Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Android based Phones / Tablets > Android Tablets
Old 10-13-2013, 07:55   #1 (permalink)
Qaisar Mahmood's Avatar
Member: 226457
Sonork: 100.1604561
Thanks Meter: 14,902
VRoot 1.7.0 - 1-Click Root Method mostly All andriod phone not metter which brand
VRoot 1.7.0 - 1-Click Root Method mostly All Android phone not matter which brand and which modal
Supported devices:lot of devices up to Android 4.x (4.0~4.3)
download this software
http://www.mediafire.com/download/v3...3690_Setup.exe
after this software will be auto update to 1.6.-
producer for install because chines language so i post all step
Next.
Don't create start menu. (as you wish)
Create desktop icon.
Finish. Uncheck if you dont want to start the rooting app now.
after this open software and connect phone(must enable usb debugging)
then click on Root during root phone will be restart
note:after root superuser will be display in English language not in chines
more shocking news on the way
Qaisar Mahmood
The Following 86 Users Say Thank You to Qaisar Mahmood For This Useful Post:
Old 10-13-2013, 08:11   #2 (permalink)
Member: 1956298
Sonork: 100.1626680
Thanks Meter: 27
vv thanks for this useful information
but try to change Chines 2 english in next update
Old 10-13-2013, 08:17   #3 (permalink)
Member: 226457
Sonork: 100.1604561
Originally Posted by [email protected] View Post
This is version 1.6.0.3690 but you hit the post 1.70
install version 1.6.0.3690 after connect phone and software will be update auto through internet
Qaisar Mahmood
Old 10-13-2013, 08:42   #4 (permalink)
zishhaider's Avatar
Member: 952111
Sonork: I'm not using now.
Thanks Meter: 603
Seems good.. But what If we already got 3..
1-Srs Root (freeware)
2-UnlockRoot Pro (Paid bu you can google :P )
3-Volcano Box One key Root(Many times Solved my problems)
In that case what is the specialty of above software even it is in Chinese...
Old 10-13-2013, 09:06   #5 (permalink)
zishhaider's Avatar
Member: 952111
Thanks Meter: 603
Originally Posted by max_cool View Post
i tried on htc sensation 4g bt it didnt work , btw thanks...
You need to have a unlock boot loader.. Go to HTC Dev and unlock it first...
Old 10-13-2013, 09:31   #6 (permalink)
Member: 319131
Thanks Meter: 15
Root_with_Restore_by_Bin4ry_v31 pass: chekm
Old 10-13-2013, 11:05   #7 (permalink)
Abhinav kumar b's Avatar
Member: 1751950
Sonork: 100.1615788
Thanks Meter: 25
VRoot 1.7.0 letest set link----------- VRoot_1.7.0.3882_Setup
The Following 6 Users Say Thank You to Abhinav kumar b For This Useful Post:
Old 10-13-2013, 15:35   #8 (permalink)
Gead's Avatar
Member: 1963729
Thanks Meter: 132
is there any program that does root for Sansung I9070?
Old 10-13-2013, 15:54   #9 (permalink)
Member: 226457
Sonork: 100.1604561
yes try with this software sure this software working perfect
Qaisar Mahmood
The Following 3 Users Say Thank You to Qaisar Mahmood For This Useful Post:
Old 10-13-2013, 17:52   #10 (permalink)
Dooha_Bd's Avatar
Member: 1427033
Sonork: 100.1596688
Thanks Meter: 1,175
More info about this tools.
1,Rooting app started. This will pop-up.
2,connect your device and you it will get detected. (Make sure USB Debugging is turned ON in your device)
Click the Green bottom right button and wait for rooting process to be done.
3,When this shows up, device will reboot, now you can unplug your device.
4. Now you need to install SuperSU from play store to replace the Chinese root manager called 授权管理 1.0.4.
5. Go to play store and install SuperSU.
6. Start SuperSU and you will be asked for permission by 授权管理 1.0.4, choose 允许(means allow). (Should be the right side option.)
7. SuperSU will prompt to install SU binary, go ahead with OK and it will display successful.
8. Now, freeze 授权管理 1.0.4 in titanium backup, just in case you need it again.
Note: If you uninstall straight away from app manager, you need to make sure SuperSU updated the binary.
9. Re-run SuperSU to make sure everything is alright. You will be prompt again to install SU binary, just do what it asked.
10. After that, you are rooted with SuperSU and 授权管理 1.0.4 will not be there anymore.
OPTIONAL
11. If you want to be more assured, in SuperSU app, prepare for a Reinstall in settings. (NOT Full unroot NOT Switch superuser app)
12. SuperSU will be removed and go back to play store to re-download and install.
13. Start SuperSU and SuperSU will prompt to install SU binary, go ahead with OK and it will display successful.
Thanks for understanding..
Note,Version will be auto meted updet with internet connection..
The Following 2 Users Say Thank You to Dooha_Bd For This Useful Post:
Old 10-14-2013, 07:55   #11 (permalink)
alkim's Avatar
Member: 992568
Sonork: kulit
Thanks Meter: 228
after the unit restart during rooting the phone will automatically turn on or it remain in off stage then you put it on manually i try in s5360 after phone turn off Ive waiting some minute but not turn on i manually turn it on but good news phone is rooted
Old 10-21-2013, 14:21   #12 (permalink)
headszone1's Avatar
Member: 1568769
Sonork: 161.1167
Thanks Meter: 183
need to get his root program in full English i tell u i download and install it but i need full English
Old 10-21-2013, 17:47   #13 (permalink)
wasim_mobile200's Avatar
Member: 332001
Thanks Meter: 58
i instal old and new version but all time software open error appears and software close in just 10 seconds.......
error in chinese language thats why i cant undrstand.... ?
i re install many time but always same issue plz give me solution..
The Following User Says Thank You to wasim_mobile200 For This Useful Post:
Old 10-28-2013, 06:59   #14 (permalink)
Cheater -Don't Deal with him-
Member: 452256
Sonork: 100.1651051
Thanks Meter: 585
thanks Qaisar Mahmood
VRoot_1.7.1 full setup
VRoot_1.7.1.4028_Setup
Good luck for all
Old 10-30-2013, 08:59   #15 (permalink)
Member: 793565
Sonork: 100.1611436
Thanks Meter: 356
New Update 29-10-2013 VRoot_1.7.2.4128
Update log :
Download Lnk
VRoot_1.7.2.4128_Setup(2)
The Following 3 Users Say Thank You to gulzarjan For This Useful Post:
Page generated in 0.43890 seconds with 7 queries
