01-05-2015, 06:58 | #1 (permalink) |
Product Manager Join Date: Mar 2013 Location: CH
Member: 1907775 Status: Offline Sonork: 1653265:unlocker Thanks Meter: 2,693 | Night Using Selfie Enhancing Flash Light For Smartphone Monopod Selfie Stick The Night Using Selfie Enhancing Flash Light LED flash elp dramatically improve the quality of photos and video you take with your iphone, ipad, android or windows phone in low-light situation. It easily plugs into the headphone port of the device and has its own battery, so it doesn’t drain the power of your smart phone—yet has enough power to take up to 500 photos before recharging. GENETLE LIGHT FOR YOUR SELFIES Night Using Selfie Enhancing Flash Light takes your selfies to the next level with a soft beam of light controlled by a smart app. TRY EVEN BETTER PHOTOGRAPHY Natural skin tones,Mild shadows,Diffused light,Infinite depth,Full-featured frame covering VIDEO LIGHTT FOR EVERY DAY OCCASIONS Shoot fully lighted videos on your IOS, Androids and Windows Phone using the companion app. icanany provides a vivid constant light that useful for short night videos and brief interviews. KEY VIDEO FEATURES Constant light mode,Adjustable brightness,No red-eye effects,70-degree beam angle Free companion app WHAT MAKES ICANANY OUTSTANDING BATTERY INSIDE FREE APP IOS+ANDROID FLASH MODE FRONT/BACK CAMERA PHOTO/VIDEO MODES NO RED EYE ADJUSTABLE BRIGHTNESS BEAM ANGLE UP TO 3H LIGHT TIME LIGHT TEMPERATURE HOW BRIGHT IS ICANANY? The flash is constructed to include four hi-end LEDs that provide an uncompromising amount of light for such a small size. The light comes through 70-degree optics, of our development, which works perfectly with any smart phone or tablet. HOW WELL IS ICANANY SUPPORTED ON IOS? ICANANY apps are working with smartphones and tablets that support iOS 6/7/8 (iPhone 4 and higher, iPad 2 and higher). Each device has its own camera specification, so our team was working with each camera to find the perfect flas synchronization. Moreover, we developed the SDK and continuously looking for new camera apps that will support ICANANY functions. HOW WELL ICANANY IS SUPPORTED ON ANDROID? ICANANY apps are working with smart phones and tablets that support Android 4.0 and higher. We made a universal app that works stable with all Android 4.0 devices. The most popular smartphones like Samsung Galaxy S series have received more attention from ICANANY app development team so you will find better ICANANY synchronisation. WHAT IS THE DIFFERENCE BETWEEN PLASTIC AND ALUMINIUM VERSION? Aluminum is significantly more thermally conductive than plastic, which allowed us to make it more powerful than our plastic version in constant light mode. Anodized aluminum ICANANY = tough, cold, and powerful. We like to keep everything minimalistic and perfect. Each detail of ICANANY is carefully designed to maximize our technology. CAN I USE ICANANY REMOTELY? You have the option of using an audio extension cable with your ICANANY. Both 3-pole and 4-pole extension cables will allow you to have classics in hand flash for more creative pics. HOW LONG WILL IT WORK? Most importantly, with its own built-in battery, ICANANY will not drain your smartphone's power. It has a 110 mAh battery which will be enough for more than 500 flashes per charge. Also ICANANY has three constant light power modes, which you can change by pushing the button on the top of the device. 1. First power mode will light LEDs for up to 2 hours 2. Second power mode – up to 40 minutes 3. Third power mode – up to 25 minutes IS THE ICANANY HARD TO USE? The ICANANY was designed to intuitively easy to use, just like your smartphone! You need to connect the flash to audio jack, start the app and it's ready to take pictures. To use it in constant light mode you will need just to push the button several times. If you would like to know more about how to use the ICANANY with the app please check our YouTube video. WHAT IS FLEXIBLE CHARGER AND WHY WOULD I NEED IT? Flexible charger is a must have accessory that will widely increase applycability of your smallest LED device. It is made of flexible material and allows you to use it as: ICANANY stand Keybord lighting Macro photography Skype-call light Reading light And it should be noted that ICANANY works well during charging process on first power mode. http://www.rsim5.com/flash/201501041033286.jpg CAN I USE ICANANY REMOTELY? You have the option of using an audio extension cable with your ICANANY. Both 3-pole and 4-pole extension cables will allow you to have classics in hand flash for more creative pics. And don’t forget that ICANANY has a battery inside. That means that it can be used as a constant light without being connected to the smartphone. CAN I CHANGE THE BATTERY? ICANANY housing is carefully secured by ultrasound technology and is not designed to be disassembled. The battery inside the flash has capability to pass 1000 cycles, just like the smart phone. I RECEIVED MY ICANANY AND IT DOES NOT REACT TO THE BUTTON PUSH Some of the devices that reached you- are fully discharged (we didn’t charge them all before packaging). So once you receive you package, the best thing to do is to charge your ICANANY for around 4 hours, then unplug it from the charger and it will be ready to light your life! I'M HAVING ISSUES WITH MY ICANANY. WHAT COULD BE WRONG? This is a new product and there is a small probability that something will go not as good as it should be. If you have any issues or you think that something is not good with your device, the best way to get the fast answer is to contact us directly find we will find the best solution for you. China Monopod, Wireless Monopod, Cable Take Pole supplier - Shenzhen Source Industrial Co., Ltd. Last edited by kinglock; 01-05-2015 at 15:33. |
