12-20-2017, 05:54 | #2 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Unknown Age: 39
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | @georkings Hello I have corrected it its typo. MIPI and IMEI Cert should be pass before sending ask to reseller. there is no way to check in software for this at present only via dial *#0011# |
The Following User Says Thank You to stanner_austin For This Useful Post: |
12-20-2017, 07:16 | #3 (permalink) |
Banned Join Date: Jan 2014 Location: Havana, Cuba Age: 40
Member: 2107306 Status: Offline Thanks Meter: 612 | Hi @stanner. Do we know at this moment what MIPI DEVICE FAIL stands for? It's hardware? Where in hardware? Thanks in advance. |
The Following 2 Users Say Thank You to Prsctt For This Useful Post: |
12-20-2017, 07:37 | #4 (permalink) |
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | Hello MIPI is extra layer of protection enabled by samsung to verify chip of connector. Which handle USB/UART over same connector. They forcing disable network on hardware level exactly same as for IMEICERT fail on MIPI fail on new devices. Some of qcom samsung can be solved with erase backup & restore backup option via ##33725327# need combination firmware or bypass knox with gcpro Careful do not erase efs its not going to fix MIPI it will fail IMEICERT if any one do so. |
The Following 4 Users Say Thank You to stanner_austin For This Useful Post: |
12-23-2017, 21:14 | #5 (permalink) |
Member: 2107306 Status: Offline Thanks Meter: 612 | Can anyone point me where in the board is this chip? I have some ideas on how to resolve this. Is in the flex handling the charge? |
12-24-2017, 03:40 | #6 (permalink) |
Freak Poster Join Date: Jan 2015 Location: La Habana, Cuba
Member: 2324261 Status: Offline Thanks Meter: 117 | Prsctt man.. contact me... The MIPI Fail is a hard problem.. i solved in my workshop with only heat and flux ... |
The Following User Says Thank You to armandogarriga For This Useful Post: |
