01-28-2015, 04:37 | #1 (permalink) |
Freak Poster Join Date: Jun 2005 Location: Brazil Age: 37
Member: 154995 Status: Offline Thanks Meter: 13 | C1604 emergency only I did a IMEI repair in a C1604, but I had only emergency call. So, I´m trying to do repair secure area + unlock + repair IMEI, as a readed in forum. But, during the repair of secure area I have the problem below: Smart-Clip 2 1.08.01 ADB: Repair security area Sony Xperia * daemon not running. starting it now * * daemon started successfully * ^ Sony so0101 ADB Interface Driver Version: Linux version 3.0.8-perf ([email protected]) (gcc version 4.4.3 (GCC) ) #1 PREEMPT Thu Jan 17 19:46:31 CST 2013 Phone model: Sony C1604 Firmware: 11.1.A.0.68 Date: Thu Jan 17 19:18:57 CST 2013 Version: 11.1.A.0.68 Baseband Firmware: 76XXU-USNSKOLYM-2060, Baseband Processor: QCT MSM7x27a SURF Preparing...Skipped attached the first backup file when I did the IMEI repair. 355556056233520_Sony_C1604_11_1_A_0_68_Thu Jan 17 191857 CST 2013 - Download - 4shared Please help me to have signal, Thank you. |
01-28-2015, 08:36 | #2 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ fernandesx, Have you performed Master Reset operation after Repair IMEI? If no, please run Master Reset operation, as it is signed in the manual. In case same issue appears you can use "Rollback Sony security area" function. It will return your phone to the previous state (as it was before the repair IMEI procedure). Also, please sign what an issue phone originally had. Why are you trying to perform Repair IMEI to this phone? Best Regards GSMServer team Last edited by GSM_Support; 01-28-2015 at 09:50. |
01-28-2015, 17:16 | #3 (permalink) |
Member: 154995 Status: Offline Thanks Meter: 13 | problem keeps I´m doing this repair just cause before I can´t register in the operator. I found the operator, but it answer to me that I´m unable to register. I did the Rollback, then factory reset, after unlock + factory reset, after repair imei + factory reset. Same problem. After this I update de firmware to 11.3.A.2.1 and did the rollback again. Did the same procedure and only emergency call. Now I tryied to do the procedure indicated in another topic: Repair secure area - factory reset - unlock - factory reset - imei - factory reset. But I had the same problem to do security area repair: Smart-Clip 2 1.08.01 ADB: Repair security area Sony Xperia * daemon not running. starting it now * * daemon started successfully * ^ Sony so0101 ADB Interface Driver Version: Linux version 3.4.0-perf ([email protected]) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #1 SMP PREEMPT Tue Apr 9 19:34:45 CST 2013 Phone model: Sony C1604 Firmware: 11.3.A.2.1 Date: Tue Apr 9 18:52:37 CST 2013 Version: 11.3.A.2.1 Baseband Firmware: 76XXU-USNSKOLYM-2540 Baseband Processor: QCT MSM7x27a SURF Preparing...Skipped Could you help me? |
