Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Android based Phones / Tablets > Android Tablets
Old 10-25-2013, 08:09   #16 (permalink)
nathan111284's Avatar
Member: 1370010
Thanks Meter: 53
I need exact firmware for next700 r
ockchips rk2928-g
Old 11-11-2013, 04:34   #17 (permalink)
Member: 2063071
Rockchip rk2928-g
Please help me with my easytouch tablet pc. It was pattern locked and i can't connect it to internet since it's wifi connection was turned off. Pls send me links to where i can download the drivers of my tab. Need it asap plssss.
Old 12-11-2013, 07:53   #18 (permalink)
Member: 1529452
Sonork: 100.1637909
Thanks Meter: 44
mitashi play be 141 2g firmware need
Hardware:rk2928board
Board:rk2928sdk
CPU ABI:armeabi-v7a
Manufacturer:rockchip
Model:TSINTECH
Android Ver:4.1.1
bootloader ver:unknown
USB config:mass_storage,adb
User:wangzeng
Baseband ver:BASE_10A.W11.48_V023,BASE_10A.W11.48_V023
Build number:JRO03H
IMEI1: 91+++++++++++++
Root: Not Root
>>Done
Old 12-15-2013, 17:55   #19 (permalink)
Member: 2085317
Hello All
I HAve SAme Proplem But With Haier tablet 7 Inch ( HR-Q70RL ) ANd its Not Working With ANy Format Programs If Any One Can Help Please Share Your Answer
Thanks Alot
Old 12-16-2013, 08:05   #20 (permalink)
eng imran's Avatar
Member: 1640158
Sonork: 100.1615555
Thanks Meter: 129
Originally Posted by wessam_a7med View Post
Hello All
Thanks Alot
try this and post result ??
https://dl.dropboxusercontent.com/u/...HC20130419.rar
Old 12-21-2013, 17:10   #21 (permalink)
Member: 2089431
Tengo una tablet sunstech tab700 no hay manera de encontrarle un firware que sea comptible con rockchip 2928-g arm cortex a8 ayudarme porfavor
Old 12-23-2013, 06:49   #22 (permalink)
Member: 1181277
Thanks Meter: 13
mitashi be 141 2g pattern lock plese help me sir.
its rockchip rk2989g...
Old 12-23-2013, 07:10   #23 (permalink)
Faheem Anjum's Avatar
Member: 399832
Thanks Meter: 23,735
Use this method :http://forum.gsmhosting.com/vbb/f606...t-adb-1717216/
The Following User Says Thank You to Faheem Anjum For This Useful Post:
Old 01-31-2014, 17:46   #24 (permalink)
INGSOFT-GSM's Avatar
Member: 1075477
Sonork: 1622970
Thanks Meter: 31
want rockchip RK2928 Flash file plz help me
For patern lock tablet UTECH UM-770
Tablet UTECH UM-770
CPU: ARM Cortex A9 (Rockchip 2928), speed: 1.O Ghz
Display: 7" TFT LCD Panel, with Multi-point capacitive touch panel
Panel Resolution : 800x480ECH
OS: Android 4.1.1
RAM: DDRIII 1GB
Nand Flash: 4G
Memory Expansion : support TF card solt in (max 32GB supported)
Camera 0.3 Mega Pixel
HDMI output Yes
Wifi
please i need key combination or rom to flash
Old 02-02-2014, 18:33   #25 (permalink)
Member: 2119033
Sarfraj did you get any solution??
Board:rk2928sdk
CPU ABI:armeabi-v7a
Model:TSINTECH
Android Ver:4.1.1
User:wangzeng
Build number:JRO03H
Root: Not Root
>>Done
Any solution you got? Me stuck with multiple attempt for pattern unlock and tab is locked!!!!. No way to flash and factory reset as no recovery mode on BE 141 2g!!!
Old 02-12-2014, 13:25   #26 (permalink)
Member: 812734
Smart Tablet Firmware
Hi Everyone
Can you please help me find the firmware of this tablet please ?
Heres the references
Smart Tablet
SMTAB-710
Rockchip RK2928-G
Motherboard CH-1 E334023 94V Rohs
Please Help
Old 03-13-2014, 13:09   #27 (permalink)
Member: 1656636
Rockchip atouch a712-2g
Pleas lelp firmwar atouch a712-2g
Old 04-22-2014, 14:29   #28 (permalink)
Member: 1823065
Tablet UTECH UM-770
OS: Android 4.1.1
RAM: DDRIII 1GB
Nand Flash: 4G
HDMI output Yes
Wifi
Hello I am from Venezuela just like I repair a tablet with a program that i found in this same page called Faheem Anjum Tools v1.1
Old 06-14-2014, 09:25   #29 (permalink)
Member: 2194161
Sonork: 100.1656642
want firmware for Rockchip 2928-g for icq tablet,tsintech mo model
Old 07-03-2014, 16:47   #30 (permalink)
Member: 178564
Thanks Meter: 3
rockchip
sierra
model no sr-t7120 firmware need
Page generated in 0.39482 seconds with 7 queries
