04-13-2017, 20:48 | #1 (permalink) |
No Life Poster Join Date: Jan 2015
Member: 2325887 Status: Offline Thanks Meter: 134 | after write cert by z3x and octopus imei 00 can gcpro fix ? insert sim card and not registered on network gcpro key can be repair this problem? first problem imei 3500000000000 |
04-13-2017, 20:53 | #2 (permalink) |
No Life Poster Join Date: Jan 2009 Location: Root tunnel Age: 36
Member: 952111 Status: Offline Sonork: I'm not using now. Thanks Meter: 713 | Yes if you have gc pro you can.. Assuming you are on higher and latest build you need combination firmware..install it and after that you can write cert by uart(comport).. Notebypass knox or reset msl is still required to write cert) |
04-14-2017, 00:51 | #5 (permalink) |
Freak Poster Join Date: Feb 2016 Location: Cayman Islands
Member: 2529251 Status: Offline Thanks Meter: 275 | No bro . First you need to root the device and use gcpro key yo bypass knox then write the cert back. Check to see if the baseband is good if not you need efs and cert Sent from my SM-G930F using Tapatalk |
04-18-2017, 16:34 | #8 (permalink) |
Member: 952111 Status: Offline Sonork: I'm not using now. Thanks Meter: 713 | Root can damage knox Mr.Pro. What I said is based on my personal experience. If you have never tried it out it does't mean that it will not work. |
