Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GPGIndustries Support section > Distributed Devices by GPG > GCPro Key
Old 04-22-2017, 20:16   #1 (permalink)
Member: 2183509
Thanks Meter: 68
Exynos & Qcom FRP Userdata
Can anyone explain what these Exynos and Qcom FRP Userdata good for?
I know they help with FRP removal but what makes this different from the traditional ways of FRP removal.
Old 04-22-2017, 21:37   #2 (permalink)
Member: 49752
Sonork: QQ:1474246528
Thanks Meter: 6,085
Hello
As you know download mode remove frp is exploit closed in late 2015.
frp zip in support are force user data to skip setup and bypass frp. so you can go in settings and ON OEM unlocking & factory reset. which will disable frp on that handeset. note that this exploit also closed in 08-2016 by samsung.
You dont need to extract file. use gcpro sam zip flash select zip file it will be flashed.
The Following 4 Users Say Thank You to stanner_austin For This Useful Post:
Old 04-22-2017, 22:25   #3 (permalink)
Member: 2183509
Thanks Meter: 68
Thank you Stanner for the explanation!
Old 04-23-2017, 02:48   #4 (permalink)
Member: 92260
Thanks Meter: 843
Originally Posted by stanner_austin View Post
Hello
Great explanation, I was wondering about it.
Do you know if the "terminal/dialer" exploit has been closed too?
Anything new out there for frp?
Page generated in 4.08043 seconds with 8 queries
