Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Android based Phones / Tablets > Android Tablets
Old 06-23-2013, 15:08   #1 (permalink)
nafe2me's Avatar
Member: 977479
Sonork: 100.1638508
Thanks Meter: 423
Simmtronics Xpad X801 Hard reset done
Pls follow below steps to Hard reset the Xpad X801…..
1. Connect the Charger to the Tab.
2. Power off the device (Push Reset key if device is in hanged state)
3. Press volume- & hold it
4. Now press power key for 2-3 min. You will get below screen,
& after that below screen
Pls press Vol+ & Vol- Keys to move up & down. You need to select “Wipe data/Factory Reset”
& Press “power key”
Select “delete all user data” & push the Power key.
Will get below screen
Select “reboot system now” & Push the Power key.
& you are done......
Old 10-02-2013, 05:44   #2 (permalink)
sanjai6's Avatar
Member: 1821459
Sonork: 1636390
Thanks Meter: 55
Simmtronics Xpad X802 Tablet hard reset done
Simmtronics Xpad X802 Tablet hard reset done first switch on tablet next press volum {-} key press hold two key android logo show. next press up key wipe data show .........................
The Following 3 Users Say Thank You to sanjai6 For This Useful Post:
Old 01-23-2014, 15:24   #3 (permalink)
Member: 998763
how to put fast boot mode xpad x722
Old 01-23-2014, 15:37   #4 (permalink)
Member: 998763
how to remove pattern lock xpad x772 vai multi tool step by step...plzzzzzzzz
Old 01-23-2014, 15:48   #5 (permalink)
Member: 998763
step by step how to remove patter lock x pad x722 via multi toolll
Old 02-20-2014, 16:40   #6 (permalink)
Member: 1574148
Sonork: robingarg23
Thanks Meter: 6
plz tell how to remove pattern lock xpad x722 by android tool
or other plz help?
Old 02-27-2014, 04:55   #7 (permalink)
Member: 1279370
friends Simmtronics XPAD X722 pattern lock solve by volcano box with android tool.
Old 04-22-2014, 12:40   #8 (permalink)
haroon008's Avatar
Member: 2062801
Thanks Meter: 41
how to hard reset
Simmtronics XPADx722 hard reset
Old 04-22-2014, 13:18   #9 (permalink)
cellularry's Avatar
Member: 42276
Thanks Meter: 47
hello,
Anyone can help with hard resetting Xpad Q5.
thanks,
Old 04-30-2014, 10:41   #10 (permalink)
cellularry's Avatar
Member: 42276
Thanks Meter: 47
& Press “power key”
appreciate if you can help with Q5 hard reset
The Following User Says Thank You to cellularry For This Useful Post:
Old 09-20-2014, 06:18   #11 (permalink)
Member: 2177930
Sonork: 1658657
Please Help.......
How to reset Xpad smartphone Q5...
Old 10-27-2014, 07:07   #12 (permalink)
mahzra azra's Avatar
Member: 1722956
Sonork: mybestfriend.adeel
Thanks Meter: 295
Originally Posted by moktarctgm View Post
Please Help.......
i also need solution of q5 pattern lock---
how to root ?
its a spd 6820 but something is differ from other 6820 set becouse it does not formate with any tool. every tool connect it easily but no one can do root.
thanks.
Old 10-27-2014, 07:42   #13 (permalink)
Member: 1722956
Thanks Meter: 295
i done it my self--
1--- connect it mannualy with miracle box with this cable----
after select button it show port in your device manager---
tick on formate tab and push start button.
set will be formated---
after format set look it---
if you like my post press thanks button.
The Following User Says Thank You to mahzra azra For This Useful Post:
Old 11-04-2014, 06:30   #14 (permalink)
Member: 737752
Thanks Meter: 8
SIMPEL treeck
Now press power key for but on
Old 11-05-2014, 11:58   #15 (permalink)
Member: 1722956
Thanks Meter: 295
SIMPEL treeck
bro this solution is for q5 modles.not for x801. look it deeply.
Page generated in 0.36513 seconds with 7 queries
