GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   Android Tablets (https://forum.gsmhosting.com/vbb/f906/)
-   -   BSNL Penta T-Pad IS709C pattern lock (https://forum.gsmhosting.com/vbb/f906/bsnl-penta-t-pad-is709c-pattern-lock-1598170/)
anil.prajapati 01-13-2013 09:59
RATHISH.TR_ALUVA 01-13-2013 13:34
TRY WITH RESETTING/WIPE
1. There three buttons at front in Penta TPad
2. Press these three buttons together and then try to start Tpad by using Power Button. Once you done it It will ask you to press the button Press the top most button (Which is going to be used for back). and then it will show that your Penta TPad is resetting.
anil.prajapati 01-13-2013 15:11
1 Attachment(s)
i can enter in recovery mode but menu not showing plz help me
i can press a button but stll in recovery android image
ritikesh 01-20-2013 12:29
hellooo
i also facing the same problem plz help..............
Frenzy_2020 01-20-2013 12:35
contact me. I have done this Tab, its a bit trick u need to flash the Tab with firmware
frenzy
ritikesh 01-20-2013 12:41
frenzy
i have sent u a private msg....
plz plz help............
Mehmood Riaz 1 01-20-2013 13:00
Press and hold Volume up + Volume Down + power on
select wipe data/ factory reset by volume down button then touch menu
> volume down to select yes--delete all user data then touch menu
> reboot system now
http://img534.imageshack.us/img534/277/123vdy.png
lakhasharp 01-25-2013 06:29
bsnl penta is709c tablet flashing problem plz help me Thanks for advance
abhishekkjain 02-15-2013 18:03
Hey how is this tab? Shall I buy it?
amit kanpur 02-15-2013 20:03
try to hard reset by adb...........
anil.prajapati 02-16-2013 06:05
plz tell me peroceder
adb
manish 1213 02-16-2013 06:16
i have also done....pattern unlock
there have three buttons in tab.....press volume + menu +power....then u have see android pic.....then again press volume down....u have enter the menu....n delete wipe factory setting and unlock the tab.....aprover by me
alkesh02 03-08-2013 06:57
how to hard reset penta t-pad is709c
ple help me
alkesh02 03-08-2013 06:58
step by step explen how to hard reset penta t-pad is709c manish
trust4eve83 03-08-2013 14:31
DO YOU HAVE Android Multi Tools_1.0 By AzimBahar TOOL ? IF U HAVE THEN USE THIS TOOL IF U DONT HAVE THEN DOWNLOAD HERE Android-Multi-Tools_1.0-By-azimbahar.rar USE THIS TOOL WORKS FOR U 100%
Page generated in 0.17213 seconds with 6 queries
