Nokia X Android Based Nokia X Nokia X+ Nokia XL The Nokia X family is a range of new smartphones from Nokia introduced in 2014, running a forked version of Android |
08-18-2014, 13:52 | #1 (permalink) |
No Life Poster Join Date: Nov 2011
Member: 1696653 Status: Offline Sonork: 100.1638410 Thanks Meter: 809 | Nokia X,X+,XL Android Mobiles Flashing tutorial + Firmware Downloader Nokia X,X+,XL Android Mobiles Flashing tutorial + Firmware Downloader Note: Flashing(Refurbish) - It will remove all user content from the memory (not SD) nd restore all settings 2 factory ones. It vil works only on connected nd not dead phones. Recovery - This options will recover dead phone or will flash different software variant designeted for other markets. Phone if is live must be powered down and not connected to NCS until massage pop up during flashing while after when you press the Start Note : To Refurbish and LPC: For device detection, user needs to manually enter code: *#*#2273#*#* on device dial-pad and enable WinUSB mode by selecting it on device’s screen. Same action is always needed after finalized flashing To get start first download latest NCS with support Nokia X series. Download NokiaCareSuiteForStore-5.0.60.1409 Nokia android supported Firmware(ROM) Downloader Nokia DataPackage Manager 2013.7.5 No need login :: How to download firmware see below given n the picture :: How to flash the nokia android mobiles nd recover Bricked Mobiles * Download all ROM files and copy them into c:\ProgramData\Nokia\Packages\Products\rm-xxx\ * Launch Nokia Care Suite from yur desktop and click on Product Support Tool for Store 5.0 * If you doing Recovery which is most of cases, unmark Automatic product selection and set No Connection. Do not connect the phone! Click File-> Open product-> put model name if NCS let you or write down RM version, for example 980 * Then Programming-> recovery, downloaded packages will show up in the window * Click on an firmware and press Start, wait for massage windows and follow it. Nokia X - 980 Nokia X+ - to be updated Nokia XL - to be updated Nokia X (RM-980) Product Codes 059V301: RM-980 GLOBAL SWAP 059T991: RM-980 NDT APAC ID ERA 059T992: RM-980 NDT APAC ID PAR 059T993: RM-980 NDT APAC ID TRI 059T9F0: RM-980 NDT APAC MY 059T983: RM-980 NDT APAC TH 059T982: RM-980 NDT APAC VN 059T9D8: RM-980 NDT EURO PL 059T989: RM-980 NDT EURO TR 059T9G1: RM-980 NDT EURO UA 059T9G0: RM-980 NDT IMEA AE 059T9F2: RM-980 NDT IMEA EG 059T985: RM-980 NDT IMEA IN 059T9F4: RM-980 NDT IMEA KE 059T9F9: RM-980 NDT IMEA KW 059T9F5: RM-980 NDT IMEA NG 059T9F7: RM-980 NDT IMEA ** 059T986: RM-980 NDT IMEA PK 059T9F8: RM-980 NDT IMEA QA 059T9F6: RM-980 NDT IMEA SA Nokia X - How boot in Recovery and Bootloader Mode :: Nokia Recovery Mode :: 1. Turn off your device 2. Press Volume + and Power Button 15 seconds :: BootLoader Mode :: 1. Turn off your device 2. Remove wires and battery 3. Hold on Volume + Key while you connect USB 4. Device should be detected as Qualcomm CDMA Technologies MSM |
The Following 15 Users Say Thank You to mobilehelper For This Useful Post: |
