01-07-2015, 07:34 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: (United States Of Islam) Age: 37
Member: 399832 Status: Offline Sonork: Faheem Anjum Thanks Meter: 24,310 | [PhoenixUsbPro] Flashing Tutorial for Allwinner A23 CPU devices - Stock firmware ROM* - PhoenixSuit Key* - PhoenixUSBPro* (Even if people keep calling it PhoenixSuit, thats its name when you install it) - Semi-bricked Tablet* (Stuck on Logo, Cant enter recovery, etc.) - Windows XP x86 or Windows 7 x86 / x62 * - Patience** This is a READ FIRST and READ-WHILE-ON-IT tutorial, Make sure to READ IT FIRST and then you can read it while youre doing it. If you attempt to do it while youre reading it without reading it first you'll be propense to make tedious mistakes. Let's get on it. Install PhoenixUSBPro and once its installed, open it. Phoenix is just like livesuit but they have a bigger interface, youll see the task buttons on top: Key file | Image | Debug View | Start | Help | Update | Exit | []reboot below it shows your USB Hub status (internal and external) and on the right side theres a box to hold your failed or succededly flashed devices. DONT connect your tablet yet. Press the key file button and navigate to where your Key file is and double click on it to select it. Press the Image button and navigate to where your *.IMG Stock firmware rom file is and double click on it to select it. Youll see a (X) red Icon on the right. Dont mind it yet. DONT connect your tablet yet. Press Start. The red Icon should have turned to GREEN. If it didnt, something went wrong, they key file or the *.IMG rom file are damaged, corrupted, downloaded wrong or they are invalid. Search for a working ROM or start again the tutorial. (Most of the times it should do just fine). after the Icon has turned green, we are ready to connect our device. First connect your USB Cable to your computer and leave your tablet disconnected Make sure your tablet is completely turned off. Before connecting your tablet, press the Volume+ button (or search your device's FEL Button on google / Linux-sunxi) for the Q88Pro, and Q8H is Volume+, probably for others the same. Ok, Hold the Volume+ button pressed down and connect your USB Cable to your Tablet (While holding the Volume+ button down). Right after connecting your USB Cable into your tablet (without releasing the Volume+ Button) Start pressing your POWER button repeatedly, One time every second. At the sixth time (for some devices you need to press it 10 times or more) it will pop in your USB Hub interface box a device. Wait a few and it will appear your connected tablet. It will say: Your device's queued ID and the process percent. Mostly starts fast til 7% and then it continues to 53% then it does the job. It'll take about 2"5 mins so be patient I know you want your tablet restored. After its done it will appear on the right box if it succeeded or failed and the time the flashing took. now you can press Stop and disconnect your tablet. In the FEL Mode, even if your tablets screen is deep black, it might be still turned on. So firstly try to turn it on normally holding your power button for about 3 to 5 seconds, if nothing seems to happen you need to force-shutdown first, for it: hold your power button for about 10 to 15 seconds. After that your tablet should be powered down, proceed to turn your tablet on. VOILA!!, good work guys.! Download Link - http://forum.gsmhosting.com/vbb/f906...lease-2003564/ Last edited by aZimBahar; 10-19-2015 at 07:23. |
The Following 15 Users Say Thank You to Faheem Anjum For This Useful Post: |
01-07-2015, 09:02 | #2 (permalink) |
Moderator Join Date: Mar 2011 Location: metasploit Age: 31
Member: 1537689 Status: Offline Sonork: 100.1669550 Thanks Meter: 2,219 | phoenixusbpro flashing guide for new user Faheem Anjum already post compleat guide Here im adding something for new user with pic 1st Downlod Letest Flasher From here : ****************************/folder/x4o...%26_phonixcard NT: Letest Phonixcard also can flash a23 available on following link Here we go Phoenixusbpro flashing guide : 1. open phoenixusbpro folder and open PhoenixUSBPro.exe [for win 7 user run as Adminishtrator ] [IMG]****************************/convkey/4f7b/w1ko3mtayg9x5ig6g.jpg[/IMG] 2.Click no key bottom from top [IMG]****************************/convkey/1efb/6dkalr7s12hor116g.jpg[/IMG] 3. select key file from phoenixusbpro key folder [ only for 1st time farther when you use it will auto detect key file ] [IMG]****************************/convkey/d4df/0lzzpavrfr7i0h56g.jpg[/IMG] 4.now click to image button and select downloded firmware [IMG]****************************/convkey/531b/2475tzeqr7dvjrz6g.jpg[/IMG] [IMG]****************************/convkey/f0af/2t8who73joltyaz6g.jpg[/IMG] 5.now after select image click to start button [IMG]****************************/convkey/3b76/aid7v5ltfm7hm326g.jpg[/IMG] 6.after select start you will see a green trick mark at and of left side this mean all ok you are ready to flash your tablet [IMG]****************************/convkey/9806/37bfhsg0ae9r12u6g.jpg[/IMG] 8.final stage you have to force tablet in flash mode by key combintions [its same as livesuit flashing stage ] HOLD on vol + or - key then connect usb to tablet and quickly keep pressing power button few times 10-15-20 you will see flashing process started software will detect your tab usb and wait for finished massage [IMG]****************************/convkey/bfe1/1rk6qll4ji995nm6g.jpg[/IMG] All done now disconnect and power on your tablet .......... Last edited by Rahul_Bhutani; 01-07-2015 at 13:41. Reason: User Request / Flasher Link Updated |
The Following 18 Users Say Thank You to gsm mithun roy For This Useful Post: |
02-23-2015, 07:53 | #3 (permalink) |
Member: 1537689 Status: Offline Sonork: 100.1669550 Thanks Meter: 2,219 | phoenixusbpro v.3.3.4 comes with chines language all is same like other version here is little video for newer who seems problem with new version |
The Following 6 Users Say Thank You to gsm mithun roy For This Useful Post: |
03-27-2015, 20:10 | #6 (permalink) |
Crazy Poster Join Date: Dec 2013 Location: Harare, Zimbabwe
Member: 2076822 Status: Offline Thanks Meter: 2 | can someone send me the Link in .7z compressed format so that i can download because my Internet Service Provider is Blocking the .rar, .zip, .exe file extensions from being downloaded |
The Following User Says Thank You to computer expert For This Useful Post: |
03-28-2015, 06:54 | #7 (permalink) | |
Member: 1537689 Status: Offline Sonork: 100.1669550 Thanks Meter: 2,219 | Quote:
nothing without .rar here | |
The Following User Says Thank You to gsm mithun roy For This Useful Post: |
05-09-2015, 21:13 | #10 (permalink) |
Freak Poster Join Date: Feb 2011 Location: ALGERIA Age: 43
Member: 1513870 Status: Offline Thanks Meter: 46 | good after non mr gsm mithun roy what version is good to download 3.0.1 or 3.3.3 or 3.3.4 i mean key file work also in 3.3.3 and 3.3.4 |
The Following User Says Thank You to sgreenphone For This Useful Post: |
05-10-2015, 06:40 | #11 (permalink) |
Member: 1537689 Status: Offline Sonork: 100.1669550 Thanks Meter: 2,219 | 3.3.4 kay file available inside 3.3.4 flasher folder....! |
The Following 2 Users Say Thank You to gsm mithun roy For This Useful Post: |
07-23-2015, 08:31 | #13 (permalink) |
Product Supporter Join Date: Jul 2011 Location: ISLAMIC & INDIA WITH MIRACLE T Age: 37
Member: 1617868 Status: Offline Sonork: 100.1625996 Thanks Meter: 2,028 | Funtab f722 pattern unlock this phoenixusbpro flashing MY 1ST A23 CPU FLASHING phoenixusbpro MANY TAB FLASH A10/A13 CPU LiveSuit.exe BUT A23 CPU NOT SUCCESS ERROR INVALID IMAGE FILE FUNTAB F722 PHONE Tablet (7 Inch, 8 GB, 2G, Black) [/SIZE] THANK TO TOOL LINK OR post compleat guide gsm mithun roy No Life Poster |
The Following 2 Users Say Thank You to .::THE ROCK::. For This Useful Post: |
