Nokia X Android Based Nokia X Nokia X+ Nokia XL The Nokia X family is a range of new smartphones from Nokia introduced in 2014, running a forked version of Android |
04-09-2018, 17:20 | #1 (permalink) |
No Life Poster Join Date: Feb 2002 Location: Russia Age: 44
Member: 9519 Status: Offline Thanks Meter: 2,150 | NTool sneakpeak Code: RUNNING NTool 0.01 HMD PHONE "PL2Gxxxxxxxxxxxx" CONNECTED model=P2A sub_model=none software version=PL2-213B-0-00WW-B09 SW model=00WW build number=B09 hardware version=5.0 RF band id=G_850_900_1800_1900^W_1_2_5_8^L_1_3_5_7_8_20_28_ secure:yes reported max download size: 536870912 getBootloaderType:commercial SecVer:4 getBootloaderType:commercial challenge:D611A10DD5955148ADE2077F13D8FB2AE0A37B0E dm-veracity passed extract and flash "B2N-0-213B-xbl_service.zip" to "xbl_a" Extracted 2563273 bytes extract and flash "B2N-0-213B-xbl_service.zip" to "xbl_b" Extracted 2563273 bytes extract and flash "B2N-0-213B-abl_service.zip" to "abl_a" Extracted 380928 bytes extract and flash "B2N-0-213B-abl_service.zip" to "abl_b" Extracted 380928 bytes device PL2Gxxxxxxxxxxxx removed HMD phone "PL2Gxxxxxxxxxxxx" removed HMD PHONE "PL2Gxxxxxxxxxxxx" CONNECTED perform auth routine SecVer:4 getBootloaderType:service ProjectCode:PL2 UID:xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx Using cached signature service key auth passed flash "B2N-0-213B-gpt_both0.bin" to "partition" skip flashing B2N-0-213B-xbl_service.elf skip flashing B2N-0-213B-xbl_service.elf extract and flash "B2N-0-213B-xbl_service.zip" to "xbl_a" Extracted 2563273 bytes extract and flash "B2N-0-213B-xbl_service.zip" to "xbl_b" Extracted 2563273 bytes skip flashing B2N-0-213B-abl_service.elf skip flashing B2N-0-213B-abl_service.elf extract and flash "B2N-0-213B-abl_service.zip" to "abl_a" Extracted 380928 bytes extract and flash "B2N-0-213B-abl_service.zip" to "abl_b" Extracted 380928 bytes flash "B2N-0-213B-tz.mbn" to "tz_a" flash "B2N-0-213B-rpm.mbn" to "rpm_a" flash "B2N-0-213B-hwcfg.img" to "hwcfg" flash "B2N-0-213B-hyp.mbn" to "hyp_a" flash "B2N-0-213B-pmic.elf" to "pmic_a" flash "B2N-0-213B-keymaster64.mbn" to "keymaster_a" flash "B2N-0-213B-cmnlib.mbn" to "cmnlib_a" flash "B2N-0-213B-cmnlib64.mbn" to "cmnlib64_a" flash "B2N-0-213B-dspso.bin" to "dsp_a" flash "B2N-0-213B-devcfg.mbn" to "devcfg_a" flash "B2N-0-213B-sec.dat" to "sec" flash "B2N-0-213B-mdtpsecapp.mbn" to "mdtpsecapp_a" flash "B2N-0-213B-storsec.mbn" to "storsec" flash "systeminfo.img" to "systeminfo_a" perform "reboot-bootloader" device PL2Gxxxxxxxxxxxx removed HMD phone "PL2Gxxxxxxxxxxxx" removed HMD PHONE "PL2Gxxxxxxxxxxxx" CONNECTED perform auth routine SecVer:4 getBootloaderType:service ProjectCode:PL2 UID:xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx Using cached signature service key auth passed flash "B2N-1-213B-NON-HLOS.bin" to "modem_a" flash "B2N-0-213B-00WW-mdtp.img" to "mdtp_a" flash "PL2-0-213B-00WW-boot.img" to "boot_a" erase "boot_b" flash "PL2-0-213B-00WW-system.img" to "system_a" TotalSize: 0000003221225472 flash "PL2-0-213B-00WW-system_other.img" to "system_b" TotalSize: 0000003221225472 flash "B2N-0-213B-BTFM.bin" to "bluetooth_a" flash "B2N-0-213B-00WW-persist.img" to "persist" TotalSize: 0000000033554432 erase "userdata" if not retain user data flash "PL2-00WW-001-sutinfo.img" to "sutinfo" flash "B2N-0-213B-NV-default.mbn" to "nvdef_a" flash "C1N-0-0020-0001-hidden.img.ext4" to "hidden_a" flash "PL2-00WW-018-cda.img" to "cda_a" erase "ssd" if not retain user data erase "misc" if not retain user data erase "sti" if not retain user data flash "PL2-00WW-018-splash.img" to "splash_a" flash "PL2-00WW-018-multi-splash.img" to "splash2" erase "ddr" erase "securefs" on factory skip, options: 0000000000000001 bootName "KEY_INFO" skip, options: 0000000000000001 bootName "box" flash "PL2-0-213B-00WW-vendor.img" to "vendor_a" TotalSize: 0000001073741824 flash "B2N-0-213B-xbl.elf" to "xbl_a" flash "B2N-0-213B-xbl.elf" to "xbl_b" flash "B2N-0-213B-abl.elf" to "abl_a" flash "B2N-0-213B-abl.elf" to "abl_b" perform "oem set_active _a" perform "oem enable-charger-screen" skip, options: 0000000000000001 bootName "cda" skip, options: 0000000000000001 bootName "e2p_package" skip, options: 0000000000000001 bootName "e2p_script" flash "md4.dat" to "md4" Elapsed: 201 secs. EDL mode not required. IMEI/BT/MAC change, which do not damage network. bootloader unlock. ..... reasonable cheap really soon |
The Following 15 Users Say Thank You to the_laser For This Useful Post: |
04-10-2018, 18:31 | #3 (permalink) | |
No Life Poster Join Date: Sep 2011 Location: Dhaka,Bangldesh
Member: 1659078 Status: Offline Sonork: Mahidi Munna Thanks Meter: 199 | Quote:
04-10-2018, 22:51 | #5 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | How about reading post from beginning to the very end ? or simple words : Wait, it will be announced and you can purchase. b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! |
The Following 3 Users Say Thank You to Brka For This Useful Post: |
04-22-2018, 19:29 | #10 (permalink) |
Member: 9519 Status: Offline Thanks Meter: 2,150 | Anyone with setool2 credits can test NTool 0.02 https://mega.nz/#F!Qt0gmIhJ!IsPqnXMJB-TKQpxZq5aKQA 1 credit for flashing 1 credit for bootloader unlock generation supported any HMD smartphone - nokia 1,2,3,4,5,6,6.1,7,7 plus,8 so far supported : - flashing of original .NB0 files or original unpacked .NB0 !!! make sure you using proper firmwares for your phone model !!! - FRP reset - bootloader unlock signature generation !!! make sure you double check IMEI and SERIAL NUMBER BEFORE REQUEST !!! instructions to use signature : Code: install fastboot drivers for phone. power off phone. run fastboot flash unlock <signature file> connect phone to cable run fastboot oem unlock-go follow instructions on phone display if any - ALWAYS connect powered off phone !!! If phone in FASTBOOT mode - connect phone to cable, start operation, then press and hold volume up + power buttons until phone restart !!! |
The Following 6 Users Say Thank You to the_laser For This Useful Post: |
04-26-2018, 11:18 | #12 (permalink) |
No Life Poster Join Date: Jun 2004 Location: MACEDONIA
Member: 67805 Status: Offline Thanks Meter: 364 | I have semi bricked Nokia 6 ta-1033 when client make ota update. I manage somehow to downgrade bootloader from 8.1.0 to 7.1.1 with adb sideload and now OST LA can start to program phone in FTM mode with .nb0 but process end with error that battery is to low and I cant charge battery from recovery, ftm or powered off phone When I try to flash with ntool phone need to be powered off, and when I connect powered off phone ntool do not detect phone even some driver is loaded for a short time and after this phone goes to recovery or stuck to android logo Any help why ntool cant detect phone @seba thanks for the link |
04-26-2018, 15:16 | #13 (permalink) | |
No Life Poster Join Date: Jul 2011 Location: ۞_ KERALA__۞_INDIA
Member: 1619462 Status: Offline Sonork: 100.1606509 Thanks Meter: 1,517 | Quote:
The Following User Says Thank You to .::EXTREME::. For This Useful Post: |
04-26-2018, 22:07 | #14 (permalink) | |
Member: 9519 Status: Offline Thanks Meter: 2,150 | Quote:
drivers, included in ntool or in OST, should be installed. NTool will only detect phone if it in FASTBOOT mode and drivers are installed. HMD devices enter FASTBOOT mode automatically during reset. you can try another next trick : start operation, connect phone in recovery or stuck in android logo, press and hold volume up + power on until phone reset. btw, NTool v0.0022 released with support for flashing of NTool firmwares plus many interesting firmwares uploaded Code: ./Nokia1.Frontier.FRT: FRT-039E-0-00WW-B02.NBx.zip ./Nokia2.Dynamo.E1M: E1M-064D-0-00WW-B01.NBx.zip E1M-115B-0-00WW-B01.NBx.zip ./Nokia3.Essential.NE1: NE1-215O-0-00WW-B01.NBx.zip NE1-4040-0-00WW-B01.NBx.zip ./Nokia5.Core.ND1: ND1-5600-0-00WW-B01.NBx.zip ./Nokia6.D1C: D1C-521B-0-00WW-B01.NBx.zip ./Nokia6.Plate2.PL2: PL2-2230-0-00CN-B01.NBx.zip PL2-2230-0-00WW-B01.NBx.zip ./Nokia6.Plate.PLE: PLE-5600-0-00WW-B01.NBx.zip ./Nokia7.Charm.C1N: C1N-1250-0-00WW-B01.NBx.zip C1N-127C-0-00CN-B02.NBx.zip ./Nokia7_Plus.Onyx.B2N: B2N-213B-0-00WW-B03.NBx.zip B2N-213C-0-00CN-B02.NBx.zip ./Nokia8.Avenger.A1N: A1N-310B-0-00WW-B01.NBx.zip ./Nokia8.Bang.NB1: NB1-484E-0-00WW-B01.NBx.zip | |
The Following 4 Users Say Thank You to the_laser For This Useful Post: |
04-27-2018, 01:06 | #15 (permalink) |
Member: 67805 Status: Offline Thanks Meter: 364 | Thanks I'll try next phone because this nokia 6 I solved firmware problem with OST LA. First I flash twrp to phone then I charge phone because twrp have this ability and then I write firmware with OST LA |
The Following User Says Thank You to MOBICOM For This Useful Post: |
