08-21-2014, 08:48 | #1 (permalink) |
Freak Poster Join Date: May 2013 Location: India - Gujarat
Member: 1934308 Status: Offline Sonork: 100.1640317 Thanks Meter: 105 | Touch Fix For Allwinner A13 v.1.0 Touch Fix For Allwinner A13 v.1.0 This image shows the 'adb devices' command output in the log text. This image shows the 'script.bin' file loaded in the memo text, and combos to change the variables values. - Use the 'check devices' button to see your device stats as performing 'adb devices' - Use 'get script.bin' to get your A13 script.bin file, convert it to script.fex and extract current variables values - Use 'update variables' to update variables values in the script.fex file loaded in memo text - Use 'update script.bin' to save the loaded script.fex in script.bin, and put this file in your A13. The original script.bin file of your A13 will be renamed to script.old The application (c++ builder 2009 source code included) can be found here: Download From HERE |
08-21-2014, 09:18 | #3 (permalink) |
Moderator Join Date: Mar 2011 Location: metasploit Age: 31
Member: 1537689 Status: Offline Sonork: 100.1669550 Thanks Meter: 2,219 | the method really dosen't clear to me is this tools really work stand alone or need extra script file ts mudles ..... can you describe it little more easy for us how it works how to work ..! |
