Member: 1372118
Thanks Meter: 139 | disable BIMS 9860 new version done disable BIMS 9860 new version done Quote:
Connecting to Device in progress, please wait...
Device [1] connected.
Get device info...
The type initializer for '<>z__Aspects' threw an exception.
Device Info:
PIN:
Bootrom Version: 5.22.0.15
Hardware ID: 0x1D001404 RIM BlackBerry Device
HW ID Override: None
OS ID: None
Metrics Version: 6.25
Build Date: Apr 26 2011
Build Time: 18:58:44
Build User: ec_agent
Security: Enabled
Supported Options: 0x0000000D
Drivers: 0x00000010
Processor: 0x00400001
FlashID: 0x00000000
LDR Blocks: 0x80013F4C
Bootrom Size: 0x00020000
External MCT/HWV: Enabled
Boot Mode: N/A
Boot OS Count: N/A
HWV:
Board Revision 0001 - 0x11
CPU Version 0002 - 0xA6
SW Compatibility 0003 - 0x03
POP Revision 0004 - 0x04
Power Mgt Hardware 0007 - 0x01
POP Security 000B - 0x01
WCDMA Band supported 003B - 0x00
BSIS support 0041 - 0x01
Charger Hardware 0043 - 0x09
Mem Config Table (ver 1.24):
Flash Chip: blocks 0-65535, Chip 0, Sub 0
Boot0 MMC: blocks 0-15, total = 16, flags = 0x0003
User MMC: blocks 16-65535, total = 65520, flags = 0x0003
Bootrom: blocks 0-15
MCT: block 16
OS NV: blocks 17-80, total 64
Apps EFS: blocks 81-208, total = 128
Modem EFS: blocks 209-336, total = 128
Branding: blocks 337-384
OS Dynamic: blocks 385-????
FS Dynamic: blocks ????-8207
FS Nand FAT: blocks 8208-65535, total = 57328
MMC Enhanced: blocks 16-8207, total 8192
NAND Config: type 0, data 0x00001000 0x00010000
NAND Config: type 1, data 0x15170003 0x00000000
RAM Chip: 0x00000000-0FFFFFFF, Bank Size 33554432
RAM Chip: 0x20000000-2FFFFFFF, Bank Size 33554432
RAM Chip: 0x40000000-4FFFFFFF, Bank Size 33554432
CRC: 0x5F1332D4
Mem Config Table (ver 1.25) (actual):
MCT: block 16
OS Fixed: blocks 385-1161
UMP Fixed: blocks 1162-1420, total = 259
FS Fixed: blocks 1421-8207, total = 6787
CRC: 0xBD38A37D
Flash:
Number of chips: 1
Flash ID: NAND blocks 0-52239
Device ID: 0x4
Vendor ID: 0x45
Manufacturer Name: ******* (4.41)
OEM/Application ID: 0x100
Product Name: SEM04G
Product Revision: 0x90
Product Serial Number: 0x41C26B43
Manufacturing Date: Year 2011, Month 5
MMC Partition Info:
Boot0: 1024 KB (enhanced)
Boot1: 1024 KB (enhanced)
User: 524288 KB (enhanced)
User: 2818048 KB
Total Size: 3265 MB
DRAM:
Vendor: Samsung (0x1)
Revision: 0x0
Memory Map:
NAND Blocks: 52240 * 64 Kb
RAM Base: 0x40000000
IRAM Base: 0x00000000
OS Range: 385 - 1161
File System:
Memory Map:
1421 - 8207
Sectors: 6787
Branding:
VendorID: 613
OS Version: 5.1.0.338
Metrics Version: 3.18
FS Code Version: 10.0.0.0
Package Version: "5.1.0.338"
Build Date: Apr 20 2012
Build Time: 18:41:05
SV Number: 37
OS Address: 0x40000000-0x4308B6CF
App Start: 0x40154A14
Companion Binary: 0.0.0.0
RAM usage: 0x479FFFFC-0x49ACF230
IRAM End: 0x49ACF000
DSP ROM2 Address: *not present*
OS Extended Addr: 0x00000000
LDR Blocks: 0x40650328
API Checksum: 0x00000000
JumpTable (<3): 0x40000328
JumpTable (>2): 0x40002FAC
Radio Code: Eltron6 radio code linked
OS API Version: 156.39
STP Protocol Ver: 5.291.4 (release OS)
HWV:
Board Revision 0001 - [0x01 - 0xFF], 0x01
POP Revision 0004 - [0x00 - 0xFF], 0x01
CPU Version 0002 - [0xA2 - 0xFF], 0x01
SW Compatibility 0003 - [0x00 - 0x03], 0x01
Power Mgt Hardware 0007 - [0x01 - 0xFF], 0x01
POP Security 000B - [0x00 - 0xFF], 0x01
WTE supported 003C - [0x01 - 0xFF], 0x00
Version Table:
STP protocol version: 5.291.4
BlockFS API Version: 10.0.0.0
USB driver version: 02.32
Block map version: 0.0
NDK ABI version: 0.1
WLAN radio version: 4.5.0.215
Radio version: 5.0.2.1.1
Kernel Version: 3.2.0.385
Metrics Version: 1.1
Build Date: Apr 10 2012
Build Time: 18:49:40
Build User: SCM
App:
Version: 7.1.0.428 (0x070101AC)
Metrics Version: 1.7
Build Time: 19:37:03
Build User: RIM
Memory Map: 0x40154A14-0x40650327
App c_main: 0x404647D0
JumpTable (<3): 0x00000000
JumpTable (>2): 0x00000000
AppFSVersion: 3.0.0.0
AppFSSize: 0x0
RAM Map: 0x47800000-0x479FFFD8
IRAM Map: Unused
App Type: JVM
UMP:
Size: 5288648 bytes, blocks 1162-1242, offset 0
Size: 8053444 bytes, blocks 1242-1365, offset 46380
Size: 3617480 bytes, blocks 1365-1420, offset 38952
Preparing device, please wait..
Done
Disable Build in Media in progress, please wait...
Connected
Done. | |
