10-13-2013, 07:55 | #1 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Pakistan
Member: 226457 Status: Offline Sonork: No more used Thanks Meter: 14,934 | VRoot 1.7.0 - 1-Click Root Method mostly All andriod phone not metter which brand VRoot 1.7.0 - 1-Click Root Method mostly All Android phone not matter which brand and which modal Supported devices:lot of devices up to Android 4.x (4.0~4.3) download this software http://www.mediafire.com/download/v3...3690_Setup.exe after this software will be auto update to 1.6.- producer for install because chines language so i post all step Next. Don't create start menu. (as you wish) Create desktop icon. Finish. Uncheck if you dont want to start the rooting app now. after this open software and connect phone(must enable usb debugging) then click on Root during root phone will be restart note:after root superuser will be display in English language not in chines more shocking news on the way BR Qaisar Mahmood |
The Following 86 Users Say Thank You to Qaisar Mahmood For This Useful Post: |
10-13-2013, 08:11 | #2 (permalink) |
Freak Poster Join Date: Jun 2013 Location: In Pakistan
Member: 1956298 Status: Offline Sonork: 100.1626680 Thanks Meter: 29 | vv thanks for this useful information but try to change Chines 2 english in next update Last edited by ..::Nokian CareŽ::..; 10-13-2013 at 09:49. Reason: quote removed |
10-13-2013, 08:42 | #4 (permalink) |
No Life Poster Join Date: Jan 2009 Location: Root tunnel Age: 36
Member: 952111 Status: Offline Sonork: I'm not using now. Thanks Meter: 713 | Seems good.. But what If we already got 3.. 1-Srs Root (freeware) 2-UnlockRoot Pro (Paid bu you can google :P ) 3-Volcano Box One key Root(Many times Solved my problems) In that case what is the specialty of above software even it is in Chinese... |
10-13-2013, 09:31 | #6 (permalink) |
Freak Poster Join Date: Jul 2006 Location: Russia N.Novgorod Age: 46
Member: 319131 Status: Offline Thanks Meter: 25 | Root_with_Restore_by_Bin4ry_v31 pass: chekm |
10-13-2013, 11:05 | #7 (permalink) |
Freak Poster Join Date: Apr 2012 Location: India
Member: 1751950 Status: Offline Sonork: 100.1615788 Thanks Meter: 25 | VRoot 1.7.0 - 1-Click Root Method mostly All Android phone not matter which brand and which modal Supported devices:lot of devices up to Android 4.x (4.0~4.3) download this software VRoot 1.7.0 letest set link----------- VRoot_1.7.0.3882_Setup |
The Following 6 Users Say Thank You to Abhinav kumar b For This Useful Post: |
10-13-2013, 17:52 | #10 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Barisal Age: 44
Member: 1427033 Status: Offline Sonork: 100.1596688 Thanks Meter: 1,204 | More info about this tools. 1,Rooting app started. This will pop-up. 2,connect your device and you it will get detected. (Make sure USB Debugging is turned ON in your device) Click the Green bottom right button and wait for rooting process to be done. 3,When this shows up, device will reboot, now you can unplug your device. 4. Now you need to install SuperSU from play store to replace the Chinese root manager called 授权管理 1.0.4. 5. Go to play store and install SuperSU. 6. Start SuperSU and you will be asked for permission by 授权管理 1.0.4, choose 允许(means allow). (Should be the right side option.) 7. SuperSU will prompt to install SU binary, go ahead with OK and it will display successful. 8. Now, freeze 授权管理 1.0.4 in titanium backup, just in case you need it again. Note: If you uninstall straight away from app manager, you need to make sure SuperSU updated the binary. 9. Re-run SuperSU to make sure everything is alright. You will be prompt again to install SU binary, just do what it asked. 10. After that, you are rooted with SuperSU and 授权管理 1.0.4 will not be there anymore. OPTIONAL 11. If you want to be more assured, in SuperSU app, prepare for a Reinstall in settings. (NOT Full unroot NOT Switch superuser app) 12. SuperSU will be removed and go back to play store to re-download and install. 13. Start SuperSU and SuperSU will prompt to install SU binary, go ahead with OK and it will display successful. Thanks for understanding.. Note,Version will be auto meted updet with internet connection.. |
10-14-2013, 07:55 | #11 (permalink) |
No Life Poster Join Date: Mar 2009 Location: earth
Member: 992568 Status: Offline Sonork: kulit Thanks Meter: 231 | after the unit restart during rooting the phone will automatically turn on or it remain in off stage then you put it on manually i try in s5360 after phone turn off Ive waiting some minute but not turn on i manually turn it on but good news phone is rooted |
10-21-2013, 17:47 | #13 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Wales
Member: 332001 Status: Offline Thanks Meter: 58 | i instal old and new version but all time software open error appears and software close in just 10 seconds....... error in chinese language thats why i cant undrstand.... ? i re install many time but always same issue plz give me solution.. |
The Following User Says Thank You to wasim_mobile200 For This Useful Post: |
