Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Android based Phones / Tablets > Android Tablets
Old 12-25-2013, 17:10   #1 (permalink)
kailash_gm's Avatar
Member: 101117
Thanks Meter: 465
ubislate 7c+ tested orignal flash file n flasher
here is my tested orignal flash file n flasher.
easy to flash just use this img file in this link.
live suite which we use in micromax flashing..
here is link of file n flasher
UBISLATE 7C+ Stock and flasher - Download - 4shared - kailash
The Following 4 Users Say Thank You to kailash_gm For This Useful Post:
Old 01-02-2014, 08:01   #2 (permalink)
mohit_kripalu01's Avatar
Member: 486357
Sonork: 100.1602846
Thanks Meter: 1,211
after flash touch not working any touch fix file so plz share
Old 01-02-2014, 08:39   #3 (permalink)
Member: 486357
Sonork: 100.1602846
Thanks Meter: 1,211
here is detail
Old 01-02-2014, 14:52   #4 (permalink)
..::CHAIN::..'s Avatar
Member: 1753928
Sonork: 100.1615906
Thanks Meter: 2,309
Cool
Try With This & Post Result .......
Q75SK30701.img_??????|??? ??-?????
Regards,
Old 01-02-2014, 15:38   #5 (permalink)
Member: 486357
Sonork: 100.1602846
Thanks Meter: 1,211
Regards,
whats is this bro Q75SK30701.img 574.68mb file
Old 01-02-2014, 18:17   #6 (permalink)
Faheem Anjum's Avatar
Member: 399832
Sonork: Faheem Anjum
Thanks Meter: 23,907
there is 2 method you can apply one of them both working and tested
- A working ROM Link [Password: esandroid]
- Flashing Program Link
- A Memory Card of atleat 512 MB
- A PC/Laptop.
Flashing Instructions
1) Extract PhoenixCard.rar by using Winzip or Winrar.
2) And extract it into same folder where the PhoenixCard is extracted.
3) Take a micro SD card and format it.
4) Insert the SD Card into laptop or PC by using SD Card jack.
5) Double click on PhoenixCard app into the folder of PhoenixCard.
6) A window will open and in the disk Box, select the Drive of your SD Card.
7) Now click on img File and select the Downloaded ROM IMG file.
8) Then click on Burn button. And it will show you some processing.
9) After completion this processing exit phoenixCard app and remove the SD Card from laptop/PC.
10) Switch of your device and insert that SD Card into the device and turn it on.
11) It will shows a progress bar on the centre of the display after completeion of his bar click ok and remove SD Card.
12) Start the device as normal.
2nd one here
Flash File of Ubislate 7c+ find it first on >>> Ubislate7C+
what you need :
Ubislate 7C+ which is stuck on android
Ubislate 7C+ Drivers >>> 32Bit & 64Bit
Cwm recovery for ubislate LINK >>> CWM Recovery
Flash files of Ubislate7C+ LINK >>> Ubislate7C+
Method:
1: Connect the tab to pc n install driver
2: Start the tab n let it show android icon or name
3: Flash Cwm recovery by clicking recovery for ics and follow the instruction
4: Copy the folder in the ubislate7c+ flash file zip to ur sd card
5: Insert the sd card in the Tab.
6: Click reboot to recovery.
7: Wipe data/system 8: Go to backup/restore
9: Restore
10: DONE ENJOY YOU HAVE SUCCESSFULLY FLASH UR TAB
For Those with Forgotten Pattern Lock
Method:
4: Click reboot to recovery.
5: Wipe Data/system & wipe Cache
6: Go to Advance n wipe Dalvik
7: Reboot.
8: DONE ENJOY
The Following 2 Users Say Thank You to Faheem Anjum For This Useful Post:
Old 01-03-2014, 04:06   #7 (permalink)
ranagaurav's Avatar
Member: 907098
Sonork: 100.1601140
Thanks Meter: 695
U have ubislate 7c rom ?
This methed is work on 7c? Plz guide
Old 01-06-2014, 15:27   #8 (permalink)
Member: 486357
Sonork: 100.1602846
Thanks Meter: 1,211
- A PC/Laptop.
2nd one here
what you need :
Method:
9: Restore
Method:
7: Reboot.
8: DONE ENJOY
1st Method success touch working but camera or wifi not working
2nd Method give error restore faild
Old 01-18-2014, 10:38   #9 (permalink)
Member: 205176
Thanks Meter: 19
i m try 1st methode flash succes but touch don't work 2nd link not working
Old 02-08-2014, 16:30   #10 (permalink)
Member: 1684564
Thanks Meter: 23
thamkx sir
- A PC/Laptop.
2nd one here
what you need :
Method:
9: Restore
Method:
7: Reboot.
8: DONE ENJOY
thankx sir but cam and wifi prob.........but my custmr is hapy.... thankx sir any otther solution cam and wife .?
Old 08-11-2014, 07:19   #11 (permalink)
Member: 953066
Thanks Meter: 7
ubislate7c+ tab
just win data showing and hang,
sprite update error: fail to scan flash infomation
sprite update error: current card sprite failed
now hold the machine
showing this matter how to solve problem
Old 09-19-2014, 14:15   #12 (permalink)
Member: 2260206
Compatibility Issue
Hello Kailash,
I appreciate the good work that you've done for the older ubislate devices here. I own the new Ubislate 7C+ EDGE tablet which is based on the A23 Family with a dual core cortex A7 processor clocked at 1.2 Ghz. Will my device be compatible with the ROM that you've provided?
Old 12-19-2014, 14:32   #13 (permalink)
Member: 1510675
Sonork: 100.1640264:vivek
sir where are rom img file select by me help me
Old 04-29-2015, 07:04   #14 (permalink)
Member: 1847344
Thanks Meter: 294
all will be ok
just flash only 7c+ type 5
here is link Welcome to the ./downloads/Datawind (Courtesy of Mr fcuker)/7C Plus Edge/ folder of GsmHosting support area
Old 06-11-2015, 14:04   #15 (permalink)
Member: 2364517
Sonork: 100.1648530
Thanks Meter: 9
ubislate 7c+
aakash3 tab a13 allwiner cpu after flash blank imei& cam not work
pls give me right flash file
Page generated in 0.46230 seconds with 7 queries
