12-17-2013, 19:16 | #32 (permalink) |
No Life Poster Join Date: May 2003
Member: 28004 Status: Offline Sonork: 100.1601142 Thanks Meter: 770 | can anyone help how to update the firmware of HCL V1 Connect2G ? there is no sd card update file for this set ... only mptool can update this set but donno how //// plz help ... |
01-01-2014, 12:07 | #34 (permalink) |
Freak Poster Join Date: Apr 2012 Location: india gkp
Member: 1742275 Status: Offline Thanks Meter: 56 | 100% done hcl connect 2.0 after flasing process done on your tab then insert cable its asking for turn on usb you just clik on battery meter your setting will show now you go to deplopment and on the debbung and use mirecle box in android tab tick on wipe data thats all 100% reset your tab |
01-14-2014, 12:37 | #35 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Nepal
Member: 622060 Status: Offline Thanks Meter: 37 | hello i am also facing this problem in hcl v1 me tablet i hav downloaded firmware from support but when try scaning in "NandMPTOOL" always getting "No vimicro disk connected" message please give me solution brother |
01-19-2014, 18:15 | #37 (permalink) | |
Junior Member Join Date: Nov 2013
Member: 2071490 Status: Offline Thanks Meter: 2 | Quote:
the tablet will not start but a disk named VDfu will appear. here you go its in download mode, in MPTool setttings make auto reset=yes, the reason for this is to reboot after flashing, then click download to start flashing, if(you get an error like please check NAND PARAM inifiles) { then click on settings,then change the "NANDType" to available choices, number by number and press download, this must solve the problem, } else { Download success, You need to press the THANKS button. } A ThAnKs Will make my day, INCaSe If I Helped in AnYWaY... | |
The Following 2 Users Say Thank You to exceptionalkhan For This Useful Post: |
02-11-2014, 10:36 | #38 (permalink) |
Junior Member Join Date: Jan 2014
Member: 2100127 Status: Offline Sonork: molnisky.com Thanks Meter: 1 | hcl-me-tablet-v1-connect-2g hard reset solution 100% solution 1) press vloum down and press power botton 2) show android logo 3) press volum down and up kea and power kea 5/10 time see recovery menu |
03-06-2014, 08:06 | #40 (permalink) | |
No Life Poster Join Date: Apr 2008 Location: gsmsolution Age: 34
Member: 755480 Status: Offline Sonork: 100.1609798 Thanks Meter: 233 | Quote:
here is tutorial Y1_Image_Update_Process - Download - 4shared | |
03-19-2014, 20:35 | #41 (permalink) |
Freak Poster Join Date: May 2011 Location: india
Member: 1574148 Status: Offline Sonork: robingarg23 Thanks Meter: 9 | thANKS prawanandpandey ur method ok after andriod logo press up and power many time and try it show factory reset option......... |
The Following User Says Thank You to robingarg23 For This Useful Post: |
05-10-2014, 13:53 | #44 (permalink) |
Junior Member Join Date: Jun 2009
Member: 1052584 Status: Offline Thanks Meter: 1 | hcl-me-tablet-v1-connect-2g hard reset solution 100% solution 1) press vloum down and press power botton 2) show android logo 3) press volum down and up kea and power kea 5/10 time see recovery menu good job 10000000000% working tested by me |
