Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GPGIndustries Support section > Distributed Devices by GPG > GCPro Key
Old 08-17-2016, 22:36   #1 (permalink)
Member: 2522275
Thanks Meter: 10
Exynos Unlock - Can't get it to work
Using Version...1.0.0.0035
Selected Port ssudmdm0000 = COM74
Selected Model GT-I5510
Selected Task SAMSUNG Exynos Unlock
no reply Are you sure modem port is alive ??..
!!! Fail !!!!
Total Time Take...00:00:46
Log Saved
DEVELOPER MODE = ENABLED
USB DEBUGGING = ON
*#0808# - SELECTED LAST OPTION
I tried every port, nothing works. Used UART - still doesn't work. How to get this working?? Please help
Old 08-18-2016, 09:26   #2 (permalink)
Member: 49752
Sonork: QQ:1474246528
Thanks Meter: 6,085
@ogcrct
Hello
Exynos unlock do not need any code to dial,no need root.
Make sure you are using latest update.
follow this steps..
go to setting > developer mode enable usb developer mode.
open gcpro gsm tool.
select scan port select samsung usb modem port.
select any model.
accept MTP in phone if ask.
go to Samsung tab.
select Exynos unlock .
press start keep phone screen alive and active.
once job done restart phone if not automatic.
check with with sim card. should be unlocked.
Old 08-18-2016, 15:06   #3 (permalink)
Member: 2393099
Selected Port ssudmdm0000 = COM495
Selected Model GT-I5500
!!! Fail !!!!
Log Saved
phone normal or download mode ????help please
Old 08-18-2016, 17:53   #4 (permalink)
Member: 2522275
Thanks Meter: 10
I'm getting the same results? Why? Please help. Are we supposed to being using UART? or USB?
Selected Port VCP0 = COM5
Selected Model GT-I5800
Phone Found Please Wait...
fail to connect modem ..
!!! Fail !!!!
Total Time Take...00:00:13
Log Saved
Old 08-19-2016, 15:34   #5 (permalink)
Member: 2444830
Thanks Meter: 162
I'm having same issue, it has something to do with the Computer operating system, Windows 7 has no problem but Windows 10 do, I'm trying my best to troubleshoot the issue still no progressed already have the latest drivers installed too...
Sent from my SM-N930T using Tapatalk
Old 08-19-2016, 23:31   #6 (permalink)
Member: 2522275
Thanks Meter: 10
thats gotta be it. i have windows 10 too
Old 08-23-2016, 21:52   #7 (permalink)
Member: 1815016
Thanks Meter: 77
Yep same issue here.
Using Version...1.0.0.0036
Selected Port ssudmdm0000 = COM167
Selected Model SM-G920F
!!! Fail !!!!
Total Time Take...00:00:47
Log Saved
Old 08-25-2016, 19:11   #8 (permalink)
Member: 2522275
Thanks Meter: 10
someone please help us?
Old 08-25-2016, 20:20   #9 (permalink)
Member: 1815016
Thanks Meter: 77
Keeping the screen alive seems to do the trick. So turn up screen timeout, or turn on the option where it never sleeps while charging
Old 08-25-2016, 21:13   #10 (permalink)
Member: 2522275
Thanks Meter: 10
it works on G920T not N920T though? any ideas?
Old 08-25-2016, 21:32   #11 (permalink)
Member: 1815016
Thanks Meter: 77
Exynos Unlock is not for T-Mobile devices. Must use "T-Mobile Unlock" option
Old 08-25-2016, 22:07   #12 (permalink)
Member: 2522275
Thanks Meter: 10
If i use t-mobile unlock and then write cert option it wont work? why?\
exynos unlock can be used on TMOBILE devices. In fact, people direct other people on this forum to use exynos unlock before writing cert on N920T PG1... but for some reason exynos unlock cannot detect modem for N920T on my pc
Old 08-25-2016, 22:34   #13 (permalink)
Member: 1815016
Thanks Meter: 77
The Exynos Unlock only functions as an MSL reset on T-Mobile devices - it does not unlock the SIM. There are many threads reporting success for this model on that version - maybe you can find some tips there. Root access might be needed
Old 08-26-2016, 09:58   #14 (permalink)
Member: 49752
Thanks Meter: 6,085
@ogcrct
Hello
If you want to write cert do that first when your warranty is not VOID.
Then second step is root and unlock phone.
About not detect on modem port it can be your pc,driver,your phone settings messed up anything.. we can't guess what can be issue just do hard reset and plug phone read steps on second post follow it if same check on other pc. no other idea sorry.
Old 08-26-2016, 15:42   #15 (permalink)
Member: 2522275
Thanks Meter: 10
I did hard reset, it's every n920t, not just one. so i know it's not the phone... i'm assuming its either my pc or the software glitch.
Page generated in 0.19071 seconds with 8 queries
