08-17-2016, 22:36 | #1 (permalink) |
Insane Poster Join Date: Jan 2016
Member: 2522275 Status: Offline Thanks Meter: 10 | Exynos Unlock - Can't get it to work Selected Port ssudmdm0000 = COM74 Selected Model GT-I5510 Selected Task SAMSUNG Exynos Unlock no reply Are you sure modem port is alive ??.. !!! Fail !!!! Total Time Take...00:00:46 Log Saved DEVELOPER MODE = ENABLED USB DEBUGGING = ON *#0808# - SELECTED LAST OPTION I tried every port, nothing works. Used UART - still doesn't work. How to get this working?? Please help |
08-18-2016, 09:26 | #2 (permalink) | |
No Life Poster Join Date: Jan 2004 Location: Unknown Age: 39
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | @ogcrct Hello Exynos unlock do not need any code to dial,no need root. Make sure you are using latest update. follow this steps.. Quote:
08-18-2016, 15:06 | #3 (permalink) |
Junior Member Join Date: May 2015
Member: 2393099 Status: Offline Thanks Meter: 0 | Using Version...1.0.0.0035 Selected Port ssudmdm0000 = COM495 Selected Model GT-I5500 Selected Task SAMSUNG Exynos Unlock no reply Are you sure modem port is alive ??.. !!! Fail !!!! Total Time Take...00:00:46 Log Saved phone normal or download mode ????help please |
08-18-2016, 17:53 | #4 (permalink) |
Member: 2522275 Status: Offline Thanks Meter: 10 | I'm getting the same results? Why? Please help. Are we supposed to being using UART? or USB? Using Version...1.0.0.0035 Selected Port VCP0 = COM5 Selected Model GT-I5800 Selected Task SAMSUNG Exynos Unlock Phone Found Please Wait... fail to connect modem .. no reply Are you sure modem port is alive ??.. !!! Fail !!!! Total Time Take...00:00:13 Log Saved Last edited by ogcrct; 08-18-2016 at 18:02. |
08-19-2016, 15:34 | #5 (permalink) |
No Life Poster Join Date: Aug 2015 Location: usa
Member: 2444830 Status: Offline Thanks Meter: 162 | I'm having same issue, it has something to do with the Computer operating system, Windows 7 has no problem but Windows 10 do, I'm trying my best to troubleshoot the issue still no progressed already have the latest drivers installed too... Sent from my SM-N930T using Tapatalk |
08-23-2016, 21:52 | #7 (permalink) |
Freak Poster Join Date: Sep 2012 Location: Minneapolis MN USA
Member: 1815016 Status: Offline Thanks Meter: 77 | Yep same issue here. Using Version...1.0.0.0036 Selected Port ssudmdm0000 = COM167 Selected Model SM-G920F Selected Task SAMSUNG Exynos Unlock no reply Are you sure modem port is alive ??.. !!! Fail !!!! Total Time Take...00:00:47 Log Saved |
08-25-2016, 22:07 | #12 (permalink) |
Member: 2522275 Status: Offline Thanks Meter: 10 | If i use t-mobile unlock and then write cert option it wont work? why?\ exynos unlock can be used on TMOBILE devices. In fact, people direct other people on this forum to use exynos unlock before writing cert on N920T PG1... but for some reason exynos unlock cannot detect modem for N920T on my pc |
08-25-2016, 22:34 | #13 (permalink) | |
Member: 1815016 Status: Offline Thanks Meter: 77 | Quote:
08-26-2016, 09:58 | #14 (permalink) |
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | @ogcrct Hello If you want to write cert do that first when your warranty is not VOID. Then second step is root and unlock phone. About not detect on modem port it can be your pc,driver,your phone settings messed up anything.. we can't guess what can be issue just do hard reset and plug phone read steps on second post follow it if same check on other pc. no other idea sorry. |
