09-03-2014, 20:24 | #2 (permalink) |
Product Supporter Join Date: Dec 2011 Location: Indonesia / Guangzhou Age: 38
Member: 1705891 Status: Offline Sonork: 100.1604564 Thanks Meter: 8,139 | set the device in FOS condition, still restart or not? if stable, after FOS condition do Disable Built in Media Storage Post your result Br, ARD |
01-27-2015, 06:46 | #6 (permalink) | |
Freak Poster Join Date: May 2010 Location: Tebing Tinggi
Member: 1306699 Status: Offline Sonork: GC Thanks Meter: 21 | Quote:
Factory OS Connecting to Device in progress, please wait... Device [1] connected. Get device info... Device Info: PIN: 28AFEE76 BSN: 1083893653 Bootrom Version: 5.26.0.12 Hardware ID: 0x0C001804 RIM BlackBerry Device HW ID Override: None Hardware OS ID: None BR ID: 0xFF000000 Metrics Version: 6.25 Build Date: Apr 20 2011 Build Time: 14:05:34 Build User: ec_agent Security: Enabled Supported Options: 0x0000000D Drivers: 0x00000010 Processor: 0x00400001 FlashID: 0x00000000 LDR Blocks: 0x80013F38 Bootrom Size: 0x00020000 External MCT/HWV: Enabled Boot Mode: N/A Boot OS Count: N/A JTAG SW Support: Unknown RPMB Support: Unknown WP Mode: Unknown Slack Mode: Unknown OS Blocking by Date: Not supported HWV: Board Revision 0x01 - 0x0C CPU Version 0x02 - 0xA6 SW Compatibility 0x03 - 0x01 POP Revision 0x04 - 0x01 Power Mgt Hardware 0x07 - 0x01 POP Security 0x0B - 0x01 WCDMA Band supported 0x3B - 0x00 BSIS support 0x41 - 0x01 Device variant 0x42 - 0x07 Charger Hardware 0x43 - 0x06 Mem Config Table (ver 1.24): Flash Chip: blocks 0-131071, Chip 0, Sub 0 Boot0 MMC: blocks 0-15, total = 16, flags = 0x0003 User MMC: blocks 16-131071, total = 131056, flags = 0x0003 Bootrom: blocks 0-15 MCT: block 16 OS NV: blocks 17-80, total 64 Apps EFS: blocks 81-208, total = 128 Modem EFS: blocks 209-336, total = 128 Branding: blocks 337-384 OS Dynamic: blocks 385-???? FS Dynamic: blocks ????-8207 FS Nand FAT: blocks 8208-131071, total = 122864 MMC Enhanced: blocks 16-8207, total 8192 NAND Config: type 0, data 0x00001000 0x00010000 NAND Config: type 1, data 0x15180003 0x00000000 RAM Chip: 0x00000000-0FFFFFFF, Bank Size 33554432 RAM Chip: 0x20000000-2FFFFFFF, Bank Size 33554432 RAM Chip: 0x40000000-4FFFFFFF, Bank Size 33554432 CRC: 0xA9BA6803 Mem Config Table (ver 1.26) (actual): Flash Chip: blocks 0-65535, Chip 0, Sub 0 Boot0 MMC: blocks 0-15, total = 16, flags = 0x0003 User MMC: blocks 16-65535, total = 65520, flags = 0x0003 Bootrom: blocks 0-15 MCT: block 16 OS NV: blocks 17-80, total 64 Apps EFS: blocks 81-208, total = 128 Modem EFS: blocks 209-336, total = 128 Branding: blocks 337-384 OS Fixed: blocks 385-1145 UMP Fixed: blocks 1146-1400, total = 255 FS Fixed: blocks 1401-8207, total = 6807 MMC Enhanced: blocks 16-8207, total 8192 NAND Config: type 0, data 0x00001000 0x00010000 NAND Config: type 1, data 0x15170003 0x00000000 RAM Chip: 0x00000000-0FFFFFFF, Bank Size 33554432 RAM Chip: 0x20000000-2FFFFFFF, Bank Size 33554432 RAM Chip: 0x40000000-4FFFFFFF, Bank Size 33554432 CRC: 0x995A96F5 Flash: Number of chips: 1 Flash ID: NAND blocks 0-131071 Device ID: 0x8 Vendor ID: 0x45 Manufacturer Name: ******* (4.41) OEM/Application ID: 0x100 Product Name: SEM08G Product Revision: 0x90 Product Serial Number: 0x51BAB2B1 Manufacturing Date: Year 2011, Month 8 MMC Partition Info: Boot0: 1024 KB (enhanced) Boot1: 1024 KB (enhanced) User: 524288 KB (enhanced) User: 6709248 KB Total Size: 8192 MB DRAM: Size: 768 MB VendorID: 0x1 Vendor Name: Samsung Revision: 0x0 Memory Map: NAND Blocks: 131072 * 64 Kb RAM Base: 0x40000000 IRAM Base: 0x00000000 OS Range: 385 - 1145 File System: Memory Map: 1401 - 8207 Sectors: 6807 Branding: Vendor ID: 102 OS Version: 5.0.0.735 Hardware ID: 0x0C001804 RIM BlackBerry Device Metrics Version: 3.18 FS Code Version: 10.0.0.0 Package Version: "5.0.0.735" Build Date: Nov 30 2011 Build Time: 22:45:36 Build User: ec_agent SV Number: 23 OS Address: 0x40000000-0x42F89A1B App Start: 0x4014BAE8 Companion Binary: 0.0.0.0 RAM usage: 0x47AFFFFC-0x49C0F230 IRAM End: 0x49C0F000 DSP ROM2 Address: *not present* OS Extended Addr: 0x00000000 LDR Blocks: 0x40620370 API Checksum: 0x00000000 JumpTable (<3): 0x40000328 JumpTable (>2): 0x40002F64 Radio Code: Eltron6 radio code linked OS API Version: 155.25 STP Protocol Ver: 5.274.4 (release OS) HWV Map: Board Revision 0x01 - [0x02 - 0xFF], 0x01 POP Revision 0x04 - [0x00 - 0xFF], 0x01 CPU Version 0x02 - [0x00 - 0xFF], 0x01 SW Compatibility 0x03 - [0x00 - 0x01], 0x01 WTE supported 0x3C - [0x01 - 0xFF], 0x00 Version Table: OS API Version: 155.25 STP protocol version: 5.274.4 BlockFS API Version: 10.0.0.0 USB driver version: 02.32 Block map version: 0.0 NDK ABI version: 0.1 WLAN radio version: 4.4.0.257 Kernel Version: 3.0.0.927 Hardware ID: 0x0C001804 RIM BlackBerry Device Metrics Version: 1.1 Build Date: Nov 30 2011 Build Time: 22:25:46 Build User: SCM App: Version: 7.0.0.579 (0x07000243) Metrics Version: 1.7 Build Date: Dec 1 2011 Build Time: 00:26:31 Build User: RIM Memory Map: 0x4014BAE8-0x4062036F App c_main: 0x404538D8 API Checksum: 0x00000000 JumpTable (<3): 0x00000000 JumpTable (>2): 0x00000000 AppFSVersion: 3.0.0.0 AppFSSize: 0x0 OS API Version: 155.25 RAM Map: 0x47900000-0x47AFFFD8 IRAM Map: Unused App Type: JVM UMP: Name: OlympiaWebKit.elf Size: 5182152 bytes, blocks 1146-1225, offset 0 Name: OlympiaWebKitLDLL.ldll Size: 7975620 bytes, blocks 1225-1346, offset 5420 Name: SaaS.elf Size: 3519176 bytes, blocks 1346-1400, offset 51240 Preparing device, please wait.. Done Go to Factory OS in progress, please wait... Done Disable Build in Media in progress, please wait... Connected --> COM Warning: get properties 0x8005000A Done. | |
The Following User Says Thank You to Stress Boyz For This Useful Post: |
