04-10-2014, 15:47 | #8 (permalink) |
Junior Member Join Date: Apr 2014
Member: 2165430 Status: Offline Thanks Meter: 0 | Tablet PC "Reef" Netxeon_R744_V3.0_20130114 Rockcip RK2928 Hynix h27ubg8t2btr-bc Elpida j2108bdbg HC-7000 600*800 OS version: Android 4.1 CPU: Rockchip RK2928 Processor Speed (max): 1GHz RAM: 512MB WiFi: 802.11 b/g/n 0.3 Megapixel Front-Facing Camera Battery Size: 3000mAh Display size: 7 inch Display resolution: 800x480 Internal: 4GB Micro SD card up to 32GB Ports 3.5 mm audio out port, Mini USB Port, Micro SD card slot, Mic, Speaker, HDMI port, DC In |
07-27-2014, 23:48 | #10 (permalink) |
Junior Member Join Date: Dec 2004
Member: 99735 Status: Offline Thanks Meter: 0 | Dears, I have the same model i-nix NTB-700 with the same board mentioned above, I'm facing SOD issue and after a lot of searching I found that is from Kernel, Kernel version that I have 3.0.36+ lfk_V_110j1 #26 I success to dump the whole rom and pack it as an IMG file for who need it to recover his tablet via Rockchip batch rom if needed, for the time being if anyone can help me by dump his kernel in order to replace mine I'll be really great full, Thanks |
03-10-2015, 06:26 | #13 (permalink) |
Junior Member Join Date: Sep 2014 Location: Russia Bashkortostan
Member: 2262616 Status: Offline Thanks Meter: 0 | TurboPad 700 software search software Rockchip RK-2928-G netxeon_R744_V2.0_20121121 not loaded. When you connect is determined by: USB \ VID_2207 & PID_292A & REV_0100 USB \ VID_2207 & PID_292A RK292X Device |
