how to hard reset Intex iBuddy Connect : Tablet/Slate PCs hi friend plz help me how to hard reset Intex iBuddy Connect : Tablet/Slate PCs |
how to hard reset Intex iBuddy Connect : Tablet/Slate PCs hi friends plz help me how to hard reset Intex iBuddy Connect : Tablet/Slate PCs |
dear try this method,may helps you |
any body help me intex buddy connect tablet how to remove google account . |
if not success check this username :- INTEX password :- INTEX@123 http://www.intextechnologies.com/web...rDownload.aspx br, azam:) |
PRES VOLUME UP + LOCK KEY + POWER SWIRCH = HARD RESET MENU :D :D :D :D :D http://i1166.photobucket.com/albums/...Photo-0033.jpg http://i1166.photobucket.com/albums/...Photo-0034.jpg |
If the factory reset process doesn’t fix your problems – or doesn’t work at all – it’s likely that there’s a problem with your device’s hardware. If it’s still under warranty, you should have it fixed or replaced. (There’s one exception to this: If you’ve been flashing custom ROMs and messing with your device’s low-level software, it’s possible that you could have overwritten the stock recovery software. In this case, it’s possible that you have a software problem and not a hardware problem.) |
I SUCCESS FULLY REMOVED GOOGLE LOCK AFTER FLASH http://img854.imageshack.us/img854/3539/ibuddy.png BRO, PRASAD |
hello sir. what kind of program do you used to do that. im having problem with my intex ibuddy connect. can you teach me? thanks in advance. i mean how do i flash my ibuddy connect? i already have the file: "DZHW-A760-iBuddyConnect-A-20130110" from intex website. what do i have to do with it? what program is needed to flash my device? thank you very much sir. |
my this tab android logo show after reset here i am need flash tools or how select file please help brother |
flash tool intex ibuddy c0nnect i need intex ibuddy connect tool.help me sir @ vaghubha sodha |
Intex ibuddy connect successfully hard reset, stuck on Pattern lock Method: connect ibuddy tablet into Pc, on Gmail username and password condition, install drivers. download this tool: Android Multi Tools_1.0 By azimbahar ( One-Man) Parvez now once drivers are install. Run this tool and select 5 (Wipe Data) from the given options. your tablet will reboot. once it is done change the Language from Setting from Chinese to English. Enjoy.. |
thanx sir [QUOTE=vaghubha_sodha;9448259]but sir how to download intex ibuddy connect firmware intex username and password wrong |
[QUOTE=manpreet.misson;9535406] Quote:
Br, azam |
