11-14-2013, 14:33 | #1 (permalink) |
Junior Member Join Date: Nov 2008 Location: indonesia - medan Age: 42
Member: 912321 Status: Offline Thanks Meter: 1 | tablet mytab 4gb cpu wm8850 need frimware in back cover : My Tab made by iD. Taiwan Technology cpu WM8850 ( 1228CB TAIWAN 2RA1011200TCM in board text : W70_V10 2012.08.04 this tab stuck in android logo Last edited by johaneshu; 11-14-2013 at 14:43. |
11-14-2013, 17:35 | #2 (permalink) |
No Life Poster Join Date: Apr 2010 Location: Pilipinas
Member: 1284799 Status: Offline Sonork: 100.1649097 Thanks Meter: 138 | W70-1.5.5-1680-NO-WIN8-1.10.zip search for instructions first before using this rom. |
The Following User Says Thank You to dust2dust For This Useful Post: |
11-15-2013, 12:03 | #4 (permalink) |
Member: 912321 Status: Offline Thanks Meter: 1 | bro .. I've downloaded the room you give, after that I was an extra and copy the file to the mmc, insert it into the tablet and on it. successful and managed to get into the tablet display, problems arising now my touch screen does not work. whether there is room or another frimware, which approximately matches the model of my tablet I sincerely hope |
11-15-2013, 14:59 | #6 (permalink) |
Member: 1284799 Status: Offline Sonork: 100.1649097 Thanks Meter: 138 | as i said search for instructions b'coz you need to edit something inside the config folder. dismantle your tab and look for touch ic number, then go to folder FirmwareInstall you will see another folder "config". see if theres a file with your touch screen ic number. select and rename just adding positive sign "+" at the first line. ensure that there is only one file that has a "+". |
11-17-2013, 12:50 | #7 (permalink) | |
Member: 912321 Status: Offline Thanks Meter: 1 | Quote:
I've tried a few files. FWC, and I found a file that can work in my toch sceern E_MID7_W70_EKTF2127_ZCC1943_A I find this file on WM8850_Universal_Uberoid_v2.0_JB_4.1.1_08APR2013 problems that I found on my tablet is after successful update tab frimwarenya first loding ok tp after restart my tab loding in recovery mode I think my tablet is not compatible with 4.1.1 JB tp cock with JB 4.0 I try to add the file in the config folder by adding a "+" in front of the file name, but after I sceern toch update does not work anymore Nobody knows the solution by adding. FWC jb 4.1.1 to jb 4.0 I really hope someone can help this problem | |
