04-27-2013, 13:22 | #32 (permalink) | |
No Life Poster Join Date: Jan 2008
Member: 681090 Status: Offline Sonork: 100.1621067 Thanks Meter: 120 | trick-works Quote:
thanks-tricks works for me thankyou very mutch | |
05-15-2013, 12:53 | #36 (permalink) |
Freak Poster Join Date: Oct 2006 Location: India
Member: 376471 Status: Offline Sonork: 100.1608095 Thanks Meter: 107 | Dear Member.... download the tool from the link, extract the update.img with that tool. After that flash with Rock Chip Flast tool... Rk29xx ImageTools V2.1 - SlateDroid.com Your problem solved..... Just now i flashed the tablet with that tool and succeeded. See the screenshot attachment... |
05-15-2013, 18:04 | #39 (permalink) | |
No Life Poster Join Date: Aug 2010 Location: find me
Member: 1377174 Status: Offline Thanks Meter: 226 | Quote:
05-16-2013, 06:37 | #40 (permalink) | |
No Life Poster Join Date: Jul 2009 Location: India
Member: 1086393 Status: Offline Thanks Meter: 771 | Quote:
My phone is in pattern lock. I have updated the fw with memory card but still pattern lock. I need to factory reset the tab. thanks | |
05-16-2013, 08:46 | #41 (permalink) | |
Member: 376471 Status: Offline Sonork: 100.1608095 Thanks Meter: 107 | Quote:
Dear Member... BSNL Penta IS709C is Rockchip CPU based tablet. It detects as RK29 device to flash the firmware. Download firmware file from this link and extract... http://www.pantel.in/download/IS709C...Wifi%20CTU.zip Dowload the tools from this link... RK29xxImageTools_v2.1.zip T760-AdvUpdater.rar Extract the RK29xxImageTools_v2.1 and place the update.img to this folder and rename it to wendal.img... Then run Runme.bat file and select 1 to unpack the file. After unpacking the flashing files will be located in temp folder of RK29xxImageTools_v2.1 folder. Then open T760-AdvUpdater folder and open update.exe. In that select the files as shown in the attached image. All the selected files must be the files located in the temp folder. After that turn off your tablet and connect it by pressing 3 buttons at the same time press on/off button. Now the device will detect as RK29 device, install the necessary drivers for that. Then check whether the device detected by update.exe as Found RKAndroid rock usb. After that click on EraseIDB and the click run. Wait for few minutes till it get completed. And then remove tablet from pc and turn on. It will get 5 to 10 minutes to fully load.... That's all.............. | |
The Following 2 Users Say Thank You to ashamsu For This Useful Post: |
05-16-2013, 09:26 | #42 (permalink) | |
it says unknown device. Need usb driver | |
05-16-2013, 10:09 | #43 (permalink) | |
Dear Member... Check the properties of unknown device, whether it shows vendor id & device id properly.... search by vendor id & device id or search in this link... Welcome | www.topnotchtablets.com Welcome! | Rockchip Firmware | |
05-17-2013, 06:44 | #44 (permalink) | |
Is this driver problem? | |
