Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia X Android Based
Nokia X Android Based Nokia X Nokia X+ Nokia XL The Nokia X family is a range of new smartphones from Nokia introduced in 2014, running a forked version of Android
Old 04-16-2014, 14:35   #1 (permalink)
Super Moderator
Parash's Avatar
Member: 1435864
Sonork: / Skype id: Parashsky
Thanks Meter: 1,755
[GUIDE][ROOT]Nokia X - How root the new v11.1.1 update
Download this package from
when your device is updated and plug in.
1- Install Nokia Composite ADB Interface (using it from Nokia Usb Drivers folder)
2- Open KingRoot app while device its working and plugged (If everything goes fine, should be detected as: Android Device (msm8625) Normal Mode.
For those wondering what to do with the Nokia drivers:
-Plug your phone to your computer
-Go to device manager and find your phone on the list(it should have a punctuation mark for windows 7 users)
-Right click on your phone and install the nokia drivers
Use only your own risk.
__________________
BR.
Parash
The Following 9 Users Say Thank You to Parash For This Useful Post:
Old 04-16-2014, 17:10   #2 (permalink)
imran qma's Avatar
Member: 469651
Sonork: 100.1584040
Thanks Meter: 115
Vroot is working with new nokia x
The Following 2 Users Say Thank You to imran qma For This Useful Post:
Old 04-21-2014, 09:10   #3 (permalink)
Member: 313894
Thanks Meter: 5
Exclamation i can`t install some of game
i am bought a new nokia x.. but it`s waste for myself bcoz i can`t install so many apps bcoz it`s display shows while installing ur download server is not defined.. example apps( front line commander, fruit ninja, ashplet 8, etc..)
these are downloaded from 1mobile store.. but not installing..some installed as good. but try to open it shows need a google login. so i want any solution for this apps problem. thank you for a response
Old 04-21-2014, 09:19   #4 (permalink)
Member: 313894
Thanks Meter: 5
Here i can`t understand your rooting instruction sir. shall u help me as detaily about how to installing as step by step? thanku..sir keep it up..
Old 05-14-2014, 09:16   #5 (permalink)
omkar3268's Avatar
Member: 1161713
Sonork: 100.1607798
Thanks Meter: 421
u r method is not working BRO
Old 05-14-2014, 09:27   #6 (permalink)
Super Moderator
Parash's Avatar
Member: 1435864
Thanks Meter: 1,755
  1. Okay, first of all did you downloaded the package given in the guide ?
  2. Once you download it, extract it then you will have two folders, One named as Kingroot and the other named Nokia X USB drivers
  3. and then download the adt bundle from Google
  4. Here's the Link in case you didn't get the adt bundle - DOWNLOAD
  5. Extract it, you will have 2 folders and an Application
  6. Open the Application named SDK Manager
  7. Then from the packages, select and install Platform tools
  8. Once, you installed platform tools, navigate to SDK folder > then Platform-tools folder
  9. Now, in the Platform tools folder, Right click anywhere while holding shift
  10. Click on Open Command Window here
  11. Then run this command : adb devices
  12. See if your device get's listed
  13. If it doesn't get listed, then Go to Control Panel > Hardware and Sound > Device Manager
  14. Plug-in your Nokia X
  15. With MTP selected in your mobile
  16. Now, you will have Nokia X device listed in the Device Manager
  17. Right Click on it, then click on Update driver
  18. Browse file for USB driver manually
  19. Select ADB driver folder from the package you downloaded from the guide on forum.xda-developers.com (i.e this - NokiaX USB Drivers\nokia\usb_driver and Click OK
  20. Install the drivers
  21. Then again navigate to sdk> platform tools
  22. Then again Open command Window there
  23. Run the command adb devices again
  24. And see if your Nokia X gets listed, the device should be c268 something like that
  25. Once you done this all, Open Kingroot folder
  26. Disconnect and connect your Nokia X
  27. Kingroot app should detect it in few mins
  28. Then follow the on-screen instructions
After the rooting process, your Nokia X re-boots and the SuperSU asks for permission, Grant it. Voila !! You are done now. You may disconnect your Nokia X now and enjoy the Rooted the Nokia X.
Does it just says root failed ? Maybe you should start the rooting process from the beginning of the tutorial (or) maybe your device is still on the previous Software version (i.e v10.0.3), make a check and do update your device if it's the previous update on your device and then try again rooting your device using this tutorial.
__________________
BR.
Parash
The Following 3 Users Say Thank You to Parash For This Useful Post:
Old 05-14-2014, 09:56   #7 (permalink)
Super Moderator
Parash's Avatar
Member: 1435864
Thanks Meter: 1,755
Nokia X Toolkit
Try this tool. Maybe it will help you
Nokia X Toolkit
__________________
BR.
Parash
Old 05-14-2014, 10:13   #8 (permalink)
omkar3268's Avatar
Member: 1161713
Sonork: 100.1607798
Thanks Meter: 421
after open adb it will not open see here
Old 05-15-2014, 07:13   #9 (permalink)
Member: 287668
Thanks Meter: 8
try ro run from command
Old 05-15-2014, 23:55   #10 (permalink)
Super Moderator
GSMWorld's Avatar
Member: 16
Sonork: 100.1652085 GSMWorld
Thanks Meter: 1,743
Vroot
Vroot is an one-key root tool designed by Mgyun-team. Just click one button, you can root your mobile device immediately!
It is very easy to use .Turn on the USB debugging mode, and connect your phone to the computer, then click the button "root" and now what you have to do is just waiting for the root result. Forget the complex and troublesome tutorials, everyone can control it easily.
Vroot's goal is providing the excellent and simplest experience for all android users. The newest version of Vroot have supported for more than 8000 kinds of Android devices. It is more effective, easier and faster than you can imagine.
In order to serve non-chinese user, we are pleasure to release this English version for downloading . If you are a non-Chinese user, just download the English version of the Vroot and enjoy the root now.
Download Here
http://products.mgyun.com/api/downju...annelcode=1005
__________________
Wbr
GSMWorld
The Following User Says Thank You to GSMWorld For This Useful Post:
Old 05-18-2014, 05:35   #11 (permalink)
omkar3268's Avatar
Member: 1161713
Sonork: 100.1607798
Thanks Meter: 421
Nokia X Toolkit
it will not work for me coz it's work on 1.0 i have 1.2 ver
Old 05-18-2014, 06:13   #12 (permalink)
omkar3268's Avatar
Member: 1161713
Sonork: 100.1607798
Thanks Meter: 421
Download Here
Thanks Bro
VRoot New English Ver Is Here Download
The Following 7 Users Say Thank You to omkar3268 For This Useful Post:
Page generated in 0.25423 seconds with 8 queries
