Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Intex
Old 03-14-2013, 13:44   #1 (permalink)
Member: 1360016
Sonork: 100.1637900
Thanks Meter: 14
Post how to hard reset Intex iBuddy Connect : Tablet/Slate PCs
hi friend plz help me
Old 03-14-2013, 13:46   #2 (permalink)
Member: 1360016
Sonork: 100.1637900
Thanks Meter: 14
hi friends plz help me
Old 03-14-2013, 13:50   #3 (permalink)
.::TEJARAM::.'s Avatar
Member: 1681461
Sonork: [OFFLINE]
Thanks Meter: 1,011
http://forum.gsmhosting.com/vbb/f606...ablet-1607655/
try
wbr
tejaram
Old 03-15-2013, 12:14   #4 (permalink)
unlockers555's Avatar
Member: 547368
Thanks Meter: 254
dear try this method,may helps you
Old 04-01-2013, 16:55   #5 (permalink)
rajakhank3's Avatar
Member: 1042104
Sonork: 100.1609232
Thanks Meter: 216
any body help me intex buddy connect tablet how to remove google account .
Old 04-03-2013, 10:28   #6 (permalink)
..::Nokian CareŽ::..'s Avatar
Member: 505794
Sonork: 100.1627614 QQ:1958018248
Thanks Meter: 2,266
try to do with Android Multi tool
if not success check this
username :- INTEX
password :- INTEX@123
http://www.intextechnologies.com/web...rDownload.aspx
br,
azam
Old 04-05-2013, 15:06   #7 (permalink)
rajasekar's Avatar
Member: 503989
Thanks Meter: 71
PRES VOLUME UP + LOCK KEY + POWER SWIRCH = HARD RESET MENU
Old 04-16-2013, 02:45   #8 (permalink)
Member: 419703
Thanks Meter: 123
If the factory reset process doesn’t fix your problems – or doesn’t work at all – it’s likely that there’s a problem with your device’s hardware. If it’s still under warranty, you should have it fixed or replaced.
(There’s one exception to this: If you’ve been flashing custom ROMs and messing with your device’s low-level software, it’s possible that you could have overwritten the stock recovery software. In this case, it’s possible that you have a software problem and not a hardware problem.)
Old 05-01-2013, 16:26   #9 (permalink)
cellcare prasad's Avatar
Member: 602547
Sonork: 100.1621466
Thanks Meter: 930
I SUCCESS FULLY REMOVED GOOGLE LOCK AFTER FLASH
BRO,
PRASAD
Old 05-02-2013, 09:36   #10 (permalink)
Member: 1929002
hello sir. what kind of program do you used to do that. im having problem with my intex ibuddy connect. can you teach me? thanks in advance.
i mean how do i flash my ibuddy connect? i already have the file: "DZHW-A760-iBuddyConnect-A-20130110" from intex website. what do i have to do with it? what program is needed to flash my device? thank you very much sir.
Old 05-24-2013, 08:11   #11 (permalink)
Member: 823633
Thanks Meter: 1,705
BRO,
PRASAD
please
my this tab android logo show after reset here
i am need flash tools
or how select file
please help brother
The Following User Says Thank You to vaghubha_sodha For This Useful Post:
Old 05-31-2013, 10:43   #12 (permalink)
Member: 883301
Sonork: 100
Thanks Meter: 12
flash tool intex ibuddy c0nnect
i need intex ibuddy connect tool.help me sir @ vaghubha sodha
The Following 2 Users Say Thank You to devratnamaharja For This Useful Post:
Old 06-18-2013, 14:40   #13 (permalink)
Member: 1465041
Intex ibuddy connect successfully hard reset, stuck on Pattern lock
Method:
connect ibuddy tablet into Pc, on Gmail username and password condition, install drivers.
download this tool:
Android Multi Tools_1.0 By azimbahar ( One-Man) Parvez
now once drivers are install. Run this tool and select 5 (Wipe Data) from the given options. your tablet will reboot. once it is done change the Language from Setting from Chinese to English.
Enjoy..
Old 06-29-2013, 13:01   #14 (permalink)
Member: 1969313
thanx sir
[QUOTE=vaghubha_sodha;9448259]but sir how to download intex ibuddy connect firmware
intex username and password wrong
Old 06-29-2013, 13:07   #15 (permalink)
Member: 505794
Thanks Meter: 2,266
[QUOTE=manpreet.misson;9535406]
download intex firmware, tools & driver from this link ftp://202.56.124.186/drivers/Mobiledrivers
Br,
azam
The Following 2 Users Say Thank You to ..::Nokian CareŽ::.. For This Useful Post:
Page generated in 0.24356 seconds with 8 queries
