tool (which you can download from right here!): https://www.dropbox.com/s/omvlf5aels...ard%20tool.zip No serial number when received – Use this firmware: https://www.dropbox.com/s/b87mjcq7ur...40315-root.img Serial numbers: S/N:AXIS2014050001 TO S/N:AXIS2014050510 – Use this firmware: https://www.dropbox.com/s/kv70mxdqno...ipment%202.zip Serial numbers: S/N: AXIS2014060001 TO S/N: AXIS2014061000 – Use this firmware: https://www.dropbox.com/s/5jfn5jqbss...ipment%203.zip Serial numbers: S/N: AXIS2014070001 TO S/N: AXIS2014071000 – Use this firmware: https://www.dropbox.com/s/gped08vegw...e%204.zip?dl=0 |
The Following 3 Users Say Thank You to Faheem Anjum For This Useful Post: |
10-30-2014, 10:22 | #3 (permalink) |
Member: 399832 Status: Offline Sonork: Faheem Anjum Thanks Meter: 24,310 | 821724c3544ef920f06 BROTHER WHICH I DOWLOAD FIRMWARE ? here this one :https://www.dropbox.com/s/b87mjcq7ur...40315-root.img Last edited by Faheem Anjum; 10-30-2014 at 10:38. |
The Following User Says Thank You to Faheem Anjum For This Useful Post: |
10-30-2014, 10:32 | #4 (permalink) | |
No Life Poster Join Date: May 2008 Location: hall road pakistan
Member: 782530 Status: Offline Thanks Meter: 8,136 | Quote:
THIS ONE FOR ME ????? | |
The Following User Says Thank You to FullFlashPak For This Useful Post: |
11-01-2014, 06:45 | #5 (permalink) | |
