04-21-2014, 13:01 | #5 (permalink) |
Freak Poster Join Date: Jan 2010 Location: Kajen
Member: 1205328 Status: Offline Thanks Meter: 234 | Copas tetangga Bootrom Version: 5.22.0.15 Hardware ID: 0x16001404 RIM BlackBerry Device HW ID Override: None OS ID: None Metrics Version: 6.25 Build Date: Apr 26 2011 Build Time: 18:57:29 Build User: ec_agent Security: Enabled Supported Options: 0x0000000D Drivers: 0x00000010 Processor: 0x00400001 FlashID: 0x00000000 LDR Blocks: 0x80013F4C Bootrom Size: 0x00020000 External MCT/HWV: Enabled Boot Mode: N/A Boot OS Count: N/A HWV: Board Revision 0001 - 0x0A CPU Version 0002 - 0xA6 SW Compatibility 0003 - 0x01 POP Revision 0004 - 0x02 Power Mgt Hardware 0007 - 0x01 POP Security 000B - 0x01 RAMImage Compat 000E - 0x01 BSIS support 0041 - 0x01 Charger Hardware 0043 - 0x09 Mem Config Table (ver 1.24): Flash Chip: blocks 0-65535, Chip 0, Sub 0 Boot0 MMC: blocks 0-15, total = 16, flags = 0x0003 User MMC: blocks 16-65535, total = 65520, flags = 0x0003 Bootrom: blocks 0-15 MCT: block 16 OS NV: blocks 17-80, total 64 Apps EFS: blocks 81-208, total = 128 Modem EFS: blocks 209-336, total = 128 Branding: blocks 337-384 OS Dynamic: blocks 385-???? FS Dynamic: blocks ????-8207 FS Nand FAT: blocks 8208-65535, total = 57328 MMC Enhanced: blocks 16-8207, total 8192 NAND Config: type 0, data 0x00001000 0x00010000 NAND Config: type 1, data 0x15170003 0x00000000 RAM Chip: 0x00000000-0FFFFFFF, Bank Size 33554432 RAM Chip: 0x20000000-2FFFFFFF, Bank Size 33554432 RAM Chip: 0x40000000-4FFFFFFF, Bank Size 33554432 CRC: 0x5F1332D4 Mem Config Table (ver 1.26) (actual): Flash Chip: blocks 0-65535, Chip 0, Sub 0 Boot0 MMC: blocks 0-15, total = 16, flags = 0x0003 User MMC: blocks 16-65535, total = 65520, flags = 0x0003 Bootrom: blocks 0-15 MCT: block 16 OS NV: blocks 17-80, total 64 Apps EFS: blocks 81-208, total = 128 Modem EFS: blocks 209-336, total = 128 Branding: blocks 337-384 OS Fixed: blocks 385-1222 UMP Fixed: blocks 1223-1481, total = 259 FS Fixed: blocks 1482-8207, total = 6726 FS Nand FAT: blocks 8208-65535, total = 57328 MMC Enhanced: blocks 16-8207, total 8192 NAND Config: type 0, data 0x00001000 0x00010000 NAND Config: type 1, data 0x15170003 0x00000000 RAM Chip: 0x00000000-0FFFFFFF, Bank Size 33554432 RAM Chip: 0x20000000-2FFFFFFF, Bank Size 33554432 RAM Chip: 0x40000000-4FFFFFFF, Bank Size 33554432 CRC: 0x39EBFAB5 Flash: Number of chips: 1 Flash ID: NAND blocks 0-52239 Device ID: 0x4 Vendor ID: 0x45 Manufacturer Name: ******* (4.41) OEM/Application ID: 0x100 Product Name: SEM04G Product Revision: 0x90 Product Serial Number: 0x41CE76F2 Manufacturing Date: Year 2011, Month 5 MMC Partition Info: Boot0: 1024 KB (enhanced) Boot1: 1024 KB (enhanced) User: 524288 KB (enhanced) User: 2818048 KB Total Size: 3265 MB DRAM: Size: 768 MB Vendor: Samsung (0x1) Revision: 0x0 Memory Map: NAND Blocks: 52240 * 64 Kb RAM Base: 0x40000000 IRAM Base: 0x00000000 OS Range: 385 - 1222 File System: Memory Map: 1482 - 8207 Sectors: 6726 Branding: VendorID: 104 OS Version: 5.1.0.276 Hardware ID: 0x16001404 RIM BlackBerry Device Metrics Version: 3.18 FS Code Version: 10.0.0.0 Package Version: "5.1.0.276" Build Date: Mar 10 2012 Build Time: 17:47:01 Build User: ec_agent SV Number: 18 OS Address: 0x40000000-0x434549A3 App Start: 0x401546E4 Companion Binary: 0.0.0.0 RAM usage: 0x474FFFFC-0x495CF230 IRAM End: 0x495CF000 DSP ROM2 Address: *not present* OS Extended Addr: 0x00000000 LDR Blocks: 0x40650370 API Checksum: 0x00000000 JumpTable (<3): 0x40000328 JumpTable (>2): 0x40002FA0 Radio Code: Eltron6 radio code linked OS API Version: 156.31 STP Protocol Ver: 5.291.4 (release OS) HWV: Board Revision 0001 - [0x01 - 0xFF], 0x01 POP Revision 0004 - [0x00 - 0xFF], 0x01 CPU Version 0002 - [0xA2 - 0xFF], 0x01 SW Compatibility 0003 - [0x00 - 0x03], 0x01 Power Mgt Hardware 0007 - [0x01 - 0xFF], 0x01 POP Security 000B - [0x00 - 0xFF], 0x01 WTE supported 003C - [0x01 - 0xFF], 0x00 Version Table: OS API Version: 156.31 STP protocol version: 5.291.4 BlockFS API Version: 10.0.0.0 USB driver version: 02.32 Block map version: 0.0 NDK ABI version: 0.1 WLAN radio version: 4.5.0.196 Radio version: 5.0.2.1.1 Kernel Version: 3.2.0.315 Hardware ID: 0x16001404 RIM BlackBerry Device Metrics Version: 1.1 Build Date: Feb 26 2012 Build Time: 16:16:38 Build User: SCM App: Version: 7.1.0.342 (0x07010156) Metrics Version: 1.7 Build Date: Mar 10 2012 Build Time: 19:11:21 Build User: RIM Memory Map: 0x401546E4-0x4065036F App c_main: 0x40462018 API Checksum: 0x00000000 JumpTable (<3): 0x00000000 JumpTable (>2): 0x00000000 AppFSVersion: 3.0.0.0 AppFSSize: 0x0 OS API Version: 156.31 RAM Map: 0x47300000-0x474FFFD8 IRAM Map: Unused App Type: JVM UMP: Name: OlympiaWebKit.elf Size: 5284552 bytes, blocks 1223-1303, offset 0 Name: OlympiaWebKitLDLL.ldll Size: 8053444 bytes, blocks 1303-1426, offset 42284 Name: SaaS.elf Size: 3613384 bytes, blocks 1426-1481, offset 34856 Preparing device, please wait.. Done Disable Build in Media in progress, please wait... Connected --> COM Warning: get properties 0x8005000A |
04-22-2014, 00:19 | #7 (permalink) |
No Life Poster Join Date: Feb 2011
Member: 1519258 Status: Offline Thanks Meter: 243 | As i ever read spookey rtas until os5 or device can be downgrade from os6 to Os5. Has supported and you can check spookey post http://forum.gsmhosting.com/vbb/10244494-post8.html |
04-22-2014, 12:53 | #10 (permalink) |
Freak Poster Join Date: Aug 2013 Location: spookeybox
Member: 2008809 Status: Offline Sonork: 100.1653171 Thanks Meter: 764 | @sadermo What is your device problem? and please try use v1.2.0.4 Check this, Disable Rtas worked http://forum.gsmhosting.com/vbb/f907...first-1791356/ Br, SpookeyBox Last edited by SPOOKEY V2; 04-22-2014 at 13:03. |
04-24-2014, 06:00 | #13 (permalink) | |
No Life Poster Join Date: May 2006 Location: MOBILE SOFTZONE BHUBANESWAR IN
Member: 271478 Status: Offline Sonork: 1590868 Thanks Meter: 1,070 | Quote:
