Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia X Android Based
Nokia X Android Based Nokia X Nokia X+ Nokia XL The Nokia X family is a range of new smartphones from Nokia introduced in 2014, running a forked version of Android
Old 06-05-2019, 10:00   #1 (permalink)
Member: 1429766
Thanks Meter: 51
Exclamation Nokia 6.1 stuck in Download mode
Hello! I have a stucked in Download mode Nokia 6.1 TA-1050. The phone can't enter Recovery mode with any key combination. I tried to flash stock firmware with OST LA but it gets stuck on Reflash service bootloader... I guess because of it's bootloader locked state. There is a trick that you can bypass this but from recovery and as i said i can't boot into recovery. So any ideas? Thank you in advance!
The Following User Says Thank You to xukca For This Useful Post:
Old 06-05-2019, 10:19   #2 (permalink)
Member: 1429766
Thanks Meter: 51
SOLVED! Made a check of phone's current boot slot with that command in fastboot:
fastboot getvar current-slot
Mine was b so i changed it to a with that command:
fastboot --set-active=a
After that phone booted in recovery with only two options Try again and format user data. I formatted and the phone booted up!
The Following 4 Users Say Thank You to xukca For This Useful Post:
Old 06-10-2019, 22:17   #3 (permalink)
Member: 261334
Thanks Meter: 13
now my computer is no longer in that mode I do, I'm in HS-Usb mode
The Following User Says Thank You to Electro_nokia For This Useful Post:
Old 06-29-2019, 12:18   #4 (permalink)
Member: 139718
Thanks Meter: 3
thanks it works for my nokia 7 plus
Old 06-29-2019, 12:19   #5 (permalink)
Member: 1429766
Thanks Meter: 51
I am happy that it worked for you!
Old 07-17-2019, 10:52   #6 (permalink)
rana_sab's Avatar
Member: 62911
Thanks Meter: 156
in my case nokia ta-1116 always in download mode force restart but agin in download mode
in device manger only show this ?
please help
Old 07-19-2019, 12:56   #7 (permalink)
Member: 1429766
Thanks Meter: 51
Install latest Nokia drivers and i think that after the installation your device will be detected in fastboot mode and you can use the tutorial described in the second post. Good luck!
Old 07-22-2019, 13:29   #8 (permalink)
gile@gile's Avatar
Member: 1473716
Thanks Meter: 743
please help
Use this Solution.......https://www.youtube.com/watch?v=j8n_ieyzvHM
The Following User Says Thank You to [email protected] For This Useful Post:
Old 08-02-2019, 17:08   #9 (permalink)
Member: 1418143
Thanks Meter: 338
I tried too , mine was A i set it to B , to booted to recovery after formated it ok ...
The Following 2 Users Say Thank You to psytr0nic For This Useful Post:
Old 08-11-2019, 14:39   #10 (permalink)
Member: 132635
Thanks Meter: 215
Page generated in 0.19843 seconds with 8 queries
